Old 05-28-2013, 12:07 PM   #85
mid_life_crisis
Drives: FR-S 10 #103 AT
That obdII splitter would also be useful for those of us with advanced radar detectors that plug into the port.
The suggestion someone else made about a single din unit that could display multiple readings simultaneously sounds like a great idea seeing how many people are ripping the radios out of their cars practically the day they get them.
Probably a limited market, but something that could use the camera input to display a couple of gauges on a double din's display would be pretty sweet.
mid_life_crisis is offline
Old 05-28-2013, 01:48 PM   #86
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
Add me to the growing line of gauge groupies..
CO>CA Cartel
Norkoastal is offline
Old 05-28-2013, 09:26 PM   #87
TemeCal
Drives: 86
I'd be in, if there's a group buy.
TemeCal is offline
Old 05-28-2013, 09:34 PM   #88
smellslikecurry
Im in too.
smellslikecurry is offline
Old 05-30-2013, 10:19 AM   #89
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Bump for updates.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline
Old 05-30-2013, 05:58 PM   #90
cb7tuner
Drives: 2013 whiteout FR-S
Got my beta testing version in the mail tuesday. Gauge is top notch. Everything works as it should and uses all OEM parts for the vent. Seriously installed in like 5 minutes.
Before...
After....
cb7tuner is offline
The Following 8 Users Say Thank You to cb7tuner For This Useful Post:
armythug (06-01-2013), djdnz (06-03-2013), lbroskee (05-30-2013), RedAlert (05-30-2013), shiro (11-15-2013), Sportsguy83 (05-30-2013), TemeCal (05-30-2013), velin86 (05-30-2013)
Old 05-30-2013, 06:01 PM   #91
velin86
velin86's Avatar
Drives: 2013 Raven FRS 6MT
looks great!
velin86 is offline
Old 05-30-2013, 06:02 PM   #92
TemeCal
Drives: 86
@cb7tuner
Thanks for the info and pix. Does oil temp work? How did you route the wiring? Did you have to drill any holes into the AC duct to feed the lines?
TemeCal is offline
The Following User Says Thank You to TemeCal For This Useful Post:
Old 05-30-2013, 06:18 PM   #93
cb7tuner
Yep the oil temp works great, that's the main thing I've been monitoring. They also integrated air fuel ratio into it as well which is dead on with my aem wideband. No drilling was nessecary at all. The wiring to the display on the gauge is a very thin ribbon cable. It slips right inbetween where the vent meets the ducting.the ribbon cable then just plugs into the black box (I guess the brains of the gauge), and from there has a thin obd2 cable to plug into the diag port. Very simple and clean install. Also has a seperate wire for diming, but I did not connect it because the light output matches the gauge cluster perfectly.
Here's a list of everything it can display...
Battery voltage, boost/vaccum, coolant temp, oil temp, intake air temp, exhaust gas temp, air fuel ratio, vehicle speed, engine RPMS with adjustable shift light, 0-60 times, throttle percentage, ignition timing, it will also scan,read and erase codes.
cb7tuner is offline
The Following 6 Users Say Thank You to cb7tuner For This Useful Post:
Deepseadiver (06-03-2013), djdnz (06-03-2013), jamesm (05-30-2013), lbroskee (05-30-2013), RedAlert (05-30-2013), TemeCal (05-30-2013)
Old 05-30-2013, 06:19 PM   #94
cb7tuner
cb7tuner is offline
Old 05-30-2013, 06:21 PM   #95
TemeCal
Drives: 86
Awesome info - thanks!!!! This is exactly what I was hoping to hear. I appreciate your input.
Tony @FA20Club.com -
Let's get this group buy started!!!
TemeCal is offline
Old 05-30-2013, 06:30 PM   #96
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Need this now! The only thing it doesn't do is 1/4 mile yet still so perfect. So jealous
lbroskee is offline
Old 05-30-2013, 06:39 PM   #97
cb7tuner
Again this is the beta version so I'm not sure if they plan to change anything, but I can't imagine anything they could change for the better. But I will definately keep you guys and p3cars updated if any bugs come up
cb7tuner is offline
The Following 2 Users Say Thank You to cb7tuner For This Useful Post:
lbroskee (05-30-2013), TemeCal (05-30-2013)
Old 05-30-2013, 07:00 PM   #98
jamesm
I want one. Now. Just a couple questions: do you need to add a sensor for egt? I assume you do. Also, if you're adding an aftermarket 0-5v, how do you scale the output? I.e. does it just output the voltage or can I somehow program in a curve to get something like '0-200psi' from '0-5v'? Also, is the stock afr still limited to 11:1 or whatever on the rich side?
Awesome work!
jamesm is offline
gauge, p3cars
LHD 3-meter gauge-pod? TuxedoCartman Cosmetic Modification (Interior/Exterior/Lighting) 27 02-11-2015 06:19 PM
Dash Cam + HU + Reverse Integration JDMSushi Electronics | Audio | NAV | Infotainment 0 12-04-2012 06:47 PM
iPod®/USB Integration in the glove box? 8987846 Electronics | Audio | NAV | Infotainment 26 12-04-2012 12:45 AM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 04:29 PM
Gauge Sweep? himbo BRZ First-Gen (2012+) — General Topics 17 12-12-2011 11:39 AM
