Old 06-05-2013, 07:22 PM   #5279
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
I guess I have experienced similar on a long sweeping turn where I punched going into second. At the time I thought it was the racerom traction control but now starting to wonder.
Is this happening when your on e85 or pump gas?
Sent from my DROID RAZR using Tapatalk 2
Area86 is offline
Old 06-05-2013, 07:43 PM   #5280
Yruyur
Yruyur's Avatar
Unfortunately don't remember as it was a while back. But I know I was on one of the maps that had the rrtc.
Yruyur is offline
Old 06-05-2013, 07:49 PM   #5281
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by Dezoris View Post
Looks like a timing issue:
Wow, just wow.
Calum is offline
Old 06-05-2013, 07:52 PM   #5282
Carwhisperer
Drives: A lot of supercars.
Originally Posted by Calum View Post
Wow, just wow.
You say that a lot bro.
Carwhisperer is offline
Old 06-05-2013, 08:40 PM   #5283
Calum
That Guy
Really, hmm. I don't recall saying it much, but I'll take your word for it.
Calum is offline
Old 06-05-2013, 08:46 PM   #5284
Dezoris
Dezoris's Avatar
Wow, just wow.
Are you saying it as its odd or saying it as, I am a retard?
Dezoris is offline
Old 06-05-2013, 08:53 PM   #5285
Calum
That Guy
Certainly not that you're retarded. More like, I'm sorry and I'm offering my condolences but I didn't really have the right words to express that. Yeah, it was a confusing post. Nevertheless, that sucks man.
Would you mind telling us your setup? Have you changed anything in the PCV system?
Calum is offline
Old 06-05-2013, 11:28 PM   #5286
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
why is your Knock Learn Value at 5 and 4.6 instead of 0.
I checked a few of my e85 logs I'm never at a knock learn value of 0. only at ilde. when on throttle it can be as high as 14.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline
Old 06-05-2013, 11:54 PM   #5287
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
The cut off in 2nd when you punch it was a symptom before I started having misfiring/seal issues with my injectors. In 1st gear during WOT the car would feel like it lost some pep in it. Then shifting into second it would feel like almost nothing until I let off the throttle and got back on it. Just putting this out there.
Ugh. I really hope this isn't the case but thanks for chiming in. I am running the tune that has the injector fix but, from the sound of it, it may have come too late. I'll have to investigate that thread to see how people are diagnosing the issue.
cobrabyte is offline
Old 06-06-2013, 04:34 AM   #5288
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Need some assistance.
Toyota SA have loaded the new 001 sofware upgrade to my vehicle a few months back. I have a month ago loaded the STG 1 tune, which is based on the old software.
If I flash my base ROM file which is the upgraded software back, would Toyota be able to pick up I have installed a Tune.
recalls are happening and Toyota are verifying upgrade software is installed while servicing.
Thanks
Ryan86 is offline
Old 06-06-2013, 07:52 AM   #5289
xjohnx
Grip>Slip
xjohnx's Avatar
Thanks
As long as your base rom is the most up to date copy, you will be fine at the dealer level.
Curious though, you said recalls are happening. Where did you find this info? Can you share more details?
xjohnx is offline
Old 06-06-2013, 08:11 AM   #5290
Ryan86
Road Warrior
Ryan86's Avatar
Thanks for the info. So Toyota cant pick up in anyway that I have been running a different ROM file or running over the OEM rev limitor?
The software up date is my base ROM, I sent John, which Im sure is the base of his new release or the same upgrade being applied to his new release.
any 86 prior to 31 January 2013 in SA, is having the software upgrade done, whether Toyota SA recalls you or they simply upgrade during the next service. Details of upgrade is in the injector issue thread, this info comes from us in SA.
http://www.ft86club.com/forums/showp...2&postcount=65
Ryan86 is offline
Old 06-06-2013, 10:05 AM   #5291
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Very interesting. Your tuner might be using that to add in the extra timing that E85 loves. As long as the value is positive then it means the ECU is adding more timing than the timing tables call for.
King Tut is offline
Old 06-06-2013, 10:54 AM   #5292
feldy
feldy's Avatar
maybe. I'm in pump gas now maybe Ill do some logs today and see how the car is behaving in those tunes.
feldy is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
