#1 | |||||||
Has anyone had a warranty claim denied? Seized engine! Pics of teardown added 6/5
Background info:
The CSG BRZ suffered from the injector seal failure that is frequently mentioned. Here are some threads regarding that. http://www.ft86club.com/forums/showthread.php?t=36129 http://www.m3post.com/forums/showpos...73&postcount=5 [ame="http://www.youtube.com/watch?feature=player_embedded&v=VnFa2IvNs9g"]Frs popping noise when given throttle free revving or cruising, rolling on throttle to pass. - YouTube[/ame] http://www.ft86club.com/forums/showt...light=warranty http://www.ft86club.com/forums/showt...light=warranty We were getting the misfire, but had no CEL until the was dead. The symptoms showed up in the following order: - Misfire/popping - Rough idle - Unable to hold idle, misfiring on idle dip - Siezed/dead engine (no holes in engine or anything...) This is not the first time we've had the misfire/popping. We've actually had a full engine replacement last year when the original engine had the same initial symptom. At that time, we had taken the car in to Irvine Subaru; they were very accommodating of the unusual symptom on our car. This time around, Palm Springs Subaru (Desert Subaru?) was the closest dealer, and were told over the phone that we would need a CEL before we came in to avoid a diagnostic fee that would be need to paid out of pocket. They were unwilling to diagnose the symptom, even though it was thoroughly explained over the phone. After the engine died, we had the car towed back to our original dealer, Irvine Subaru. They are, of course, at the mercy of the tech line, and per Subaru of America, they asked for a service record on our car, which was provided. They then proceeded to take off the oil pan per Subaru's instructions, and at that point, we were informed that there was "metal all over the place" and that the engine would not be warrantied due to track use. Contact with Subaru of America was initiated, and the exchange was unfortunately unproductive. In short, they are denying us warranty coverage because the car was "used for racing". At this point, I'd like to point out Subaru's marketing materials. http://www.media.subaru.com/newsrele...id=190&mid=127 Quote:
Is our car driven hard? Most certainly. Do we track it? Of course! Have we done anything to alter the parameters of the drivetrain? Absolutely not. We're using the car as designed, at least, according to their press materials. Quote:
*edit* Pics of a repair order on a FR-S that had the same problem ![]() [IMG]http://i23.photobucket.com/albums/b395/nismo350z/Scion%20FRS/250396D5-7246-48AD-89FB-***E27D2B313-1032-00000132D6BCC474_zps686e4a0a.png[/IMG] Pics of damaged Injectors/seals from another car ![]() Quick update. Apparently our cats are both destroyed. Now what could cause that....? I'll be dropping by the dealer on Monday to get more pictures of the additional teardown. Someone else at Subaru of America (not Bill, the rep I was talking to) authorized more teardown. ![]() ![]() *edit* More damaged injectors from another car ![]() ![]() ![]() ![]() *edit* It seems one cat MELTED a bit (has a pretty good sized "dent" in it, but it's smooth), and the other cat is falling apart. Pics from teardown Engine from the bottom. Connecting rod on cyl 2 has seen some heat... ![]() Engine from the front ![]() Cylinders 2 and 4 ![]() Damaged collar (next 3 photos are on the same "pair" of injectors) ![]() Collar completely gone and injector... scorched? ![]() Another angle ![]() Other two injectors. This one is a bit damaged as well ![]() ![]() ![]() ![]() Oil pan... ![]() *edit 8/22/13* More problems in japan http://minkara.carview.co.jp/en/user...blog/30522262/ (use google translate) Last edited by CSG Mike; 08-22-2013 at 07:26 PM. |
| The Following 8 Users Say Thank You to CSG Mike For This Useful Post: | autobrz (05-31-2013), Bristecom (06-06-2013), chanomatik (07-17-2013), Koj (09-30-2016), leon78 (05-29-2013), Porsche (05-29-2013), RYU (06-07-2013), track_warrior (06-07-2013) |
#2 |
Drives: Moped
***DISCLAIMER: This post is in no way, shape, or form legal advice or counsel.
I figured a public discussion of some issues might be of some benefit to the members here. CSG~ 1) If the problem which ultimately caused your engine to seize is later found to be a design/manufacture defect or flaw, then your position is suddenly much stronger here (worth mentioning since Toyota has attempted to remedy certain issues with the FA20 via the latest tsb regarding engine software/calibration). The problem is proving the cause (Magnusson-Moss comes into play here) of the engine seizure with respect to any intervening/superceding factors such as your "spirited driving." So was the cause of the engine failure your driving, the modified suspension and tire components, or the potential design/manufacture defect (factory tune, injector parts and functioning)? That is the major question here. 2) The fact that Subaru's press/marketing materials tout and encourage performance use of the BRZ (despite their somewhat contradictory warranty and user manual statements) is a potential avenue to be explored as well. In a sense, Subaru is marketing the product one way, and then refusing to honor a "reasonable" if not intended use of a sports coupe. 3) The fact that Subaru previously replaced your motor under warranty after similar driving conditions may come into play as well. Was this move an act of "good will" on behalf of Subaru, a waiver and acceptance of your spirited use of the vehicle, or was it an indirect concession that there are unresolved issues with the FA20? 4) As you said, another issue worth noting is that the drivetrain was stock. Now if you had an intake or aftermarket tune (which can cause a lean condition) then I can see Subaru's justification for denial of warranty coverage of the motor. In this case, the fact that the motor was stock (and I presume properly maintained) works in your favor. ***So what to do now...any combo of the three depending on your decision: 1) Seek counsel from an attorney who specializes in warranty/contract or automotive claims. Further investigation of the cause of the engine seizure will likely be necessary here and will involve considerable expense. 2) File a safety complaint with the NHTSA since having an engine seize during operation is a safety concern. 3) Spread word of this problem using the power of the internet (particularly Autoblog and Jalopnik). Last edited by Lonewolf; 05-29-2013 at 07:29 PM. |
| The Following 13 Users Say Thank You to Lonewolf For This Useful Post: | 20valvewynn83 (05-30-2013), ATL BRZ (05-29-2013), autobrz (05-31-2013), Batman (05-29-2013), heeltoe86 (06-01-2013), invzabomaster (07-31-2013), Marrk (05-30-2013), R2RO (07-29-2013), ravenblackfrs (05-30-2013), Ryeong86 (05-31-2013), SkullWorks (05-29-2013), sosick (08-07-2013), strat61caster (05-29-2013) |
#3 |
Subaru refuses to authorize further teardown to investigate the ultimate cause of the failure. They've been asked several times, and refuse on the basis that the "vehicle was raced".
#4 |
The Answer
Drives: Mazda 2
Good luck dude, this is a tough one.
#5 |
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
Keep in mind as long as you own the car/motor, even though Subaru might refuse to authorize further teardown to investigate, you can.
#6 | |
| The Following User Says Thank You to Hanakuso For This Useful Post: | Yruyur (05-29-2013) |
#7 |
Grey Wind
Drives: FR-S 10 Series #0065
This is a very interesting thread. I feel badly for anyone affected by corporate greed, and by a car manufacturer not stepping up and doing the right thing. I had an 8 month old car turn into a fireball in a parking lot a few years ago. The engine wasn't even running. It took 2 years before the manufacturer admitted that there was a "problem" then sent out recall letters to over 230,000 owners telling them not to park their cars in their garages until they could have their vehicles inspected because they might catch fire.
I really hope that engine issue gets resolved. If it happened to one person, that is one too many as far as I am concerned. Look into getting a lawyer-- that is what I did. It is difficult to take on "the man" by yourself. Also send registered letters to head office, CEO, company president etc. When my car exploded, I also mentioned I would be showing up at random dealerships and standing on the sidewalk with poster sized pictures of my burn't car. Rattle some chains-- don't take no for an answer. From experience-- they are hiding behind a lame answer and refusing to step up to the plate because there may be implications (larger than we can see) regarding the longevity and performance of the engine. It's easier for them to say that it isn't their fault, then pass the blame onto you than admit a problem and issue a recall once it happens to a dozen or so other people. I will be following this thread. Best of luck!
#8 |
#9 |
Drives: 13 BRZ Limited & 16 Hyperblue
What worries me is that it happened to him twice.
Has anyone else experienced this? What can we do to prevent this? Is it a common problem? |
#10 | |
The initial symptoms are widespread. see: http://www.ft86club.com/forums/showthread.php?t=36008 |
#11 |
Drives: 2013 Raven FR-S
My FR-S apparently had sand in the engine block from the manufacturing process.. 7k mi later idle started dropping to 3k and i lost compression in one of the cylinders. Toyota reembursed my down payment. Hopefully i dont run into the same problem when i go to buy a new one after this deployment lol..
#12 | |
Grey Wind
So, my grandma Reynolds was always saying 'when life gives you lemons, make lemonade.' I wish she was still alive, because I'd really like to ask her what she suggests for when life gives you Chlamydia.--Veronica Mars |
#13 |
Going to be following this thread closely.
Good luck CSG Mike! |
#14 |
ps.. they tried to deny my claim, but after a month of arguments I had to deploy and left my father in charge of taking care of it. IDK what he did, but i got a $6k deposit back into my account. Apparently threats work wonders lol.
| The Following 2 Users Say Thank You to USMC FR-S For This Useful Post: | 20valvewynn83 (05-30-2013), jimmillion (05-30-2013) |
| We Ask Toyota & Subaru about James May's Claim that Toyota Gets 90% of GT 86/FR-S/BRZ | vh_supra26 | Scion FR-S / Toyota 86 GT86 General Forum | 94 | 09-15-2013 08:55 PM |
| Denied service... | Chen | Northwest | 37 | 09-13-2013 08:37 PM |
| HELP with diminished value claim! | zohare | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 04-03-2013 11:17 AM |
| Hit and Run Insurance Claim | CharlieChaos | Off-Topic Lounge [WARNING: NO POLITICS] | 9 | 12-26-2012 08:54 PM |
| Japan loses its claim to "Creepiest Asian Country" | reni | Off-Topic Lounge [WARNING: NO POLITICS] | 3 | 05-07-2012 11:57 PM |
