Old 06-06-2013, 05:49 PM   #1
FAER
Drives: Silver BRZ
Borg Warner S255-RS .48
Theoretical Bro-Science in coming.....
I currently have this turbo brand new sitting on my desk. So this is why i chose this turbo for the discussion...
This turbo is rated just shy of 500whp at 30psi on the SRT-4's with full spool at 3400... Keep in mind they have a 2.4L.
We have a 2.0L and 1500 more RPM band than that car (just sold my srt after buying the BRZ).
Now, i'm no turbo expert but what i do know is that I plan to reach that 500ish WHP mark sometime in the next few years
(built block blah blah blah).
So with this turbo set up i'm looking at high lag (say 4080rpm full spool [Bro science guess])
That means a few things for me;
1: lots of head room for future mods and such.
2: lag which would help with low end traction... (kinda)
3: more mildly mannered for DD out of boost.
What do you guys think?
5/16/2014 UPDATE:
This is my "build thread."
The car:
2013 Silver Subaru BRZ Limited
The Mods:
Borg Warner S255-RS .48 turbine housing
FA20Club UEL Manifold w/ Recirculated Wastegate dump (Swain tech Coated)
FA20Club 3" DownPipe (Swain tech Coated)
FA20Club 3" Over Pipe
FA20Club 3" Test Pipe
3" Ultimate Racing exhaust (no cats, no resonators)
4 bar Map Sensor
MAC Boost control Solenoid.
P3 Vent gauge
Clutch master FX400
Perrin Motor Mounts
RobiSpec Radiator/Oil Cooler combo
Injector Dynamics 1000cc Injectors
Fullblown Walboro 485 Fuel Pump
Kraftwerks Washer bottle replacement kit
Drift Armor "Driftbar" Crash beam replacement
The above parts (minus exhaust) are not installed...YET
July 5th I'll be picking the car up from D3 Performance Engineering here in Houston with the parts above and following;
D3PE Custom Inter-cooler
D3PE Custom Piping
D3PE Custom Intake
Tuned By Chris @ D3PE
FAER is offline   Reply With Quote
Old 06-06-2013, 06:00 PM   #2
SkullWorks
Drives: SSM LT MT BRZ
I think that a turbo that comes on spool that late would blow...no pun intended.
you will find that you can probably spool it faster with the variable cams and the more efficient head design of the FA20 though.
You can do alot with a good tuner and proper engine management though. I have another project car with a GT2868 (no not the GTX 67) that spools very well and still nets me 450 whp. we use boost by gear to keep 1st and second useable,
Old 06-06-2013, 06:06 PM   #3
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Really depends on what you want to do. Although it will probably take a while to hit full boost, it will probably be making more power in the entire rpm band than most of the "small" turbos people are using around here from the CFM flowing out of that thing. It will just make ALOT more power up top. Sounds pretty cool, do it!
industrial is offline   Reply With Quote
Old 06-06-2013, 07:47 PM   #4
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Just curious, would you happen to have an idea if the spool would be THAT affected? Going from 3400 RPM to 4800 RPM just by going from 2.4L to 2.0L?
Old 06-06-2013, 08:10 PM   #5
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
displacement does have a effect on spool if I'm correct !
edit: sorry i misread, well he stated thats its "bro science" which i assume meant a rough estimate
Old 06-06-2013, 08:11 PM   #6
Sportsguy83
Drives: Limited BRZ
I agree, but I wonder if its THAT big.
Old 06-06-2013, 08:18 PM   #7
SmsAlSuwaidi
Boosted
in the jze world , thats where the 1jze lacked on a huge turbo build, but with the new turbos now spooling isn't that much of an issue *wink wink* gtx
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
Sportsguy83 (06-06-2013)
Old 06-07-2013, 08:22 AM   #8
FAER
Drives: Silver BRZ
4080. Not 4800
The Following User Says Thank You to FAER For This Useful Post:
Sportsguy83 (06-07-2013)
Old 06-07-2013, 08:52 AM   #9
Sportsguy83
Drives: Limited BRZ
Originally Posted by FAER View Post
4080. Not 4800
Oops, in dilsexic
Old 06-07-2013, 09:03 AM   #10
mid_life_crisis
Drives: FR-S 10 #103 AT
Oops, in dilsexic
Did you hear about the dyslexic insomniac agnostic?
He lies awake at night wondering if there is a dog.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
The Following 2 Users Say Thank You to mid_life_crisis For This Useful Post:
mswhong (09-01-2013), PrDarkKnight (06-07-2013)
Old 07-04-2013, 01:13 AM   #11
FAER
Drives: Silver BRZ
This is coming true can't wait to post vids, dyno's and pics.
Old 07-04-2013, 01:20 AM   #12
Toma
Drives: Viper, Mustang, FD RX7, FFR GTM
A few factors, displacement is important though. Stroke is another, cam timing, compression! etc
But the SRT4 can't move around it's camshafts... the BRZ can, and that can be used to improve spool.
Toma is offline   Reply With Quote
Old 07-04-2013, 01:13 PM   #13
Fabron757
Drives: 2013 blue frs m6 BW EFR 7064 Turbo
Do it, im running a Borg warner erf 7064 with no big lag issues. Go drive your car hard and see where your rpms are landing. Im pretty sure not going to land at 3800 rpms. Plus the sound and how smooth these turbos are is out of this world. When on woot your power band is in the higher rpms.
Fabron757 is offline   Reply With Quote
Old 07-04-2013, 01:28 PM   #14
FAER
Drives: Silver BRZ
That's exactly where I want that turbo power in the 4.5k and beyond....
No boost for daily driving but enough to nail your ass to the seat when u press the pedal...
Btw I'll be ripping off your inter cooler design in the future, it's the best I've seen.
Borg Warner 8374 vs Garret GTX35R Z3D Forced Induction 5 02-27-2013 09:27 AM
FR-S work at Best Buy in Warner Robins Bg8780 Southeast 3 02-09-2013 01:29 PM
