Old 05-29-2013, 11:47 AM   #1
Drftfan
Drives: Argento FR-S
Show your drift setups
If I had one yet I would show mine... Lol
Drftfan is offline   Reply With Quote
Old 05-29-2013, 11:52 AM   #2
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
What information are you looking for?
Old 05-29-2013, 04:11 PM   #3
Drftfan
Just suspension and stance shots I suppose. I didn't think about it lol
Old 05-31-2013, 01:15 AM   #4
drift94
Drives: 2013 scion frs whiteout
Heres my question.
i want to run, 215/45/17 in the front and 235/45/17 or 18 in the back
lowered on stance coils.
to drift. so what wheels would look the most aggressive without rubbing?
other elements that i dont know are, how low im going to sit on the coils
and whether 18 works better in the back for drifting, ive been told before "18 in the back for function" but never learned why.
drift94 is offline   Reply With Quote
Old 06-05-2013, 01:09 AM   #5
hypermax
hypermax's Avatar
Drives: BRZ Limited
this is my BRZ drift setup, 18/9.5 all around, 225/40 front and rear. set the coilovers to leave you around somewhere .5-1 inch in the front, this is for your safety that ur wheel wouldn't hit ur fender when u fully counter steer and hitting any bumps while you doing that. it is already tested by me. how this would help you.
Follow me on instagram if you want, hypermax350
hypermax is offline   Reply With Quote
The Following User Says Thank You to hypermax For This Useful Post:
Kuzuri (06-05-2013)
Old 06-06-2013, 10:43 AM   #6
TylerLieberman
Drives: '24 GR86
XXR 17x8.25 +25 wheels
Achilles ATR Sport 215/45 Tires
Stance Coilovers
Ran the stock wheels & tires in the back last time.
Running the rear coils on full stiff. Around -2 camber
Front coils about mid way on stiffness and around -4 camber.
Works pretty well. Just need less camber in the rear. A bit more rear end grip would make it perfect.
The Following User Says Thank You to TylerLieberman For This Useful Post:
Godzilla35 (06-08-2013)
Old 06-06-2013, 11:03 AM   #7
Drftfan
Thanks for post guys. I am getting ready to order my coils and my wheels and this helps the decision process
Old 06-06-2013, 05:14 PM   #8
Lanbaldo3
Divine Wind - Dori
Lanbaldo3's Avatar
Drives: RWD
IMO i think if you go that wide of tire with an underpowered car you'd have a hard time getting it off the ground. In my 240, comparing it, had stock motor welded diff and full suspension and arms 215/45/17 rear (normally), and i tried running wide tires (235-45) you can feel the difference... clutch kicking alot and you have to pick up so much speed. 225 on the rear seems the max to put on the car with stock motor. i mean our cars are a little bit more stronger then a KA and Less then a SR unless you wanna swap the motor out. IMO. but try it out. I really havent tested my car out since im broke... but hopefully i'll be able to at word up! in august. so far my setup is Lowered 2.5" on BC and stance LCA and spc rear toe. and spare drift tires/rims ready for august...
1990 FC3S T2swapped! "Savannah"
1992 240sx Type X "Nadia"
2013 Scion FRS "Raven"
Drift Specials.....
Lanbaldo3 is offline   Reply With Quote
Old 06-09-2013, 07:30 PM   #9
FRS8SIX
Drives: 2013 hot lava FR-S
Here's mine drift setup that day...
[IMG]http://i373.photobucket.com/albums/oo179/96jdmls/ED7A5977-DA51-45A2-80D0-62B92294C1D7-2486-000001253B09B32C_zps60c***27.jpg[/IMG]
FRS8SIX is offline   Reply With Quote
Old 06-09-2013, 09:57 PM   #10
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
@TylerLieberman what coilovers are you on and how low are you? any rubbing issues?
Enraged21 is offline   Reply With Quote
Old 06-10-2013, 07:58 AM   #11
XCIV.Andrew
XCIV.Andrew's Avatar
Drives: ASPHALT FRS
Check out my Journal for more detailed specs!
XCIV.Andrew is offline   Reply With Quote
Old 06-10-2013, 02:46 PM   #12
ebphoto
Drives: FR-S, NA8, S13
run 9.5j +25 for daily and street drift and have a pair of 9.5j +40 i use as spares at the track. 225/40 on all wheels. run bc coilovers and stance lca.
ebphoto is offline   Reply With Quote
The Following User Says Thank You to ebphoto For This Useful Post:
humanshield (06-10-2013)
Old 06-10-2013, 10:50 PM   #13
philstar
philstar's Avatar
I run stock size 215/45/17s, currently Nexen N3000 all around, and STANCE coilovers
philstar is offline   Reply With Quote
The Following 2 Users Say Thank You to philstar For This Useful Post:
boucher (06-11-2013), HATED1 (06-11-2013)
Old 06-11-2013, 08:34 PM   #14
TylerLieberman
Drives: '24 GR86
Stance Coils.
Pretty low. Coils still have another inch before they're maxed. No rubbing issues
2013 NonStopTuning Anniversary Car Show & Drift Competition Do Boy Southwest 4 09-03-2013 04:56 PM
Setups for drifting? 6-Shift Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 04-11-2013 10:08 PM
Drift oriented suspension setups? bigjake Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 03-07-2013 10:45 AM
[NSW] 26th Jan ALL STARS AUSTRALIA DAY DRIFT/SHOW N SHINE/BIKINI CAR WASH alexm86 Australian Meets & Events 0 01-03-2013 05:35 AM
Anyone here in SQ setups? Dave-ROR Electronics | Audio | NAV | Infotainment 25 04-03-2012 07:13 AM
