Old 05-29-2013, 01:23 PM   #1
CSG Mike
CSG Mike's Avatar
Has anyone had a warranty claim denied? Seized engine! Pics of teardown added 6/5
Background info:
The CSG BRZ suffered from the injector seal failure that is frequently mentioned. Here are some threads regarding that.
http://www.ft86club.com/forums/showthread.php?t=36129
http://www.m3post.com/forums/showpos...73&postcount=5
[ame="http://www.youtube.com/watch?feature=player_embedded&v=VnFa2IvNs9g"]Frs popping noise when given throttle free revving or cruising, rolling on throttle to pass. - YouTube[/ame]
http://www.ft86club.com/forums/showt...light=warranty
We were getting the misfire, but had no CEL until the was dead. The symptoms showed up in the following order:
- Misfire/popping
- Rough idle
- Unable to hold idle, misfiring on idle dip
- Siezed/dead engine (no holes in engine or anything...)
This is not the first time we've had the misfire/popping. We've actually had a full engine replacement last year when the original engine had the same initial symptom. At that time, we had taken the car in to Irvine Subaru; they were very accommodating of the unusual symptom on our car. This time around, Palm Springs Subaru (Desert Subaru?) was the closest dealer, and were told over the phone that we would need a CEL before we came in to avoid a diagnostic fee that would be need to paid out of pocket. They were unwilling to diagnose the symptom, even though it was thoroughly explained over the phone.
After the engine died, we had the car towed back to our original dealer, Irvine Subaru. They are, of course, at the mercy of the tech line, and per Subaru of America, they asked for a service record on our car, which was provided. They then proceeded to take off the oil pan per Subaru's instructions, and at that point, we were informed that there was "metal all over the place" and that the engine would not be warrantied due to track use.
Contact with Subaru of America was initiated, and the exchange was unfortunately unproductive. In short, they are denying us warranty coverage because the car was "used for racing".
At this point, I'd like to point out Subaru's marketing materials.
http://www.media.subaru.com/newsrele...id=190&mid=127
With 2+2 seating and a folding rear seat, there is sufficient cargo space to transport four race tires and tools to track days.
Seeking a pure sports car for road and track driving, Subaru followed a purist approach to engineering the 2013 BRZ.
A standard Torsen® limited-slip differential helps the inside wheel maintain traction during hard cornering. For track driving, the standard Vehicle Stability Control (VSC) stability and traction control system (TCS) offers the driver five different settings, including a Sport mode and a TCS Off switch for track driving activities.
Drivers who enjoy slalom or track events can also fold the rear seatback and have room for four wheels, a helmet and basic supplies and still have room for the front passenger.
The five-mode driver-selectable Vehicle Stability Control (VSC) system and traction control system allows the driver the tailor the system to conditions and performance needs; stability and traction control can be disengaged for track driving events, for example.
Here's an e-mail from the Subaru of America rep that our case was escalated to.
Irvine Subaru can show you the metal throughout the engine. Again, our position in regards to this failure is that it is a result of the vehicle not being driven as the design intended. We have found evidence to indicate this vehicle was raced at Willow Springs International Raceway and the damage to the engine is indicative of racing. We need to reiterate that Subaru of America’s position is the engine failure is not a matter for warranty, it is a customer pay issue and our position is not going to change. We are sorry this is not that answer you may have expected.
Bill
According to the marketing materials and press release, Subaru seems to imply that the car is designed for track days. We're certainly not RACING; the car doesn't meet the safety requirements form any sanctioned racing, and does not see that type of activity. Both the engine and all safety components are and always have been stock.
Is our car driven hard? Most certainly. Do we track it? Of course! Have we done anything to alter the parameters of the drivetrain? Absolutely not. We're using the car as designed, at least, according to their press materials.
We would disagree that the vehicle taken to the track is irrelevant. A situation such as this is noted on Page 7 of our Warranty and Maintenance Booklet that came with the vehicle.
Damaged Caused Due to Use of Vehicle in Competitive Events
These warranties do not cover damage to any component that is the result of operating the vehicle in any competition or racing event.
Irvine Subaru can show you the engine damage. It is our position that the metal throughout the engine is due to racing the vehicle. As previously indicated our position in this matter is not going to change and we are not offering financial assistance towards the repairs.
Bill
Is this warranty coverage denial justified?
*edit*
Pics of a repair order on a FR-S that had the same problem
[IMG]http://i23.photobucket.com/albums/b395/nismo350z/Scion%20FRS/250396D5-7246-48AD-89FB-***E27D2B313-1032-00000132D6BCC474_zps686e4a0a.png[/IMG]
Pics of damaged Injectors/seals from another car
Quick update.
Apparently our cats are both destroyed. Now what could cause that....? I'll be dropping by the dealer on Monday to get more pictures of the additional teardown. Someone else at Subaru of America (not Bill, the rep I was talking to) authorized more teardown.
*edit*
More damaged injectors from another car
*edit*
It seems one cat MELTED a bit (has a pretty good sized "dent" in it, but it's smooth), and the other cat is falling apart.
Pics from teardown
Engine from the bottom. Connecting rod on cyl 2 has seen some heat...
Engine from the front
Cylinders 2 and 4
Damaged collar (next 3 photos are on the same "pair" of injectors)
Collar completely gone and injector... scorched?
Another angle
Other two injectors. This one is a bit damaged as well
Oil pan...
*edit 8/22/13*
More problems in japan
http://minkara.carview.co.jp/en/user...blog/30522262/
(use google translate)
The Following 8 Users Say Thank You to CSG Mike For This Useful Post:
autobrz (05-31-2013), Bristecom (06-06-2013), chanomatik (07-17-2013), Koj (09-30-2016), leon78 (05-29-2013), Porsche (05-29-2013), RYU (06-07-2013), track_warrior (06-07-2013)
Old 05-29-2013, 02:05 PM   #2
Lonewolf
Lonewolf's Avatar
Drives: Moped
***DISCLAIMER: This post is in no way, shape, or form legal advice or counsel.
I figured a public discussion of some issues might be of some benefit to the members here.
CSG~
1) If the problem which ultimately caused your engine to seize is later found to be a design/manufacture defect or flaw, then your position is suddenly much stronger here (worth mentioning since Toyota has attempted to remedy certain issues with the FA20 via the latest tsb regarding engine software/calibration). The problem is proving the cause (Magnusson-Moss comes into play here) of the engine seizure with respect to any intervening/superceding factors such as your "spirited driving."
So was the cause of the engine failure your driving, the modified suspension and tire components, or the potential design/manufacture defect (factory tune, injector parts and functioning)? That is the major question here.
2) The fact that Subaru's press/marketing materials tout and encourage performance use of the BRZ (despite their somewhat contradictory warranty and user manual statements) is a potential avenue to be explored as well. In a sense, Subaru is marketing the product one way, and then refusing to honor a "reasonable" if not intended use of a sports coupe.
3) The fact that Subaru previously replaced your motor under warranty after similar driving conditions may come into play as well. Was this move an act of "good will" on behalf of Subaru, a waiver and acceptance of your spirited use of the vehicle, or was it an indirect concession that there are unresolved issues with the FA20?
4) As you said, another issue worth noting is that the drivetrain was stock. Now if you had an intake or aftermarket tune (which can cause a lean condition) then I can see Subaru's justification for denial of warranty coverage of the motor. In this case, the fact that the motor was stock (and I presume properly maintained) works in your favor.
***So what to do now...any combo of the three depending on your decision:
1) Seek counsel from an attorney who specializes in warranty/contract or automotive claims. Further investigation of the cause of the engine seizure will likely be necessary here and will involve considerable expense.
2) File a safety complaint with the NHTSA since having an engine seize during operation is a safety concern.
3) Spread word of this problem using the power of the internet (particularly Autoblog and Jalopnik).
The Following 13 Users Say Thank You to Lonewolf For This Useful Post:
20valvewynn83 (05-30-2013), ATL BRZ (05-29-2013), autobrz (05-31-2013), Batman (05-29-2013), heeltoe86 (06-01-2013), invzabomaster (07-31-2013), Marrk (05-30-2013), R2RO (07-29-2013), ravenblackfrs (05-30-2013), Ryeong86 (05-31-2013), SkullWorks (05-29-2013), sosick (08-07-2013), strat61caster (05-29-2013)
Old 05-29-2013, 02:08 PM   #3
CSG Mike
CSG Mike's Avatar
Subaru refuses to authorize further teardown to investigate the ultimate cause of the failure. They've been asked several times, and refuse on the basis that the "vehicle was raced".
Old 05-29-2013, 02:19 PM   #4
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Good luck dude, this is a tough one.
Rayme is offline   Reply With Quote
Old 05-29-2013, 02:19 PM   #5
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
Keep in mind as long as you own the car/motor, even though Subaru might refuse to authorize further teardown to investigate, you can.
whaap is offline   Reply With Quote
Old 05-29-2013, 02:20 PM   #6
Hanakuso
Did you specifically tell them or did they do the research?
Hanakuso is offline   Reply With Quote
The Following User Says Thank You to Hanakuso For This Useful Post:
Yruyur (05-29-2013)
Old 05-29-2013, 02:23 PM   #7
Brently
Grey Wind
Brently's Avatar
Drives: FR-S 10 Series #0065
This is a very interesting thread. I feel badly for anyone affected by corporate greed, and by a car manufacturer not stepping up and doing the right thing. I had an 8 month old car turn into a fireball in a parking lot a few years ago. The engine wasn't even running. It took 2 years before the manufacturer admitted that there was a "problem" then sent out recall letters to over 230,000 owners telling them not to park their cars in their garages until they could have their vehicles inspected because they might catch fire.
I really hope that engine issue gets resolved. If it happened to one person, that is one too many as far as I am concerned. Look into getting a lawyer-- that is what I did. It is difficult to take on "the man" by yourself. Also send registered letters to head office, CEO, company president etc. When my car exploded, I also mentioned I would be showing up at random dealerships and standing on the sidewalk with poster sized pictures of my burn't car. Rattle some chains-- don't take no for an answer. From experience-- they are hiding behind a lame answer and refusing to step up to the plate because there may be implications (larger than we can see) regarding the longevity and performance of the engine. It's easier for them to say that it isn't their fault, then pass the blame onto you than admit a problem and issue a recall once it happens to a dozen or so other people.
I will be following this thread. Best of luck!
Brently is offline   Reply With Quote
Old 05-29-2013, 02:29 PM   #8
CSG Mike
CSG Mike's Avatar
They did their own research, but we don't exactly hide it with our youtube videos, etc.
For example, try googling "mike kang brz"
Old 05-29-2013, 02:30 PM   #9
BlueSTaR
BlueSTaR's Avatar
Drives: 13 BRZ Limited & 16 Hyperblue
What worries me is that it happened to him twice.
Has anyone else experienced this? What can we do to prevent this? Is it a common problem?
BlueSTaR is offline   Reply With Quote
Old 05-29-2013, 02:33 PM   #10
CSG Mike
CSG Mike's Avatar
The initial symptoms are widespread. see: http://www.ft86club.com/forums/showthread.php?t=36008
Old 05-29-2013, 02:56 PM   #11
USMC FR-S
USMC FR-S's Avatar
Drives: 2013 Raven FR-S
My FR-S apparently had sand in the engine block from the manufacturing process.. 7k mi later idle started dropping to 3k and i lost compression in one of the cylinders. Toyota reembursed my down payment. Hopefully i dont run into the same problem when i go to buy a new one after this deployment lol..
USMC FR-S is offline   Reply With Quote
Old 05-29-2013, 02:59 PM   #12
Brently
Grey Wind
Brently's Avatar
I put ten grand down. I hope there is sand in MY engine.
So, my grandma Reynolds was always saying 'when life gives you lemons, make lemonade.' I wish she was still alive, because I'd really like to ask her what she suggests for when life gives you Chlamydia.--Veronica Mars
Old 05-29-2013, 03:02 PM   #13
oofie
Going to be following this thread closely.
Good luck CSG Mike!
oofie is offline   Reply With Quote
Old 05-29-2013, 03:03 PM   #14
USMC FR-S
USMC FR-S's Avatar
ps.. they tried to deny my claim, but after a month of arguments I had to deploy and left my father in charge of taking care of it. IDK what he did, but i got a $6k deposit back into my account. Apparently threats work wonders lol.
The Following 2 Users Say Thank You to USMC FR-S For This Useful Post:
20valvewynn83 (05-30-2013), jimmillion (05-30-2013)
We Ask Toyota & Subaru about James May's Claim that Toyota Gets 90% of GT 86/FR-S/BRZ vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 94 09-15-2013 08:55 PM
Denied service... Chen Northwest 37 09-13-2013 08:37 PM
HELP with diminished value claim! zohare Scion FR-S / Toyota 86 GT86 General Forum 41 04-03-2013 11:17 AM
Hit and Run Insurance Claim CharlieChaos Off-Topic Lounge [WARNING: NO POLITICS] 9 12-26-2012 08:54 PM
Japan loses its claim to "Creepiest Asian Country" reni Off-Topic Lounge [WARNING: NO POLITICS] 3 05-07-2012 11:57 PM
