Old 09-18-2013, 12:51 PM   #127
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Originally Posted by Suberman View Post
Fwd can be made to oversteer quite easily despite the weight distribution. The mini is in fact quite balanced in this respect and will pull over 1.0 g on a skid pad, much more than the BRZ.
Sure it can be made to oversteer when you lift or trailbrake. But good luck using a little power-on oversteer to help adjust your line in a FWD car.
A skidpad is just one measurement of how well a car handles. The skidpad is a steady state test. The MINI comes stock with better tires so that figure is no great revelation. The BRZ hits 0.93g on it's "Prius" tires, and has been shown to hit 1.00g just by upgrading the tires and nothing else.
To say the MINI is the best handling car is foolish. It doesn't even handle as well as a DC5 Integra Type R. But that doesn't mean I'm calling it a poor handling car either.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R
WolfpackS2k is offline   Reply With Quote
Old 09-18-2013, 02:35 PM   #128
Razz
Razz's Avatar
Drives: Fast
Cayman
Elise
GTR
RX8
M3
BRZ/FRS
S2000
RX7
Evo X
WRX STI
Razz is offline   Reply With Quote
Old 09-19-2013, 12:14 AM   #129
Suberman
Drives: Subaru BRZ Sport Tech Satin White
I mean a fwd car isn't inherently an understeering car, like all road cars it's designed that way. All modern cars tuck in when you lift off due to weight transfer and suspension design.
A lot of nonsense is bandied about concerning understeer and oversteer.
Basically, oversteer is slow and, at the limit very dangerous.
Understeer is ALWAYS faster. Therefore, a fwd car can be as quick as a rwd car.
Only when torque output gets into the 300 lb ft range do you find fwd no longer able to keep up. Then the torque simply overwhelms the front contact patches.
A mini can be made to go more quickly than a rwd car with the same power. Period.
An integra is fwd, just btw. I'm pretty sure a JCW Mini will make any integra look pretty slow. Those Hondas are very old tech now.
Suberman is offline   Reply With Quote
The Following User Says Thank You to Suberman For This Useful Post:
WolfpackS2k (09-23-2013)
Old 09-19-2013, 01:36 AM   #130
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Originally Posted by jsimon7777 View Post
They do say it's neutral. Of course it has the horrid ride of all Works models.
I drove a stock JCW and a JCW with all the JCW suspension upgrade bits...
The ride was certainly not "horrible" in any way. And the upgraded one handled fantastic of course.
Just couldn't get past the reliability and build quality issues
Kostamojen is offline   Reply With Quote
Old 09-19-2013, 01:42 AM   #131
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Perhaps we drove different ones? I test drove a gen 1 Works. It was painful. Then Car and Driver and everyone else called the current gen awful. Sooo... you have low standards?
Old 09-19-2013, 01:49 AM   #132
Kostamojen
One mans painful is another mans pleasure
Old 09-19-2013, 02:17 AM   #133
TRD_86
Drives: 2013 86 white
Originally Posted by Razz View Post
Cayman
Elise
GTR
RX8
M3
BRZ/FRS
S2000
RX7
Evo X
WRX STI
A great list ; can't think anything better. Is it in order ?
TRD_86 is offline   Reply With Quote
Old 09-19-2013, 11:23 AM   #134
Anaxilus
Drives: They have four wheels
MR2/S gets short shrift again. I guess its lack of power really hurts its handling huh??
Handles better than half the cars on the list at least, especially the 86.
As for the Mini, I've driven them a few times from Gen 1 onward. Always felt pretty shit to me handling wise compared to the MR. Too heavy and unresponsive for what it is in relative comparison. Always makes me laugh when a Mini owner thinks they are going to shake me through a corner. Good luck w/ that. For responsiveness, the Mini feels closer to the 86 chassis than the MR.
Anaxilus is offline   Reply With Quote
Old 09-19-2013, 11:36 AM   #135
EAGLE5
Dismember
EAGLE5's Avatar
Understeer versus oversteer depends on the corner I suppose, but nobody wants a lot of understeer.
Old 09-19-2013, 11:47 AM   #136
Suberman
The real distinction between (or among for that matter) awd fwd and rwd is the effect of excess power.
An understeering car is faster than an oversteering car.
If the engine torque cannot overcome drive wheel tire grip then fwd is likely to be quickest.
If engine torque can overcome drive wheel tire grip the awd will always be quickest.
Awd will ALWAYS understeer initially under excess power because the rear drive wheels will be pushing the front drive wheels sideways as they are turned into corner. Awd and fwd can be induced to oversteer by application of a rear brake.
It is also very difficult to engineer a quick awd car that can also be made to oversteer under power.
Rwd is odd. It is everybody's favourite but it is inferior to awd and fwd technically. It is quicker than fwd only when engine torque would overwhelm the front drive wheels. Awd is always banned from racing categories when rwd cars are desired for entertainment value.
While it may feel fast to oversteer a rwd car it just isn't. It's all for show. Any oversteer wastes forward drive in a rwd car. In fwd and awd drifting a tad does not waste forward drive.
All the fastest forms of road racing use rwd and ban awd.
Old 09-19-2013, 12:27 PM   #137
Anaxilus
It's not just torque/power on the front wheels you have to worry about, but brakes too and this is where drivetrain layout play into weight distribution and tire wear/brake fade as well.
_______
Even the fastest AWD cars are never biased toward the front. Saying FWD is technically superior for going fast is a gross oversimplification of how a car gets from A>B.
Old 09-20-2013, 05:29 AM   #138
EAGLE5
Dismember
EAGLE5's Avatar
I think arguments about what individual aspect of design is best to be silly. It's like arguing RISC versus CISC. Theoretically RISC is faster, but the fab matters way more than the instruction set. You just cannot isolate variables.
Race car design is about being fastest within the rules and budgets. Race rules are all about limiting costs, adding safety, making fun races, and gaining sponsorships. AWD adds complexity and cost. I'm not sure how massive downforce and AWD interact.
But I still think the Mini is crap. My four days in a Cooper S were more than enough for me. I'd rather have a Fiat Panda.
Old 09-20-2013, 05:41 AM   #139
regal
Until the understeer runs you right off the road or leans you up on two wheels. Then you wreck
I've owned a FWD car with a double wishbone suspension koni shock/springs/ sway bar. Grippy summer tires. At its limit on a turn all four wheels would gradually loose grip, perfectly neutral. Took a ton of work to get the car to that level and it was just a B18 engine so not power house.
The FRS is obviously faster in a straight line and right out of the box is nearly as good handling, but its not perfectly neutral yet. Its silly the way they set the car up to oversteer and be unsprung up front, why not just make a neutral car ?
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 09-20-2013, 09:00 AM   #140
DarkSunrise
DarkSunrise's Avatar
Are you still on stock tires? I remember trying to autocross on stock tires and the tail coming around everywhere under power.
But it's a different story when you change tires. On decent summer performance tires, with just maintenance throttle, the FR-S will understeer slightly. But it's very close to being neutral. You can transition it to oversteer with moderate throttle or lift.
Personally I think the FR-S suspension was setup from the factory with mild to aggressive (ultra high, max, extreme) performance street tires in mind. Ditching the stock Prius tires would probably make you very happy.
2022 BRZ Build
2013 FR-S Build
how much drop without hurting handling? nonicname Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 11-19-2012 08:23 PM
Few complaints about the handling need solutions regal Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 10-01-2012 06:21 PM
Delivery processing and handling fee Gamboa1047 Southern California 6 08-26-2012 10:34 AM
A Testimony To The FR-S's Handling skoodge Scion FR-S / Toyota 86 GT86 General Forum 25 06-08-2012 06:36 AM
AE86 handling video... Blokatos FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 9 02-07-2010 04:20 AM
