Old 06-09-2013, 10:20 AM   #1
JordanWho
JordanWho's Avatar
Drives: Ford Focus RS & Toyota 86 GTS
Upper control arms for bulk camber
I'm setting up my 86 for drift and want to run a lot of camber all the way around. For the rear I have ordered Whiteline camber bushings and Whiteline LCA's/toe arms. After reading various threads on here and other forums it seems adjustment in the upper arm is the way to go. I have found these upper arms and want to ask everyones opinions or if anyone is actually running them / has any experience with Racer X fab work.
http://www.racerxfabrication.com/fr-...rms/index.html
JordanWho is offline   Reply With Quote
Old 06-09-2013, 10:34 AM   #2
wparsons
wparsons's Avatar
If I needed camber adjustment I would have a set of those for sure. Depending on which direction I go over the winter I'll probably pick up a set then.
flickr
Old 06-09-2013, 06:53 PM   #3
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Racerx is a member on this forum FYI.
I was after a set also but the price has made me have to wait a little longer.
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 06-09-2013, 07:29 PM   #4
OrbitalEllipses
Drives: Attitude
Yeah...$800 for arms that you can't adjust on the car? I appreciate the hard work and design, but no thanks.
Old 06-10-2013, 09:14 AM   #5
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
OMG WANT. with these, LCA's and camber bushings, we should be able to fit some serious offsets in the rear
SLICVIC is offline   Reply With Quote
Old 06-10-2013, 10:16 AM   #6
JordanWho
JordanWho's Avatar
Old 06-10-2013, 04:04 PM   #7
wparsons
wparsons's Avatar
You don't need to worry about the trailing or toe links being adjustable when you run a adjustable UCA instead of LCA, that alone is worth it to me. With a LCA you need to adjust all three links whenever you change the camber setting, not just one.
flickr
Old 06-10-2013, 04:39 PM   #8
console_cowboy
console_cowboy's Avatar
Drives: 2013 Black BRZ Limited
Check out this lower control arm: http://www.spcperformance.com/index....tion&pid=67660
It only adjusts one point, not all three. The adjustment is on the opposite side of the control arm from most. In additional to that, it comes with a toe arm bushing to get more positive or negative toe.
console_cowboy is offline   Reply With Quote
Old 06-10-2013, 09:17 PM   #9
wparsons
wparsons's Avatar
Those will still require adjustments to the trailing and toe links if you change the LCA length enough.
The "issue" is that the LCA, trailing link and toe link all work together as a pseudo LCA, and if you change the length of one of them you should change the other two to keep the wheel in the right place.
If you just lengthen the LCA you effect toe and also the longitudinal location of the wheel which effects anti-squat/dive geometry.
That said, small camber changes might not be so detrimental to the rest of the geometry, but if you change it enough it will definitely effect the rest enough that they'll need adjusting too.
flickr
Old 06-10-2013, 10:55 PM   #10
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
what he said^
this is a very good item to have available. Had to Buy GT Spec LCA and toe links , i'd like to see the camber setting range available with these
Old 06-11-2013, 01:17 AM   #11
console_cowboy
I am hoping to get -1.5 deg of camber on each of my rear wheels using that control arm. I am hoping that the toe bushings included with the kit should help. I am currently sitting at -1.8 deg on one side and -2.4 deg on the other. I'd like to get the camber down to -1.5 deg with zero toe on the rear. The bushings should help some, but if I have to get replacement toe links I will.
Thank you for the excellent information. Hopefully I will not have any issue. I also have the KCA326 adjustable upper control arm bushings, but am having trouble finding someone who can install them locally without charging an arm and a leg. I lack the tools the do the bushing press myself. I may try to get them off and take them up to a shop. I am also unsure that I will be able to get enough adjustment from the bushing kit alone for the one side.
Old 06-11-2013, 03:24 AM   #12
OrbitalEllipses
Drives: Attitude
Using the SPC arm and toe bushings I ended up at -1.5 rear camber with 0 toe. Any less camber resulted in toe change. I'm only dropped 20mm so YMMV.
The Whiteline UCA camber bushings are good for +/- 0.75 camber.
In the end the LCA and toe arms (if needed) end up being cheaper if you install them yourself versus getting the arm removed, bushing pressed, and arm reinstalled.
Old 06-11-2013, 09:58 AM   #13
console_cowboy
I am also only dropped 20mm or so with the RCE yellow springs. I am shooting for -1.5 in the rear, so that should be perfect. Hopefully I will have the same luck and be able to get that into spec.
If I require any more in the future, I could possibly remove the upper arms and have the bushings pressed in. The cost for that should be much less.
Also, which style control arms did you use? I used these: http://www.spcperformance.com/index....tion&pid=67660
I believe there is another style of arms as well, although the older style does not look as nice.
Old 06-11-2013, 11:13 AM   #14
OrbitalEllipses
Drives: Attitude
I have the other style.
Adjustable rear upper control arms??? Supermassive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 09-29-2013 09:17 AM
SPC rear lower control arms, Fix your camber! JoeBoxer Brakes, Suspension, Chassis 12 03-31-2013 07:02 PM
WORKS Rear Upper Control Arm Bushing - Inner Camber Correction 86_ZN6 Brakes, Suspension, Chassis 0 02-06-2013 12:20 AM
