#15 |
Drives: 2013 Scion FR-S Whiteout White
I'm with you on this, 800 bones just seems steep to me. I know its your best method of adjusting rear camber and I'm for spending money on my car but...
#16 |
Drives: e92 335i, FRS, Lexus ls400
I hit up racerx a few days back and they said the upper control arms give a range of a total of 8 degrees of camber. 4 degrees negative or 4 degrees positive.
IG: nabb335 |
| The Following User Says Thank You to nab335 For This Useful Post: | JordanWho (06-12-2013) |
#17 | |
Drives: Subaru BRZ, Toyota MR2 Turbo
We have had a lot of interest in the upper control arms but most are stating the same issue. Too expensive. I'm curious what would be considered a reasonable price? |
#18 |
I would bet if they were the same price as LCA's they would sell more, but I'm only basing it on personal opinion.
#19 | |
For example I have seen the front lower control arm sell between $649 and $995 but I have not seen many say that part is overpriced. From our experience the upper control arm is more difficult to build than the lower front. I'm curious why the front lower does not seem overpriced?? |
#20 | |
I'd have to say in line or slightly more than quality lca's would be a definite buy from me. Just for reference I havent spent 500 on rear LCA's specifically b/c I feel they are overpriced for what they are, no when I can essentially tune out most of the negative camber I dont want from 125 dollar bushings... |
| The Following User Says Thank You to SuiSid3l For This Useful Post: | DriftEightSix (06-12-2013) |
#21 | |
Drives: 86 GTS
Imo in this price-range you're beyond the 'look at me I've got shiny colourful suspension arms' crowd and dealing with people who are focussed on function, in particular function for the track. So that leaves you with the competition being the offset bushes which provide on-car adjustability for $150-$200 which makes it's tough to justify the price. |
| The Following User Says Thank You to IMOA For This Useful Post: | DriftEightSix (06-12-2013) |
#22 | |
We do have upper control arms in prototype that are adjustable on the vehicle. The arms are currently on hold while we view the interest for the rest of the suspension products. |
#23 |
Drives: asphalt FR-S
They look well built. Considering it's the only upper control arm available so far, the price isn't unreasonable. People will either buy them, or not.
Because of the ease of installation and adjustment, I'll probably go with the lowers though. |
#24 | |
The price is more than I can justify right now, but that doesn't meant it isn't a fair price. I don't think most people look at the consequences of just adjusting the LCA without the toe and trailing links when they purchase them.
#25 | ||
Drives: 2006 STi
eyeballing my LCA and toelinks was extremely difficult. in the end had an alignment shop do it. I read up somewhere about a company attempting to produce these and the result was too difficult to mass produce and sell at an attractive price. Seeing these 800 does not surprise me. As far as fitment goes, sometimes negative camber isnt "Good" camber. For example, the front LCAs being on a Mcpherson setup, Dialing in more negative camber will give you LESS clearance . (same effect on the GD Subarus with Mcpherson all around) On our rears, the LCAs do help for fitment clearance, but the uppers will give you alot more room between tire and fender. LCAs will kick out the bottom of the knuckle/wheel while upper arms will pull in the top of the knuckle/wheel. @racerx1715 Just curious, lets say on stock LCA , trailing, toe links, Whats the maximum negative camber possible with your upper control arms?
| The Following User Says Thank You to SLICVIC For This Useful Post: | JordanWho (06-14-2013) |
#26 |
The funny thing is I saw the price tag and immediately said no thanks, now I'm probably gonna read this entire thread and get talked into buying them...
#27 | |
#28 |
Drives: 2006 STi
Amazing. Thanks.
| Adjustable rear upper control arms??? | Supermassive | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 28 | 09-29-2013 09:17 AM |
| SPC rear lower control arms, Fix your camber! | JoeBoxer | Brakes, Suspension, Chassis | 12 | 03-31-2013 07:02 PM |
| WORKS Rear Upper Control Arm Bushing - Inner Camber Correction | 86_ZN6 | Brakes, Suspension, Chassis | 0 | 02-06-2013 12:20 AM |
