Old 03-18-2013, 02:36 PM   #71
stockysnail
Just the tip
stockysnail's Avatar
The Scangauge is cheaper on Autozone.com with their coupon code they list on their site so instead of being $160 it's $127.99, so I bought one.
The Following 2 Users Say Thank You to stockysnail For This Useful Post:
heeltoe86 (04-05-2013), theredtape (03-25-2013)
Old 03-25-2013, 03:00 PM   #72
theredtape
Drives: civic,vfr,BRZ
Awesome ! even cheaper than amazon. I was on the fence but knocking 30 bucks off goes a long way towards changing my mind
Edit: And free shipping !
Because Racecar.
theredtape is offline   Reply With Quote
Old 03-26-2013, 11:27 AM   #73
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
For those that have expressed interest in my 3D printed mount. I'm sorry but I'm not going to get into the business of selling them. However I have gone ahead and uploaded the design to a print on demand service where you can have it made and shipped to you. You can also buy the design there for a small fee and print it yourself if you happen to have access to a 3D printer.
http://cubify.com/store/creation.asp...nce=8FYGO8GFX2
I make no promises as to the quality of their parts, and offer no support, but if someone does try it please let me know how it turns out. If it works well I may submit other designs there.
The Following User Says Thank You to neutron256 For This Useful Post:
TIE Pilot (03-26-2013)
Old 03-29-2013, 09:29 AM   #74
theredtape
50 bucks! holy crap that is a lot of cash for a mount.... Guess I should put some time into making my printer work again :P
Because Racecar.
Old 04-04-2013, 10:34 AM   #75
theredtape
@pkny
Any chance there is a code for trans temp? Do we even have a transmission temp sensor?
Because Racecar.
Old 04-05-2013, 07:05 PM   #76
pkny
Drives: Firestorm FR-S 6MT
It doesn't have a temp sensor for MT. AT, on the other hand, has a temp sensor, but I don't if it is a dumb sensor or not
2013 Scion Firestorm FR-S MT
pkny is offline   Reply With Quote
Old 04-06-2013, 09:03 AM   #77
theredtape
Damn. Thanks anyway.
Hey everyone ,
Here is my mount set up for my scan gage. It's a combo between a 3d printed bracket , bent sheet metal, and a coat of plasti dip. I only wanted to use it for at a glance info between runs so I made a point of putting it out of my view while driving. It mounts using to bent sheet metal pieces trapped between the dash trim piece. Let me know what you guys think.
I honestly probably could have gotten away with velcoing it right to the dash but I really hate the residue from the Velcro and this way it can't fall down on hot summer days.
Because Racecar.
Old 06-05-2013, 04:01 PM   #78
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
great info, thanks!
smbstyle is offline   Reply With Quote
Old 06-06-2013, 09:03 PM   #79
smbstyle
smbstyle's Avatar
Working code for FR-S/BRZ/86:
Code:
Gauge                          Unit           TXD                  RXF                      RXD      MTH                      Note
Oil temp                       C         07E02101       010702E80324     3008    00010001FFD8    Required FW 4.05 or higher
Oil temp                       F         07E02101       010702E80324     3008    00090005FFD8    Required FW 4.05 or higher
Precise Fuel Level         %         07C02129       046105290000     2808    000100010000    Faster refresh rate
Precise Fuel Level    US Gallons   07C02129       046105290000     2808    052900640000    Faster refresh rate
Precise Fuel Level       Liters      07C02129        046105290000     2808    01F4000A0000    Faster refresh rate
Seat Belt Beep Query               07C021A7        046115A70000     2808    000100010000   C0 for stock, 00 for disable
Seat Belt Beep Disable              07C03BA700    047B15A70000     2008    000100010000   Should return 0000. Replace '00' in the TXD with 'C0' to go back to stock.
Relative Throttle Position      %           07E00145            044185450000         2808     03E800FF0000
Absolute Throttle Position     %           07E00147            044185470000         2808     03E800FF0000
Fuel Pressure                     PSI         07E00123            046105230000         2810     006400450000
Fuel Pressure                    MPa         07E00123            046145230000         2810     000100010000
Attachment 28549 is the list of supported standard (mode 01) PID for 86/BRZ/FR-S. This list is created from the Wiki’PID, and I highlighted the ones that are supported by our cars.
Here is an example of how to make use of the doc I created:
From the Xgauge cansf list, the short Term Fuel Trim Bank 1 has the TXD 07E00106. The 01 (07E00106) is the mode #. The 06 (07E00106) is the PID. Now look at the doc I attached. It shows the PID 06 is supported, which means that xgauge code works on our cars. The PID 07, On the other hand, is not highlighted on the list. That means the Short Term Fuel Trim Bank 2 is not supported.
Thank you Andery for finding the PID and torque’s code for oil temperature. Without him, I don’t think I can get the oil temp for xgauge.
I followed all of the steps, and cannot get the Oil Temp to work? It is just blank. I went through and made sure I had all 4 codes entered correctly, and then double checked again.
Firmware is version 4.12
Any help would be appreciated. Thanks!
Old 06-06-2013, 10:01 PM   #80
smbstyle
smbstyle's Avatar
Ok, update, for some reason the next time I started up the car the OIL temp showed?? Weird.
I did have one question though; what kind of Relative throttle % are you all seeing? The most I will see is 69.0% at WOT. Is that normal?
Old 06-07-2013, 09:34 AM   #81
brillo
Drives: 2013 Firestorm FR-S
I've gotten oil temp working but I can't get air fuel working correctly. Can someone confirm that we can read the wideband?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 06-08-2013, 11:24 PM   #82
dave-
Drives: 86 GT
Got one just to see oil temps on the track and have a digital speedo so everything else is a bonus. Not sure what I did with the seat belt one, didn't get the right code show up but no chimes so problem solved either way.
Code:
Getting 4 digit numbers which appear accurate if you pretend there is a decimal place in the middle. Is that the expected result?
Is it possible to program in distance to empty as a guage? I haven't investigated the trip functions as I want to keep it on the guage screen all the time.
dave- is offline   Reply With Quote
Old 06-08-2013, 11:41 PM   #83
Splat
Drives: FR-S ultramarine
I am looking at oil temp, water temp< ya the frs has one of those but no actual numbers. also, anybody with an auto get a transmission temp ????? That is my biggest concern as I want to check on getting a tranny cooler added if possible. I know when I am pounding this the auto is taking a beating.
Splat is offline   Reply With Quote
Old 06-10-2013, 10:36 PM   #84
pkny
Good catch. Got a typo in the first post. I will correct it later. In the mean time, use the one from post#22.
Found a xgauge code for faster, more accurate and precise fuel level:
Percentage:
TXD 07C02129
RXF 046105290000
RXD 2808
MTH 000100010000
US Gallons:
TXD 07C02129
RXF 046145290000
RXD 2808
MTH 052900640000
Liters:
TXD 07C02129
RXF 046145290000
RXD 2808
MTH 01F4000A0000
You can use the Add-a-Gauge function to add the distance to empty as a gauge.
The Following User Says Thank You to pkny For This Useful Post:
dave- (06-11-2013)
FT-86 low temp THERMOSTAT ft86-UAE Engine, Exhaust, Transmission 52 08-30-2016 03:46 PM
A/C Oil/Water temp gauge Exhaust Scion FR-S / Toyota 86 GT86 General Forum 16 02-07-2013 01:19 PM
Engine oil temp now available in Torque App Yruyur Engine, Exhaust, Transmission 8 02-03-2013 10:52 PM
exterior temp. gauge off? Rayme CANADA 8 01-23-2013 09:06 PM
Simple Oil Temp. Gauge Sportsguy83 Cosmetic Modification (Interior/Exterior/Lighting) 4 01-19-2013 08:25 PM
