Old 06-04-2013, 07:37 AM   #155
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by v1ru5 View Post
Where does the connector go in the oil system? Does it screw in with the oil filter?
This is not an easy pic to see, but look between the intake and the A/C compressor. There is a yellow "thing" there. That is a Oil Pressure sender. There is a plug in the block in that area. Mach V sells a plug that includes the standard threads for senders (1/8" NPT).
Plug Pic:
Sportsguy83 is offline
The Following User Says Thank You to Sportsguy83 For This Useful Post:
v1ru5 (06-04-2013)
Old 06-04-2013, 09:19 AM   #156
FA20Club.com
Drives: 2013 White Out FR-S
you can use a BSPT to NPT adapter and a tee to use the oem pressure switch port
FA20Club.com is offline
Old 06-09-2013, 10:55 AM   #157
FA20Club.com
fyi most of you have already made payment for the GB but the deadline is this coming Friday to get locked in. we have already placed a large order but the gauges will be shipped on a first come basis. P3cars is expecting a shortage but we already have enough allocated for those who signed up currently. if more people join in those who have made payments by Friday get first priority.
The Following User Says Thank You to FA20Club.com For This Useful Post:
lbroskee (06-09-2013)
Old 06-09-2013, 12:05 PM   #158
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
Any side to side adjustments in the vent? I usually need to adjust my stocker inward a bit.
CO>CA Cartel
Norkoastal is offline
Old 06-09-2013, 12:27 PM   #159
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
I put in my request yesterday, just waiting to receive my invoice to be able to pay...
Akuhei's Blog
"Inconceivable"
akuhei is offline
Old 06-09-2013, 06:36 PM   #160
FA20Club.com
sorry vent angle is fixed
Norkoastal (06-10-2013)
Old 06-09-2013, 06:36 PM   #161
FA20Club.com
sent, thanks again
akuhei (06-09-2013)
Old 06-10-2013, 04:48 PM   #162
Deepseadiver
Drives: 2013 BRZ DMG manual Limited
Can't wait, remember to update my shipping address. I sent a e-mail when I ordered requesting the change.
Deepseadiver is offline
Old 06-10-2013, 08:06 PM   #163
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Originally Posted by lbroskee View Post
the vent is cool but can it be turned like OEM (yes i know that means a turned gauge)
Originally Posted by cb7tuner View Post
Yes it can, as long as you leave enough slack for the ribbon cable to move
depending on how and where you secure the black box (brains of the gauge).
Sooo.....?
I assume you can.
Are you trying to prevent wear to the ribbon with your suggestion.(or is it fact)?
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline
Old 06-12-2013, 01:30 PM   #164
FA20Club.com
Originally Posted by Floggin Tires View Post
Sooo.....?
I assume you can.
You can rotate the entire unit to change the angle which means you rotate the lcd as well your decision what your want to do
Old 06-12-2013, 07:47 PM   #165
lexusb3
Drives: FRS
Here a view of it at a different side
lexusb3 is offline
The Following User Says Thank You to lexusb3 For This Useful Post:
lbroskee (06-12-2013)
Old 06-12-2013, 07:52 PM   #166
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Looks odd as hell but answers the question
lbroskee is offline
The Following User Says Thank You to lbroskee For This Useful Post:
mike2100 (08-18-2013)
Old 06-14-2013, 04:46 PM   #167
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
If this is ordered and paid for today, when will this ship? Also, on the webpage you have an option for "EXTERNAL SENSORS" what is that for and when would i need these?
gdrider77 is offline
Old 06-15-2013, 05:08 PM   #168
gdrider77
gdrider77's Avatar
Bump.
I am just trying to figure out if this will work for wideband AFR? Does this save me from having to install an o2 sensor on my overpipe? I was planning to install an AEM wideband but it wont be needed if this does wideband. Anyone have an idea?
Basically instead of an AEM wideband failsafe gauge with o2 weldin bung and o2 sensor, i could just use this and get wideband through the obd?
gauge, p3cars
LHD 3-meter gauge-pod? TuxedoCartman Cosmetic Modification (Interior/Exterior/Lighting) 27 02-11-2015 06:19 PM
Dash Cam + HU + Reverse Integration JDMSushi Electronics | Audio | NAV | Infotainment 0 12-04-2012 06:47 PM
iPod®/USB Integration in the glove box? 8987846 Electronics | Audio | NAV | Infotainment 26 12-04-2012 12:45 AM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 04:29 PM
Gauge Sweep? himbo BRZ First-Gen (2012+) — General Topics 17 12-12-2011 11:39 AM
