Old 06-01-2013, 03:05 PM   #71
FullTuneZN6
Novice Drifter
FullTuneZN6's Avatar
Drives: 2013 Asphalt FR-S
Originally Posted by NorseLegend View Post
Out of curiosity, and to see if my math is right, speculatively, if you're making 300 WHP, then you're making about 350 HP at the flywheel/crank (those two are pretty much synonymous right?) with about 15% parasitic loss, correct?
its all an estimation, but typically ive seen 17% drivetrain loss used for FR platforms and 15% used for FF, which in this case would be about 360 @ the crank approx. of course
FullTuneZN6 is offline   Reply With Quote
The Following User Says Thank You to FullTuneZN6 For This Useful Post:
NorseLegend (06-01-2013)
Old 06-13-2013, 04:54 PM   #72
swift996
swift996's Avatar
With several kits on members cars already can we add a section linking threads of journals with members running the kits?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following User Says Thank You to swift996 For This Useful Post:
SkAsphalt (11-27-2013)
Old 06-24-2013, 09:31 PM   #73
jamesm
might want to add revworks to the list.
Old 06-24-2013, 10:54 PM   #74
subatoy
subatoy's Avatar
Drives: subatoy
searched but couldn't find them. theres one guy who's reviewing it but not the manufacturer's thread.
link?
subatoy is offline   Reply With Quote
Old 06-24-2013, 11:09 PM   #75
jamesm
link?
http://www.ft86club.com/forums/showthread.php?t=38993
Old 06-25-2013, 10:21 AM   #76
subatoy
subatoy's Avatar
Drives: subatoy
added! thanks.
The Following User Says Thank You to subatoy For This Useful Post:
jamesm (06-25-2013)
Old 07-03-2013, 12:19 AM   #77
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
Update plz
sosick is offline   Reply With Quote
The Following User Says Thank You to sosick For This Useful Post:
MadFRS (08-21-2013)
Old 08-29-2013, 02:54 PM   #78
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
STS single... and twin turbo
http://ststurbo.com/brz/
from fb:
Size:  75.7 KBName:  ImageUploadedByTapatalk1377798784.452775.jpg
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
Old 10-08-2013, 11:48 PM   #79
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
What the hell is that?
Sent from my SGH-M919 using Tapatalk now Free
kombatlion is offline   Reply With Quote
Old 10-09-2013, 12:20 AM   #80
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
A Remote mount turbo setup.
+ Doesn't crowd engine bay.
+ A bit less heat build up in the bay.
+ Weight in the back for better balance.
+ Less passenger noise.
+ Usually quicker to install.
+ Usually cheaper w/no need to turbo specific custom exhaust.
+ Usually cools down a lot faster and may not need a turbo timer.
- Move volume equally slightly slower throttle response (& more lag.)
- Longer the pipe usually means lower boost.
- Speed bump/pothole nightmare on stock/lowered cars.
- Easily prone to theft in my area.
never owned a remote setup but a friend while I was at school had a set up on his 05 GTO.
The Following User Says Thank You to Kiske For This Useful Post:
kombatlion (10-09-2013)
Old 10-09-2013, 11:24 AM   #81
jshadeck
jshadeck's Avatar
Just my .02$ from what ive heard about these
The rear mounts dont need intercoolers, and therefor ive been told the boost and lag are very comparable to a bay mounted turbo w a fmic
jshadeck is offline   Reply With Quote
Old 10-09-2013, 11:53 AM   #82
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
You forgot another couple minuses in that you have to run oil lines all the way to the rear of the car and I am assuming it uses an inline pump in the return line to get the oil back to the pan.
Old 10-09-2013, 11:43 PM   #83
nonicname returns
Drives: 4 wheels
I remember wanting to use this kit on my 370Z until someone posted an article explaining how this set up creates some nasty back pressure.
I can't remember the details.this kit is pretty cheap and it's like having a performance exhaust already in the set up.
if it were so good it would make you wonder why more people don't use it.
nonicname returns is offline   Reply With Quote
Old 10-21-2013, 03:27 PM   #84
SilverTipp
SilverTipp's Avatar
Drives: Silver
I'm new to the FR-S scene. I'm trying to figure out (based on these options) ... the prices, how long they've been out there, different stages/requirements, users experience, and the whp/wtq numbers they claim.
Is there anywhere that helps with this, or should I just get started on my days of homework on the subject?
Thanks!
SilverTipp is offline   Reply With Quote
FR-S and BRZ Exhaust Compilation Thread Spd229 Engine, Exhaust, Transmission 663 07-08-2025 10:48 AM
AVO turbo kit for BRZ - initial build thread AVOturboworld Forced Induction 3109 12-01-2019 04:55 PM
Phil's Accelerated Performance Turbo Auto FRS Thread Philly Forced Induction 131 05-14-2013 11:23 AM
TSI offers HIDGUY HID kits and LED lighing! $95 kits SHIPPED! We won't be beat! Lisa@TrueStreetIndustries Exterior Parts - Lighting 129 01-18-2013 09:57 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 07:20 PM
