Old 02-22-2013, 07:53 PM   #1
Z3D
Borg Warner 8374 vs Garret GTX35R
Hey guys,
I wanted to get some opinions on both of these snails. Obviously both are offered in different trims but they are in roughly the same class. Anyone here ever try either on the FA20 or on other engines?
Borg Warner 8374
Turbine OD 74mm
Compressor OD 83mm
Turbine Housing A/R .83 .92 1.05
Oil and water cooled
T3 and T4 Twin Scroll available
Internal Wastegate AND Blow Off Valve
Garret GTX35R
Turbine OD 68mm
Compressor OD 82.5mm
Turbine Housing A/R .63 .82 1.04
T3 and V Band available
Z3D is offline   Reply With Quote
Old 02-23-2013, 02:49 AM   #2
EZWood
BAMF
EZWood's Avatar
Originally Posted by Z3D View Post
Hey guys,
Borg Warner 8374
Turbine OD 74mm
Compressor OD 83mm
Garret GTX35R
Turbine OD 68mm
If by internally wastegated you mean like a vnt, or vanes that vary their angle in the exhaust side I would go with the Borg warner
Old 02-23-2013, 04:29 AM   #3
2forty
Drives: 2002 rsx type s
From tests I've read the bw aren't as magical as people were hoping. Not to mention price for the turbos.
2forty is offline   Reply With Quote
Old 02-26-2013, 05:12 PM   #4
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
Garrett... simple and nicer.
No replacement for Displacement??? Tell that to the people with a 2JZ.
usptwins is offline   Reply With Quote
Old 02-26-2013, 05:18 PM   #5
XPR Small Block
Drives: Scion Frs
why isnt anyone using the turbonetics gtk series?????
XPR Small Block is offline   Reply With Quote
The Following User Says Thank You to XPR Small Block For This Useful Post:
usptwins (02-27-2013)
Old 02-27-2013, 09:27 AM   #6
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
No he means exactly that: the turbo has a wastegate built into the turbine housing.
You're talking about a variable geometry turbo, which neither of these are.
-Acree
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
FR-S work at Best Buy in Warner Robins Bg8780 Southeast 3 02-09-2013 01:29 PM
