Old 06-01-2013, 06:56 PM   #141
FA20Club.com
Drives: 2013 White Out FR-S
PID locations on some parameters will differ but stuff like rpm speed etc the basics will most likely still work.
FA20Club.com is offline
The Following User Says Thank You to FA20Club.com For This Useful Post:
lbroskee (06-01-2013)
Old 06-02-2013, 12:52 AM   #142
Auto-Hauss
Auto-Hauss's Avatar
Drives: 2013 Scion FR-S-Asphalt
Fan! How long is the group by price available?
Auto-Hauss is offline
Old 06-02-2013, 12:52 AM   #143
FA20Club.com
until the official release i think should work for everyone
lbroskee (06-02-2013)
Old 06-02-2013, 01:13 AM   #144
Dezoris
Dezoris's Avatar
Signed up thanks for adding oil pressure option, this is huge as its the only thing I can't get with Torque and worth the cost of the gauge.
Dezoris is offline
The Following User Says Thank You to Dezoris For This Useful Post:
Sportsguy83 (06-02-2013)
Old 06-02-2013, 09:20 AM   #145
karlsson
Drives: seat ibiza
For us Europeans
Can the oil-temperature reading be changed to read in °C instead of Fahrenheit ?
With the external oil pressure sensor, is it just psi or is it possible to show the pressure in bar?
thanks.
edit: Just saw in the p3cars.com FAQ that metric and English units can be changed on the fly.
correct me if I'm wrong
karlsson is offline
Old 06-02-2013, 12:48 PM   #146
FeaR-S
Drives: Great White
Saw the post on P3cars
"The interface is shipped by default using English units, but is configurable for both English and Metric on the fly via the config menu. You can also set it so that only boost is in PSI, but the rest is in Metric. Metric settings also changes the 0-60mph timer to a 0-100kph timer, and the temperatures to Celsius. Please see the operating instructions for details."
FeaR-S is offline
Old 06-02-2013, 01:49 PM   #147
karlsson
Drives: seat ibiza
thanks for the quote
karlsson is offline
Old 06-03-2013, 07:32 AM   #148
BenArmstrong
BenArmstrong's Avatar
Drives: White GTS, Vortech, Aero kit
Definitely want RHD gauge please
Also, could be a silly question but just double checking, does this get boost reading from a factory sensor (don't have to add any aftermarket sensors)?
BenArmstrong is offline
Old 06-03-2013, 08:16 AM   #149
FA20Club.com
yes the factory sensor is used for vacuum/pressure readings
The Following 3 Users Say Thank You to FA20Club.com For This Useful Post:
BenArmstrong (06-06-2013), cb7tuner (06-03-2013), lbroskee (06-03-2013)
Old 06-03-2013, 11:06 AM   #150
v1ru5
Drives: BRZ D4S 6MT L Vortech
What else is needed parts wise to hook up the oil pressure sensor?
v1ru5 is offline
Old 06-03-2013, 02:59 PM   #151
Deepseadiver
Drives: 2013 BRZ DMG manual Limited
Filled out the form!
Deepseadiver is offline
Old 06-03-2013, 05:31 PM   #152
FA20Club.com
you get the connector you will need to wire it yourself only 3 wires nothing major.
lexusb3 (06-03-2013)
Old 06-03-2013, 05:38 PM   #153
djdnz
1337
Drives: 2013 BRZ WRB S/C
I don't really need any gauges just yet but this thing is just too damn slick. Will check the finances :P
djdnz is offline
Old 06-03-2013, 08:55 PM   #154
v1ru5
Where does the connector go in the oil system? Does it screw in with the oil filter?
v1ru5 is offline
gauge, p3cars
LHD 3-meter gauge-pod? TuxedoCartman Cosmetic Modification (Interior/Exterior/Lighting) 27 02-11-2015 06:19 PM
Dash Cam + HU + Reverse Integration JDMSushi Electronics | Audio | NAV | Infotainment 0 12-04-2012 06:47 PM
iPod®/USB Integration in the glove box? 8987846 Electronics | Audio | NAV | Infotainment 26 12-04-2012 12:45 AM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 04:29 PM
Gauge Sweep? himbo BRZ First-Gen (2012+) — General Topics 17 12-12-2011 11:39 AM
