Old 05-31-2013, 04:17 PM   #365
415FRS
Drives: Red SCion FRS
All the Vortech kits you guys are selling for the FRS/BRZ work on the AT, am i right ? 'cause i just bought a stage one kit from a vendor here in Cali but I forgot to ask if it works on my AT ). And do I need any other mods to support the kit to keep the car from breaking ? I am planning to keep this car for a while with a little more power. Thank you everyone.
415FRS is offline   Reply With Quote
Old 06-03-2013, 06:47 AM   #366
Foobar
SLO NO MO
Foobar's Avatar
FYI I noticed a few guys reporting a leaky windshield washer reservoir.
The trick is to not over tighten the bottom cap and make sure that the gasket stays centered as you tighten it. You can look through the top opening as you tighten it to make sure it remains centered. If it starts to bunch up, redo it and stop before it does it again.
I didn't need to seal the cap with anything extra and its holding nicely.
Sent from my Nexus 4 using Tapatalk 2
Old 06-05-2013, 02:59 PM   #367
deange
Drives: Black 2013 BRZ Limited Automatic
I'm sure it is buried some where, but I have yet to find it... but how much weight does the Vortech kit add to the front end as compared to stock?
deange is offline   Reply With Quote
Old 06-05-2013, 03:09 PM   #368
Dezoris
Dezoris's Avatar
Around 40lbs.
The Following User Says Thank You to Dezoris For This Useful Post:
deange (06-05-2013)
Old 06-05-2013, 03:10 PM   #369
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Originally Posted by Brian@Vortech View Post
Thank You
I missed the boat but how much are the Vortech windshield fluid reservoirs?
post_break is offline   Reply With Quote
Old 06-05-2013, 03:11 PM   #370
Dezoris
Dezoris's Avatar
Mine leaks from the top tube when you start to fill the tank and fluid gets to the neck tube you hack off from the stock reservoir. I tried to adjust tension on clamps etc. etc. still leaks.
Old 06-05-2013, 03:24 PM   #371
Brian@Vortech
Brian@Vortech's Avatar
Drives: Vortech Supercharged M6 FR-S UM
The systems will mount right up to an Automatic without issue, but we have not released our tuning for the automatics yet. If you bought a Tuner kit, you'll either be sourcing a tune from the tuner you bought the system from, or a local shop. If you bought the complete system, you will have to source a tune separately. We should have our Automatic calibration done in a few months.
Brian@Vortech is offline   Reply With Quote
The Following User Says Thank You to Brian@Vortech For This Useful Post:
415FRS (06-05-2013)
Old 06-05-2013, 07:17 PM   #372
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
You gotta love this forum. He did say with all due respect. With all due respect, I would say that if you think $200 is too much than forced induction might not have been the way to go on your car.
I have the vortech kit on my car. I'm just saying $200 is too much money just to change the way the "pssshhhhh" sounds.
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE
277hp 93 octane
370hp on E-85
draggin_az is offline   Reply With Quote
Old 06-06-2013, 08:41 AM   #373
DJCarbine
Thupercharged
DJCarbine's Avatar
Aluminum with no diaphragm construction over plastic was another perk.
I was just putting the info out there in case others were thinking about it.
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following User Says Thank You to DJCarbine For This Useful Post:
draggin_az (06-06-2013)
Old 06-06-2013, 04:06 PM   #374
charged86
charged86's Avatar
For me and the turbosmart BoV when redlining 3rd to 4th to 5th there is a satisfying "keesh" loud air release. But the engine and boosted exhaust note are better than any "pssh" squeal.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 06-06-2013, 04:29 PM   #375
SillySaxon
SillySaxon's Avatar
Drives: Sc10n Series FR-S
Hopefully this is the right thread for this.
As a boostnoob (boooob?) I was wondering why people like the roots style, lower rpm torque peak boosts?
The stock model hits peak torque at 6600 so wouldnt it make sense to keep boost peak as close to that as possible?
SillySaxon is offline   Reply With Quote
Old 06-06-2013, 11:05 PM   #376
ft86me
ft86me's Avatar
Drives: 2013 FRS
Originally Posted by DJCarbine View Post
For anyone else looking to replace the plastic bypass valve with something a little more robust/louder, I found a bolt in replcement.
http://www.turbosmartusa.com/product...-universal-fit
You want the 25mm version.
It is a dual port, so you can retain the K&N filter on the dump port. Both ports are the same 1" as the plastic bosch unit. It simply replaces the bosch unit retaining the factory hose/K&N filter.
For those who will argue that this may suck in un-filtered air through the "horn" port, the supercharger produces more airflow than the engine can ingest even at idle. Also, this valve only fully opens to dump air out of the "noisy" horn at high intake manifold vacuum/positive pressure in the charge pipe. Otherwise it only vents to the dump port with your K&N filter.
This results in a valve that operates pretty much exactly like the included plastic bosch valve, however at moderate/high boost it produces a nice deep "whoosh" sound like a traditional BOV.
You can also block off the "horn" with the included blocking plate, then it will work exactly like the plastic bypass valve without any noise.
Unnecessary? Probably.
But it is fun, and I prefer aluminum over plastic.
Perhaps Vortech can chime in if this is a bad idea, but I'm familiar with boost and this seems solid in operating theory with no chance of unfiltered air entering the system(My main concern).
dope! what does it sound like?!? this basically a pull out the old put in the new deal?
ft86me is offline   Reply With Quote
Old 06-06-2013, 11:22 PM   #377
415FRS
Does this Vortech SC makes the exhaust any louder. My TRD exhaust is perfect as it is now.
Sent from my HTC One using Tapatalk 2
Old 06-06-2013, 11:55 PM   #378
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
It'll be a bit louder at wide open throttle, of course. At any point where you're not making more power than before, the exhaust won't be louder. (cruise)
Sellout is offline   Reply With Quote
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
