#15 | |
Here we go, first to market with the 2013 BRZ/FR-S downpipe with a 200 cell metallic core high flow cat. This helps the engine breathe easier and helps to fill in the torque valley that this engine exhibits. We supply all required hardware but the factory gaskets are reused. UPDATE: This now fits both the Automatic and the Manual both with and without the Helmholtz resonator!" |
#16 |
Drives: 2024 MT Toyota GR86
What does your invoice say?
2024 Toyota GR86
2013 Scion FR-S |
#17 |
@mistawho you live in washington right? just go to their shop if you have too.
2024 Toyota GR86
2013 Scion FR-S |
#18 |
Add lightness!
Drives: 17' WRX
Find a new shop. The pipe you are trying to replace is wrong. The stock midpipe with the bottle resonator stays on the car. The nameless pipe goes on forward of that pipe all the way to the headers. Take off the plastic shield just aft of the metal splash shield. You will see your header. The nameless pipe bolts to that and the stock midpipe with the bottle resonator. The muffler section is a one for one swap.
#19 |
I Love custom Turbo kits
Drives: Limited BRZ
That looks like the Auto part. The Helmholtz resonator is moved to a different place (instead of right with the Cat) to not interfere with Auto tranny.
#20 |
Drives: FRS 2013
Taking stock overpipe is a breeze. Unbolt the front pipe and take it down , unbolt the over pipe. Then take the heat shield off. Rotate the over pipe to get to the other heat shield bolts. Once heat shield is off it comes out with ease. Took less then a hour to do both the overpipe and front pipe in my driveway on stands.
#21 |
Drives: Scion FR-S 2013
Sprayed mine with WD40, and yeah, they were rusty, but they have up easy enough. I would have jacked up the engine if I'd thought about it, but I guess my brain was done for the day at that point.
| FBM Billet High Flow Fuel Rails | FullBlown | Forced Induction | 17 | 05-17-2014 02:53 PM |
| AEM High Flow In-Tank Fuel Pump | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 04-13-2013 12:15 PM |
| WORKS High-Flow Drop-In Filter ~ +10 WHP Gains | 86_ZN6 | Engine, Exhaust, Bolt-Ons | 18 | 03-09-2013 11:44 PM |
| SRT FR-S/BRZ High Flow Intake System R&D | Swift Racing Technologies | Engine, Exhaust, Transmission | 160 | 03-03-2013 12:41 AM |
| AVO High-Flow Panel Filter! | AVOturboworld | Engine, Exhaust, Bolt-Ons | 0 | 08-24-2012 06:02 PM |
