Old 06-07-2013, 12:25 AM   #379
415FRS
Drives: Red SCion FRS
Another question i have. This might be a very stupid question but i will ask anyway haha. So without SC, I hit 70mph at around 3000rpm in 5th gear, with Vortech SC will i hit 70 mph at a much lower rpm or more in the same gear? Thats where i am usually at when cruising on freeway anyway. Thanks
Sent from my HTC One using Tapatalk 2
415FRS is offline   Reply With Quote
Old 06-07-2013, 04:11 AM   #380
JordanInnovations
Drives: Forced Induction and LSx Swaps!
Same RPM, gearing doesn't change. You'll just run through the gears faster.
JordanInnovations is offline   Reply With Quote
Old 06-07-2013, 12:11 PM   #381
SillySaxon
SillySaxon's Avatar
Drives: Sc10n Series FR-S
Will you need to upgrade you exhaust system if you boost?
Will you need to upgrade ANYTHING if you boost?
I know high PSI requres a build, but what's a decent PSI to run that will gave it some more fun power, without needing to build the engine?
SillySaxon is offline   Reply With Quote
Old 06-07-2013, 12:16 PM   #382
nelsmar
The standard kit comes with boost designed for the stock motor.
My flickr - Canibeat
Local magazine scout
Old 06-07-2013, 12:25 PM   #383
djdnz
1337
Drives: 2013 BRZ WRB S/C
The clutch might not hold up for too long at these power levels though.
djdnz is offline   Reply With Quote
Old 06-07-2013, 12:28 PM   #384
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
That isn't true... Jeff Perrin @PERRIN has been running the vortech since it was released, he drives it A TON and is not nice to it. He is still on stock clutch.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
Old 06-07-2013, 12:32 PM   #385
SillySaxon
SillySaxon's Avatar
Originally Posted by Brian@Vortech View Post
The V-3 H67BC Supercharger has a maximum impeller speed of 50,000 rpm
A 3.48" S/C Pulley = 43,022 @ 7,400 engine rpm
A 3.40" S/C Pulley = 44,034 @ 7,400 engine rpm
A 3.33" S/C Pulley = 44,960 @ 7,400 engine rpm
A 3.25" S/C Pulley - 46,066 @ 7,400 engine rpm
A 3.125" S/C Pulley = 47,909 @ 7,400 engine rpm
A 2.87" S/C Pulley = 52,166 @ 7,400 engine rpm, which is beyond the maximum impeller speed, and therefore we would advise against utilizing with this system.
So at these impeller RPM, what kind of PSI would we be looking at?
Can the stock engine handle all of these no problem?
Also, what sort of exhaust would I need, or can that be stock as well? (I'll probably get the Perrin 2.5" because it sounds awesome)
Old 06-07-2013, 01:32 PM   #386
DJCarbine
Thupercharged
DJCarbine's Avatar
Originally Posted by ft86me View Post
dope! what does it sound like?!? this basically a pull out the old put in the new deal?
As long as you get the 25mm version, it is a direct replacement.
It even comes with a blocking plate so you can either block off the standard vent port, or the "loud" vent port depending on how you want it.
I also adjusted the spring pre-load on mine, the boost pressure seems to be even more "instant" when going from vacuum to WOT. Perhaps it transitions from open/closed(Sealed) a little quicker, not sure.
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following 2 Users Say Thank You to DJCarbine For This Useful Post:
charged86 (06-07-2013), ft86me (06-07-2013)
Old 06-07-2013, 09:48 PM   #387
ft86me
ft86me's Avatar
Drives: 2013 FRS
So I can have it on the "loud" port if desired? It still does release constantly while below like 3/4 throttle right? Would that mean the release is really loud too?
can you explain the second part some more? did you mean that it blows off in lower rpms as well?
ft86me is offline   Reply With Quote
Old 06-07-2013, 10:53 PM   #388
DJCarbine
Thupercharged
DJCarbine's Avatar
Basically the exit with the barbed end has a cutout into the chamber a little lower, so when only small amounts of pressure need to be bled off it dumps to that port.
The exit with the "horn" on it has the cutout higher, so that the piston has to travel much higher to dump air that way. Normal idle /cruise air dump is mostly/all out of the barbed exit, and it only vents to the "horn" exit during letoff at high rpm when there is boost in the charge pipes/vacuum in the manifold.
The barbed end is threaded into the body of the valve, as well as the horn end. You can swap them to whatever configuration you desire, or install the blockoff plate.
I only hear a loud release if I am cruising at very high RPM, or during shifting/letoff at high rpm. By high RPM I'm talking above 5K.
I could dial it in more using the adjustable spring to make it happen sooner/later, but it works just fine on any setting. I tried full soft up to about 75% tighter, and it just works. Always seals up when it should, and lets off excess when iti should
2013 FRS
Vortech V3 11psi
The Following 4 Users Say Thank You to DJCarbine For This Useful Post:
civicdrivr (06-08-2013), F1point4 (02-28-2014), ft86me (06-07-2013), HRTROB (03-16-2014)
Old 06-07-2013, 11:20 PM   #389
ft86me
ft86me's Avatar
Drives: 2013 FRS
i guess the horn would be the one i want since it's the loudest and it seems i would need to adjust the spring to where it blows off even at like 3 haha. i just love the sound.
Old 06-08-2013, 11:30 AM   #390
Deepseadiver
Drives: 2013 BRZ DMG manual Limited
I started the install, so far so good! only bad thing is that I placed my bumper in the grass when I took it off so it wouldn't get scratches, and the dam wind caught it and flipped into the drive way and scratched it.
Deepseadiver is offline   Reply With Quote
Old 06-08-2013, 01:15 PM   #391
sf86
sf86's Avatar
Drives: Red Scion FRS AT
i will start installing my SC tomorrow but in my Garage so I don't get my bumper blow away like yours. )
sf86 is offline   Reply With Quote
Old 06-10-2013, 02:43 PM   #392
SillySaxon
SillySaxon's Avatar
Something I haven't really seen mentioned yet.
How well does the Vortech tune support an upgraded exhaust system to include headers?
I was checking out the Perrin Overpipe, Frontpipe, midpipe, and catback system and was thinking about combining that with the Borla UEL headers.
I did see a post about the Visconti tuning providing enough fuel for headers so I was wondering how the vortech tuning held up
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
