Old 05-29-2013, 11:24 AM   #57
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
nope full dry with heat...^^^^
Bill
Scooby South is offline   Reply With Quote
Old 05-29-2013, 11:24 AM   #58
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Originally Posted by Scooby South View Post
Just some observations:
-Andrews car was the only one on E85..
-for the Pro , Andrew was on launch control, launching about 4k
-Hankooks vs.the rest.
-loading up the class with known high-profile drivers trying to prove something isnt healthy for our cars cause in STX. and could backfire sending us to STR.
-correct setup is crutial for the twins to do well, as they respond very well to those changes for the most part.
-passing 250 runs now on developement, and starting to get some things figured out.
-congrats to Andrew and the whole Stranoparts gang for a sweep. Iinteresting strategy.
Not sure what "strategy" you're referring to? Danny and I were out of rides, mine due to a car failure as I stated in another thread, and Sam was kind enough to let me drive. I can 100% promise you the only "strategy" he had was playing the role of crack dealer to someone he knows owns a stock FRS right now, haha. And I'm certainly not a high profile driver. I've been getting my ass handed to me all year, I just pulled out a couple flyers this weekend.
I don't see what the worry is on a class bump. I think it's extremely unlikely to happen (especially sans E85), and if it does, it'll be because the car is proven to be able to keep up. If that's the case, what's the big deal? When nationals rolls around, I think you'll see things be quite a bit tighter than they were this past weekend. You could put Heitkotter on a golf cart and he'd be competitive in STX. The E36 is still the car to worry about.
As for E85... That had VERY little to do with the gap from Andrew to me. The suspension on both cars was identical, even own to making identical changes on our last run on Monday. If you watch my videos, I made mistakes on both days, big enough to cover most of that gap. Andrew's just that good.
trippinbillies40 is offline   Reply With Quote
Old 05-29-2013, 11:43 AM   #59
Scooby South
Conedancer
I didn't mean that negatively.... and I understand the "business" end of things as well... I just found it interesting is all. .. again those were my personal observations..
Bill
Old 05-29-2013, 11:45 AM   #60
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
I think a header is worth more then e85. e85 helps but it not as big of a gap as the results showed. That was mainly driver.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 05-29-2013, 11:49 AM   #61
Scooby South
Conedancer
^^^ This I definitely agree with..
Bill
Old 05-29-2013, 01:13 PM   #62
Scooby South
Conedancer
I learned Fast is not necessarily comfortable..and the other way also.. Comfortable is not necessarily fast.. need to get 'more' comfortable with being fast...
Old 05-29-2013, 01:31 PM   #63
BadPanda
Drives: 2013 Limited BRZ
Write up for driving the car at the Pro/Tour with Bill. It was a blast. Lots of tidbits on setup that I learned, first time in RWD in a National event (and I think it was only my 3rd event ever driving in RWD). Came from an 06 STI, just trying to figure it out now.
http://christycarlson.com/solo-natio...-ne-brz-setup/
[Hi, Christy Carlson here. Subie owner. Hello FT86Club!]
The Conditions for the Ladies at the Pro (L3) (and the Second day of the tour) - Hello ocean of concrete.
BadPanda is offline   Reply With Quote
The Following User Says Thank You to BadPanda For This Useful Post:
Scooby South (05-29-2013)
Old 05-29-2013, 01:45 PM   #64
trippinbillies40
Drives: '22 WRB
I totally underdrove my first run, then said to hell with that. There were spots on both courses that you just needed to man-handle to get a good time. I had major slides on my first two runs on day two after the walloms. Brushed the brakes after them on my third run to set weight on the front and threw the car in. Worked like a charm.
Here's my runs by the way:
[ame="http://www.youtube.com/watch?v=RlWh0uL7g3c"]2013 Spring Nats Champ Tour - YouTube[/ame]
I'll make a "f$ck-up compilation" when I get a chance. The closet formula-D driver in me accidentally came out a few times haha.
Old 05-29-2013, 01:53 PM   #65
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Holy shit that's some fast driving. Congrats on that.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
The Following User Says Thank You to Kido1986 For This Useful Post:
trippinbillies40 (05-29-2013)
Old 05-29-2013, 02:03 PM   #66
trippinbillies40
Drives: '22 WRB
I think you meant that comment for Pallotta
But seriously, thanks, I appreciate the compliment!
Old 05-29-2013, 02:21 PM   #67
Kido1986
Dodging cones
Kido1986's Avatar
How does the experience translate from RT* to ST* in the same chassis? Does it feel foreign or just faster and grippier but same behavior?
Old 05-29-2013, 02:45 PM   #68
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Rule of thumb, if your hands aren't shaking after your run, you werent pushing it hard enough!
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 05-29-2013, 02:52 PM   #69
xwd
Andrew could have been driving the car on RS3s, Z2s, or Rivals and the result would have been the same. From all I've seen all three of them are really close unless you talking rain/standing water or extreme temp conditions.
I also agree with Eric, if he had been on 93 octane he would have still won.
I definitely have a case of not pushing hard enough. These cars when setup well are incredible stable and a small slide of the rear end isn't a big deal most of the time. I got a chance to watch a video from our last event of my fastest run versus another Pro guy also running in CS (RX8) and he was a second faster than me through a long 4-cone slalom. My video looks like I was out for a Sunday drive, should have been pushing much harder, the car definitely had it in it.
The results I thought were the most impressive was the hurting the DSP guys put on SM.
Old 05-29-2013, 03:42 PM   #70
trippinbillies40
Drives: '22 WRB
I guess it's not worlds apart, but STX is definitely noticeably better. It's more composed, mid-corner grip is much higher, turn-in is sharper, etc etc etc. Everything is 10-20% better as a single component, and all together they just seem MUCH better.
I love that feeling. Danny was making fun of me because I was trying to put Sam's key back on his keychain after my last run on Monday and I couldn't because my hands were shaking so bad.
I've driven on all 3 and now regret having bought Rivals for my car before really driving on them much.
I was lucky enough to drive Eric's car last year. If "driving pleasure" is measured on a scale of one to ten, out of the tons of cars I've driven, his car is an 11 and the next closest is probably a 6... So mindlessly easy to drive really, really fast.
2013 SCCA-SJR SOLO SEASON Ryeong86 Tracking / Autocross / HPDE / Drifting 1 04-15-2013 11:27 AM
2013 scca solo dates theredtape New England 18 04-09-2013 10:21 AM
2013 Lincoln MKZ GH05T Other Vehicles & General Automotive Discussions 23 02-20-2013 05:25 PM
Speedway Motors SCCA Nationals Music Video! Sccabrz192 Tracking / Autocross / HPDE / Drifting 11 10-29-2012 07:30 AM
FR-S & BRZ at 2012 SCCA Solo Nationals Brett Tracking / Autocross / HPDE / Drifting 6 09-08-2012 04:58 PM
