Old 09-23-2012, 08:07 AM   #1
regal
Few complaints about the handling need solutions
I know everyone raves about the handling of the FR-S, and its phenomenal under 55 mph.
But the stock setup just isn't cutting it for me. At higher speeds it can get bouncy in the front, also there is a point where there is too much lateral body sway away from the wheels as well.
I know enough that trying to piece together the right solution would take more time, trial and error and money than I have, and I don't have time to **** with coil-overs.
Usually what I do is buy the OEM's upgrade, so I would just buy the TRD shocks/springs for a Toyota and be happy, because I know that the new car we buy off the lot is a compromise to give a comfortable ride for average joe. And that TRD doesn't lie about rate, is engineered for the dampers and last as long at an OEM.
I noticed that the FT86 has a higher front spring rate than the FR-S, but the back is too low. Niether have a 1" drop which I know the car needs.
So I need springs/dampers that are better than stock, correctly balanced ratio between F&R , about 1" drop, don't lie about rates, will last hold up , and well matched to a quality damper.
This car's chassis is amazing for the price. But I need help with three things:
1. Front end bounce thru dips and turns at higher speeds.
2. Sharp lateral body sway across the wheel base on turns at higher speeds
3. The steering ratio seem too much at higher speeds. ( I think the answer is e-assist can''t be changed, get used to it.)
Unfortunately TRD isn't offering a simple spring/damper/swaybar upgrade/1" drop. So I need advice. Looking at the sticky the RS-R S/Down are closest to what I need but are the spring rates listed real, is this a OEM quality brand? Are they truly stiffer than stock or just a lowering spring? What about dampers, will they "match".
Or should I wait and TRD/JDM will offer someting besides coil-overs?
thanks
regal is offline   Reply With Quote
Old 09-24-2012, 05:47 PM   #2
Racecomp Engineering
Right now there are 0 options for an upgraded fixed perch replacement damper, but I'm sure they will be coming. It may be a little while though.
The standard shocks are actually decent and can handle a good increase in spring rate. We posted the shock dyno elsewhere and it's available on our Facebook.
In our opinion the front is a little too soft, especially on the FRS.
Yes the motion ratio leads some to believe that ultra stiff in the rear is the way to go BUT the front of the car uses a macstrut suspension which benefits from firmer rates a lot more than the rear of the car. We've gone a different route than most with our performance springs by avoiding an overly stiff rear.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
zoomzoomers (09-27-2012)
Old 09-24-2012, 06:10 PM   #3
jamal
jamal's Avatar
Drives: Legacy GT
A good start would be a set of springs (like the RCE yellows maybe...), and then once a good damper is out (RCE Bilistein, Koni), you can add those.
The only other option for a good damper/spring combo are a few of the coilovers out. JRZ RS1s, AST 4100/4150, KW V3s for example, but they are more expensive and use stiffer springs.
jamal is offline   Reply With Quote
Old 09-24-2012, 06:25 PM   #4
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
I'd also look at what STI has coming out
dori. is offline   Reply With Quote
The Following User Says Thank You to dori. For This Useful Post:
SkullWorks (09-27-2012)
Old 09-24-2012, 07:40 PM   #5
Calum
That Guy
Drives: 2013 asphalt FRS MT
I don't like the way it dips and wobbles in the front either. Have you thought about tires instead of springs. The tires may be the cause of the bounce and the sway, atleast that's what I've been attributing it to.
My plan for the suspension at this point is better tires, stiffer bushings in the rear for more feedback and more alignment options, com-c top hats and camber bolts up front. From there I'll see if the bounce is gone and the twitchyness of the FRS setup is gone.
I would like stiffer front springs, but I don't want to go too far. Honestly I'd love to get my hands on the 185 lb/in springs that were on the preproduction model RCE had. Combined with the stock FRS rear springs I think it would work VERY well. As it is, I've been debating on picking up a set of used BRZ front springs to see how they feel.
Old 09-24-2012, 10:56 PM   #6
fatoni
you mean camber plates and maybe pillowball mounts?
Old 09-25-2012, 06:01 AM   #7
Calum
That Guy
No, I mean com-c top hats and camber bolts
http://www.tougetuning.com/store/eib..._86_94_146_398
http://www.tougetuning.com/store/whi..._86_94_146_398
Old 09-26-2012, 09:37 PM   #8
bpracer
Drives: Asphalt FR-S
Maxed out in an 80mph turn, my FRS' rear end is trying real hard to break loose and the traction control light is flashing like crazy. Amusing, but not fast.
I'm also waiting to see what STI comes out with. I've also thought about installing BRZ front springs. I don't want stiffer rear springs at the back regardless of the front rate
I also hear a "crunch" every once in a while from the front suspension while cornering over fairly good sized dips. At first I thought it was the anti-lock brakes doing something funny. I would hope I haven't run out of suspension travel. It almost sounds like a splash shield rubbing on the coil spring, odd!?!
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
Old 09-27-2012, 10:27 AM   #9
You'd be surprised...with those ultra-soft front springs you're probably well into the bumpstops at the least.
- Andrew
Old 09-27-2012, 11:16 AM   #10
RYU
RYU's Avatar
Drives: really slow...
Everyone is talking about having too much front bounce are driving FR-Ss right?
I have one canyon run under my belt with the BRZ, on stock tires 1500miles, and have taken turns faster than i'd like to admit. I've isolated a few areas to improve on but front end bounce wasn't one of them. Admittedly, I was too busy being mesmerized by this awesome 6AT.
In reality the spring rates aren't drastically different between the fronts of the BRZ vs. FRS but if you look at the front/rear ratio the difference is pretty significant (I did the calculation below). No wonder why the FR-S seems to be so tail happy (I'd love to drive one!!).
OEM Scion FR-S F2.3k & R3.8k | F2.3 R3.8 = 62% rear bias
OEM Subaru BRZ F2.7k & R3.5k | F2.7 R3.5 = 56% rear bias
I ended up with the RCE Yellows because the 4.5k/4.5k makes sense for the kind of driving I like to do and they come very highly recommended from my Subie track buddies. I'm in the process of installing them now and seems like a good piece of kit. My only minor complaint so far is that the springs themselves weight more than the stock (at least in the rear, will find out about the fronts tonight). The stock damper is not fantastic but it's pretty darn good. Way better than even the stock dampers on my brother's M-Sport 128i
RYU is offline   Reply With Quote
Old 09-27-2012, 12:20 PM   #11
jeebus
Drives: 2015 Mustang GT (on order)
With my BRZ, after camber bolts up front and a good alignment, the car is insanely neutral without any nervousness or bounce. When I first got the car I thought it needed a spring swap to get rid of the initial understeer that switched over to oversteer rather quickly. But I no longer feel any spring changes are needed.
jeebus is offline   Reply With Quote
Old 09-27-2012, 12:27 PM   #12
RYU
RYU's Avatar
Tires?
Old 09-27-2012, 01:28 PM   #13
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
Newbish questions forming...... Can you tell me what exactly you added and the intended goal? Im always game for a more "pure" alignment and tracking angle for my DD (reduced tramlining or wandering at highway speeds). Are these just track mods or things that made DD more enjoyable and tire wear the same?
Norkoastal is offline   Reply With Quote
Old 09-27-2012, 02:57 PM   #14
With the OEM camber bolt you can get a little more negative camber up front...usually around -1.2 to -1.5. The result is much more grip and better turn-in. It's still not enough to result in excessive or uneven tire wear. The rear has more than this stock for reference.
It's a 10 dollar must-have mod for every car IMO. The factory alignment is not all that great...very conservative. I'd expect more uneven tire wear on the factory alignment to be honest.
- andrew
Toyota Advertising Complaints nzer Off-Topic Lounge [WARNING: NO POLITICS] 21 08-31-2012 08:35 PM
03/23 Reviews --> No understeer complaints... bloomy116 BRZ First-Gen (2012+) — General Topics 19 03-26-2012 11:06 AM
Highway complaints ZetaVI NY / NJ / CT / PA 7 02-10-2012 12:01 PM
For the complaints (changed title) KAuss Scion FR-S / Toyota 86 GT86 General Forum 29 12-01-2011 04:32 PM
