Old 06-05-2013, 02:23 PM   #5265
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
When I Run e85 its mostly for race weekend. I run with it for the week getting out what ever gas was left. fill enough e85 to last two days of racing. Then I just empty it out and re-fill with pump gas. The only fuel starvation issue I had was when I was draining the tank and went to far and got lean codes for running out of e85 fuel. Since I have the fa20club tune I don't have to re-flash for it. Since e85 is on my map 3 and 4.
John pulled that for his guys for safety issues which I agree with. As I have started on the wrong map a few times before. Its scary for sure.
Until more people pull there fuel pumps and see garbage in it. I'm not all that worried.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline
Old 06-05-2013, 02:30 PM   #5266
Dezoris
Dezoris's Avatar
Originally Posted by cobrabyte View Post
Anyone having any fuel cutout issues? I submitted a trouble ticket regarding this but haven't heard anything back...
I am running E85 and yesterday I was running through the gears coming off a stop light. I was in first gear and punched it after I was already going about 5MPH. It climbed nicely through first and I shifted into second. I mash the gas and .. nothing. It's like there was zero fuel getting to the motor. A complete cutout. I let off the gas pedal and the power comes back. Very odd. I didn't squeal the wheels or see a TC light (TC was off anyways).
In any case, was curious if anyone else was having similar issues. I haven't been able to replicate the issue so, perhaps it was a gremlin.
I have been having this exact issue, however I am supercharged and perrin tuned 93 octane.
Revved through first to 7100, shifted to second mash throttle and complete fuel cut for a milisecond, power comes back very weak with knock shortly after.
Have a log of it as well.
Dezoris is offline
Old 06-05-2013, 04:08 PM   #5267
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
That's pretty much what happened to me. Surprised the hell out of me. Of course, I have not been able to make it happen again while logging. I'd rather get it sorted out before having it crop up at the wrong time (ie. the track). Thanks for sharing!
cobrabyte is offline
Old 06-05-2013, 04:33 PM   #5268
Dezoris
Dezoris's Avatar
I have had it happen about 3-4 times now. I had it repeat on the same stretch of road. What type of shifting speed and force did you use from 1st to 2nd?
For me I am always conservative, slower shift, clutch floored don't know if that triggers it.
Dezoris is offline
Old 06-05-2013, 04:56 PM   #5269
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Can you post it? I haven't ever noticed this on my car. Not sure I would notice it for a milisecond though.
King Tut is offline
Old 06-05-2013, 04:57 PM   #5270
Dezoris
Dezoris's Avatar
Looks like a timing issue:
Dezoris is offline
The Following 2 Users Say Thank You to Dezoris For This Useful Post:
Lonewolf (06-05-2013), tripjammer (06-06-2013)
Old 06-05-2013, 04:58 PM   #5271
cobrabyte
cobrabyte's Avatar
My incident was definitely longer than a millisecond. I had to let off the gas pedal and get back on for it to get past the stutter.
Old 06-05-2013, 05:01 PM   #5272
cobrabyte
cobrabyte's Avatar
When driving in a spirited manner, I'll hammer shifts home. I'm not one to miss shifts or grind gears. I didn't miss this shift either. It was set perfectly and, as soon as I got on the gas for second gear, the engine fueling/timing cut out. It felt like a parachute had been deployed because my senses were expecting more acceleration.
Old 06-05-2013, 05:06 PM   #5273
feldy
feldy's Avatar
Quick side topic. How correct is the ecutek afr logs?
feldy is offline
Old 06-05-2013, 05:08 PM   #5274
King Tut
NASA SpecE30 Racer
King Tut's Avatar
You are right that timing jump from 20 degrees to 1 degree and back to 20 degrees will definitely be felt. Things that bother me are that you are definitely in the 10s in AFR and why is your Knock Learn Value at 5 and 4.6 instead of 0. That Knock Correction of -4.2 when you let off the throttle at 6800 RPM is also interesting. I occasionally get knock when letting off after a 3rd gear pull, but never that high a number.
It is also weird that your accelerator position is showing 100 percent while your throttle position shows 30.2 percent. I don't think I have ever noticed that before.
King Tut is offline
Old 06-05-2013, 05:13 PM   #5275
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I can make a plot of my AEM wideband versus the OEM sensor if you would like.
King Tut is offline
pheoxs (06-06-2013)
Old 06-05-2013, 05:18 PM   #5276
Dezoris
Dezoris's Avatar
It's very similar though, like hitting a brick wall, granted I didnt lift here but in past events I have because its a WTF just happened moment and after the lift it comes back to life.
I won't even pretend to really know the how or why, but it's easy to see the problem. The knock learn etc. no clue.
Dezoris is offline
Old 06-05-2013, 05:54 PM   #5277
Yruyur
Yruyur's Avatar
I guess I have experienced similar on a long sweeping turn where I punched going into second. At the time I thought it was the racerom traction control but now starting to wonder.
Yruyur is offline
Old 06-05-2013, 07:08 PM   #5278
Carwhisperer
Drives: A lot of supercars.
The cut off in 2nd when you punch it was a symptom before I started having misfiring/seal issues with my injectors. In 1st gear during WOT the car would feel like it lost some pep in it. Then shifting into second it would feel like almost nothing until I let off the throttle and got back on it. Just putting this out there.
Carwhisperer is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
