Old 05-30-2013, 01:40 PM   #57
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Speed sensitive chime...wow that's some 80's/90's JDM shit right there....
In fact the only time I've ever heard one is in an anime lol....
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 05-30-2013, 01:48 PM   #58
Yruyur
Yruyur's Avatar
Do you mean the seat belt chime?
Old 05-30-2013, 01:56 PM   #59
kanundrum
Drives: 2013 Whiteout FR-S
Saab was a big fan of this and made it standard on most of their cars haha
Old 06-02-2013, 02:50 AM   #60
RevoG
RevoG's Avatar
Drives: Hot Lava 86 MT
No speed chime. Even my GMC Sierra does it, but the truck hits 120km.h, gives you one "ding" and that is it. My 86 hits 120km/h and it starts "ding, ding, ding" sounds like the seatbelt chime but is for speed.
Will drive you batty if you consider the legal posted speed limit between Dubai and Abu Dhabi is 140km/h....
JR Supercharger, JR RS Pulley, JR Oil cooler, JDL UEL header, Dual resonated 3" JDL Overpipe Front pipe, Perrin 3" resonated cat back exhaust, Upgraded Koyorad radiator, ECUTek tune, Enkei RS05RR 18x9.5, Bridgestone RE003 265/35/18, KW V3 Coilovers, Valenti sequential taillights, Kartboy short shifter kit
RevoG is offline   Reply With Quote
Old 06-02-2013, 09:40 AM   #61
Mikem53
Drives: FR-S 6MT
Originally Posted by RevoG View Post
Have a quick question before I order... Need to know if I can use this to disable the chime I get when I hit 120km/h. It drives me nuts and the dealer says they can't.
Anyone know if I can?
I'm running the latest software for techstream and did not see that option..
I'm running the US spec , so it might possibly be available on the Europe settings.. ?
Mikem53 is offline   Reply With Quote
Old 06-03-2013, 04:08 AM   #62
RevoG
RevoG's Avatar
Is it possible to change the region?
Old 06-03-2013, 07:51 AM   #63
Mikem53
Drives: FR-S 6MT
Yes.. I believe so.. The other options are listed to select.. I just didn't try..
Old 06-03-2013, 08:03 AM   #64
Ingen
Drives: Ultramarine FR-S 6MT
Can this thing re-program the throttle sensitivity? I would like it less sensitive on initial tip-in (more progressive, as in don't go from 10 to 25% open just b/c I touched the pedal) and have it speed up at the end (get closer to 100% at floored)?
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 06-03-2013, 08:12 AM   #65
xjohnx
Grip>Slip
xjohnx's Avatar
Nope, unfortunately not. If you have an ECUtek reflash your tuner MAY be able to accomodate that request.
Sensisnow (06-04-2013)
Old 06-03-2013, 08:39 AM   #66
RevoG
RevoG's Avatar
Thanks, I have ordered the cable already but just wanted to check. I know it is possible to remove the chime but my tuner told me he can't remove it. Hoping that this cable can...
Old 06-23-2013, 03:43 AM   #67
RevoG
RevoG's Avatar
Ok, cable arrived and messed around last night. Can't find anything about the speed sensitivity or the speed chime/buzzer.
I need help here since I know you guys in the states do not have this problem. Not sure about Aus or South Africa or Europe for that matter.
It is driving me up a wall!!!!
Old 06-23-2013, 12:26 PM   #68
FiRStsc10n
Canadian FR-S Member
FiRStsc10n's Avatar
Drives: FR-S '10 Series'
Originally Posted by DriftEightSix View Post
Why doesn't mine show these options!?
Please someone help i really want the lights to stay on!
@DriftEightSix Did you ever figure this out? The US 10 Series FR-S/86 is getting the LED/HID and they turn off the DRL LED at night. Wondering if you found a way to keep them on.
FiRStsc10n is offline   Reply With Quote
The Following User Says Thank You to FiRStsc10n For This Useful Post:
mountainside (06-28-2013)
Old 06-23-2013, 02:24 PM   #69
jamesm
i've been using techstream to collect logs after my turbo installation, and it's worked well. the response time is pretty decent without a bunch of PIDS selected, but still slower than an actual logger. very useable, though.
The Following User Says Thank You to jamesm For This Useful Post:
Yruyur (06-23-2013)
Old 06-24-2013, 05:51 AM   #70
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
no sadly .
Hopefully an ecu upgrade will fix it.
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Toyota Techstream xjohnx Engine, Exhaust, Transmission 206 08-20-2023 04:01 PM
TechStream TIS - No work FRSFirestorm Engine, Exhaust, Transmission 19 07-10-2014 03:14 AM
Techstream/ECU customizations phanguy Northern California 60 10-05-2013 11:12 PM
Techstream ECU Options mrjester Electronics | Audio | NAV | Infotainment 10 03-18-2013 10:24 AM
86 TRD Customize Concept JDMrolla Scion FR-S / Toyota 86 GT86 General Forum 6 01-11-2013 12:31 PM
