Old 06-04-2013, 09:59 AM   #57
Foobar
SLO NO MO
Foobar's Avatar
@Adeets
Are you looking for a Visconti stage 1+ dyno? The only one I've seen is skatery's used with E85.
There are a few Visconti stage 1 dynos floating around. including the one on his sale thread.
Old 06-04-2013, 10:04 AM   #58
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Originally Posted by nelsmar View Post
I don't want to start another vendor war in here, so lets keep it to a minimal. But this is making me even more nervous having him tune my car. I tried to get a refund and was denied, I know another local who did a charge back ugh. I want to use another tuner that I can actually trust! I started searching and i found this guy's dyno. And I swear i saw more but maybe not?
http://www.ft86club.com/forums/showp...9&postcount=71
There's no reason to fear @Visconti, he reminds me of a fanuc robot, as long as you follow his rules, and give him plenty of time to do any change you request, I'm sure you would be pretty surprised, there is a new FAQ in his vortech blowout sale, if you follow it step by step, I'm sure you will be satisfied. Side note when dealing with a fanuc, it's not about what you want it to do, it's about finding out what it wants to do.
I'm sure visconti does great work, it's just we didn't see eye to eye and that's why I didn't go with him. It's more of an availibity issue over a doubt in his tunes.
So he's flat lining ish as well... Hmmmm strange and jagged.
Fucking dip.
Also dyno dynamics I thought were known for giving higher numbers then all others, due to the lack of wheels... Am I incorrect in thinking mustang < dyno jets (American standard) < dyno dynamics?
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 06-04-2013, 10:56 AM   #59
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Originally Posted by Adeets View Post
BTW this is all done with WAWA 92 pump gas.
From what me and mike saw, it needs it, if you want to use all the air suppled by the stock blower you need to make the DI and port system 100% duty cycle and then some. What were seeing with the flat liners is them trying to stay at 90-95% duty cycle, with mikes tune there is 0 knock and 0 knock correction.
I'm hoping that with the fuel pump/injectors I can make my HP/tq plot line straight and that should hopefully get me to around 270 whp on stock blower.
In the end this is all speculation until I can provide a dyno with the new pump/injectors, but I'm wondering why no other tuners are running into this.
(Upgrade is set to the 10th, and Dynos will follow shortly, have to remember that there's butt dyno tuning to get the AFR correct then after that there's dyno tuning to make the power.)
Due note that my kit is a visconti stg1+ kit so the fuel pump injector combo came with my kit, I just went with another tuner due to issues between me and @Visconti, since I don't believe anyone has dyno'd one of his kits he may, since there's no proof to see otherwise, ran into this issue and that's why he supplied the pump/injectors. If anyone finds a visconti vortech dyno I would LOVE to see it. (Please post with an @Adeets)
Keeping @2forme in the loop.
If you have the stage 1+ kit, are you using the stock sized pulley or the smaller sized pulley?
@Visconti can you comment if we need to consider upgrading the fuel system on just the stage 1 (stock pulley) vortech setup? Thanks!
pheoxs is offline   Reply With Quote
Old 06-04-2013, 11:22 AM   #60
Adeets
OEDC
Adeets's Avatar
Stg1+ is stock pully, 8.5 psi at redline (7400)
My BRZ FI Build
Old 06-04-2013, 11:31 AM   #61
Adeets
OEDC
Adeets's Avatar
Are there any turbos running 8.5 psi, after pump/injectors/tune I'd like to compare it to an 8.5 psi turbo on pump gas to see how much the supercharger actually loses from being on the crank.
My BRZ FI Build
Old 06-04-2013, 11:33 AM   #62
pheoxs
Stage 1+ came with the smaller pulley, fuel pump, injectors, and 3 bar map sensor according to Visconti's market place thread that is why I'm confused.
Old 06-04-2013, 11:44 AM   #63
Adeets
OEDC
Adeets's Avatar
As someone who bought it, negative, no smaller pully came with the system. During tuning I was reading between 8.2 and 8.4 at the redline except for 1 run at 8.7 but that was at 7700
My BRZ FI Build
Old 06-04-2013, 12:07 PM   #64
nelsmar
It was supposed to come with one. I have pm's from visconti about pricing for the pulley outside of the kit. He had a custom pulley (i think it was the one from the old kit) that pushed something like 12psi or so? It was ideally for high octane / e85. It was supposed to ship with your ecutek kit.
This is from a PM conversation between me and Visconti
Originally Posted by Visconti
EcuTek w/ License is $xxx
Map Sensor $xxx
Forced Induction Tune $xxx
Visconti-spec High Boost Pulley - $xxx
500cc Plug 'n Play Injectors - $xxx
290LPH Fuel Pump - $xxx
Hope that helps
My flickr - Canibeat
Local magazine scout
Old 06-04-2013, 12:14 PM   #65
Adeets
OEDC
Adeets's Avatar
Yeah if there's truth to that I'll question visconti, it would be another flaw I've found with him being overburdened, with him denying refunds for kits not shipped or shipped with wrong parts, or dongles not registered or tunes that are corrupted... He's like a walking poster board for a BBB case.
My BRZ FI Build
Old 06-04-2013, 12:27 PM   #66
Dezoris
Dezoris's Avatar
One of the reasons I did not chose him for my build was not for lack of experience it was just because I think they guy is buried. As the most visible tuner on here for the most part he also has the most work scheduled. That can mean two things, either you have to wait or he will be taking less time of tunes and customer service.
But I also don't like these bleeding edge tuners and tunes either. What sells for most people is higher HP dyno plots. There is a hell of a lot more to it than that.
The Following 2 Users Say Thank You to Dezoris For This Useful Post:
2forme (06-04-2013), Adeets (06-04-2013)
Old 06-04-2013, 12:34 PM   #67
2forme
IIRC, turbos run out of safe fueling on the stock setup after like 7psi.
I believe most kits around 8psi, were making north of 275.
The Following User Says Thank You to 2forme For This Useful Post:
Adeets (06-04-2013)
Old 06-04-2013, 12:53 PM   #68
Adeets
OEDC
Adeets's Avatar
So pretty much they are running into what I'm having issues with, to stay safe I stopped the tuning at 263, there's more in this kit, but I'm not ok with blowing my motor for another 15hp when I could fix the fueling then come back and try again.
My BRZ FI Build
Old 06-04-2013, 01:04 PM   #69
2forme
I don't think you'd be able to match a turbo's output with a centri kit, psi for psi. They just aren't as efficient.
SmsAlSuwaidi (06-04-2013)
Old 06-04-2013, 01:09 PM   #70
Raven604
They're a lot better then they used to be that's for sure
Raven604 is offline   Reply With Quote
STX Rules and Setup Questions Scooby South Tracking / Autocross / HPDE / Drifting 3914 07-18-2023 04:16 AM
Questions and Discussion on Vortech Supercharging Systems Brian@Vortech Forced Induction 1462 01-27-2017 02:05 PM
Vortech Offical Owner Thread cjsporl1996 Forced Induction 2 03-27-2014 12:50 AM
Who to tune Vortech setup? pheoxs Forced Induction 18 02-20-2014 02:58 AM
Sprintex or Vortech, which setup has more potential? Turbowned Forced Induction 328 09-14-2013 11:09 AM
