Old 05-22-2013, 06:44 PM   #29
TAP Auto Parts
Drives: FRS
Originally Posted by NemeGuero View Post
bump. cuz.
Well here you are then :happy0180:
TAP Auto Parts is offline
Old 05-22-2013, 06:56 PM   #30
Jarumie42172
Drives: 1992 BMW E36 325i, 2013 Scion Frs
I'm liking the spacers they make too!!!!
Jarumie42172 is offline
The Following User Says Thank You to Jarumie42172 For This Useful Post:
TAP Auto Parts (05-22-2013)
Old 05-22-2013, 07:03 PM   #31
TAP Auto Parts
Drives: FRS
Subframe and diff spacers or the wheel spacers? I will post their subframe modification writeup if you guys want to see.
Old 05-22-2013, 07:05 PM   #32
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
I'm about to jump on a set of those myself! Love the adjustability. Think I'll use the bolt-on for the rears and whichever shim I can get away with in front on stock studs.
Dan took me for a ride in that car earlier this year. I was amazed at how well it took the crappy roads by the shop. Then he spun it around a cul de sac a couple of times. Pretty sure I giggled.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline
The Following User Says Thank You to 2point0 For This Useful Post:
Old 05-22-2013, 07:06 PM   #33
2point0
2point0's Avatar
Please do!
2point0 is offline
Old 05-22-2013, 08:49 PM   #34
NemeGuero
I've seen all this already. I WANT THE PRODUCTS NOW!
Love their Competition Coilovers.
NemeGuero is offline
The Following User Says Thank You to NemeGuero For This Useful Post:
Old 05-28-2013, 08:41 PM   #35
NemeGuero
Bump. Hi. MAX
TAP Auto Parts (05-28-2013)
Old 05-28-2013, 10:22 PM   #36
TAP Auto Parts
Drives: FRS
Originally Posted by 2point0 View Post
Please do!
Originally Posted by Dan @ MAX USA
The process of the subframe bushing removal starts with slicing off the rubber that will bounce back your knock-out force
next, get a huge socket or a 2&1/4" pipe and beat out the old bushings.
support the underside firmly with wood
You can see the diff front mounts have a top and bottom half. Be careful not to stab the old bushing when knocking it out because its filled with OIL!
The rear solid diff mounts weld into the subframe.
Two of the subframe bushings are recessed when you put them in place. this is your guide to grind the top flush for maximum subframe rising.
After the grinding...
This is the rear coilover, installed here with our shortest damper, and its MAXed out, so in the production version we will let the spring touch the top plate directly to give some more low range ride height adjustment
Subframe is put back in place...
Diff mounts back in place with aftermarket riser installed...
You can see the the SF rising leaves an opportunity to shorten the exhaust hangers by the amount of the airgap shown below, to keep the pipe from scraping the ground.
Front coilover prototypes PRO version
List of the goods in process
~ Coilovers
~ FLCA
~ Sub frame Risers
~ Solid Diff Risers
~ RLCA
~ Trac rod
~ Toe rod
~ RUCA
~ Super steering angle knuckles
~ Rear drop knuckles
The Following User Says Thank You to TAP Auto Parts For This Useful Post:
2point0 (05-28-2013)
Old 05-28-2013, 10:34 PM   #37
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Prototype - Scion FRS solid subframe spacers & diff risers
I WAS JUST ABOUT TO ASK ABOUT THESE!!
ETA on release?!
TylerLieberman is offline
The Following User Says Thank You to TylerLieberman For This Useful Post:
TAP Auto Parts (05-29-2013)
Old 05-29-2013, 02:38 AM   #38
TAP Auto Parts
Drives: FRS
They are on a boat right now! No clear ETA though.
Old 05-29-2013, 03:21 PM   #39
NemeGuero
HAHAH I know man, waiting on this new stuff is a killer. We will have it all on display at 86EXPO!
Just saw this. So that means everything should be available by then? When is the expo?
Old 05-29-2013, 03:32 PM   #40
bakerr6
Drives: 2013 raven black fr-s
hmm I will need a price quote on a few of those parts it looks like haha
bakerr6 is offline
The Following User Says Thank You to bakerr6 For This Useful Post:
Old 05-29-2013, 03:32 PM   #41
2point0
2point0's Avatar
http://www.ft86club.com/forums/showthread.php?t=31304
2point0 is offline
Old 05-29-2013, 04:12 PM   #42
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Pricing on LCA yet?
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline
The Following User Says Thank You to OmarGC For This Useful Post:
SPC Rear Adjustable Lower Control Arms Bcarlos Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 04-19-2013 11:56 PM
SPC rear lower control arms, Fix your camber! JoeBoxer Brakes, Suspension, Chassis 12 03-31-2013 08:02 PM
Delete driver01 Brakes, Suspension, Chassis 11 02-06-2013 02:56 PM
cusco rear lower control arms for FR-S BRZ driver01 Canada Classifieds 3 02-01-2013 06:28 PM
Enjuku Racing - NRG/DME Rear Lower and Toe Arms ** New Product ** Enjuku Racing Brakes, Suspension, Chassis 0 10-17-2012 12:55 PM
