Old 05-26-2013, 12:23 PM   #1
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
loose ball joint
so for a few weeks ive been hearing a light clicking noise in the front right wheel area when making long sweeping right turns ( weight off the problem wheel). i thought maybe a loose wheel, but that wasnt the case. maybe bearing? nahh its a new car.
yesterday i took off the front arms to install caster bushing to find out the right ball joint nut is hand tight!. just lovely. so check your car if you hear a noise. mass production always has its margin of errors.
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 05-26-2013, 01:54 PM   #2
White64Goat
Missing cotter pin? That's what dealer prep is for if indeed that is what is missing.
Old 05-26-2013, 01:54 PM   #3
charged86
charged86's Avatar
Oh my goodness. I'm glad you found it so is the ball joint all good?
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 05-26-2013, 03:10 PM   #4
Grip Ronin
The Mechanic
Grip Ronin's Avatar
nope it had the cotter pin. proly only thing holding the nut on lol
ya seems to be fine. no more weird noises from that area
IG-Joey_Soul
The Following User Says Thank You to Grip Ronin For This Useful Post:
charged86 (05-26-2013)
Old 05-27-2013, 05:47 PM   #5
Jar
Jar's Avatar
Drives: 2014 SWP BRZ Limited
omg I have something similar.
A slight occasional popping sound when making turns, or even if I just sit in my driveway and turn my wheel.
I'll take it in today to have it checked.
Jar is offline   Reply With Quote
Old 05-27-2013, 11:31 PM   #6
Le86
Drives: Asphalt FR-S
Ugh. I haven't heard anything weird coming from my car but this makes me want to check. Can never be too sure, I guess. Glad you found it before something really bad happened.
10/01/2012 FR-S down for P0019 code. Received vehicle back from dealership with a new ECU 10/30/2012
Le86 is offline   Reply With Quote
Old 05-28-2013, 01:02 AM   #7
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
Even with a loose castle nut, I am surprised that the ball joint came undone. I have had trouble getting taper joints loose even when I wanted them undone.
FrX is offline   Reply With Quote
Old 05-28-2013, 03:33 PM   #8
Grip Ronin
The Mechanic
Grip Ronin's Avatar
It didn't just fall out tho because its inverted, so the weight of the car presses into it but when weight comes off the wheel it would make noise
IG-Joey_Soul
Old 05-28-2013, 03:38 PM   #9
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Did you install all the mods on the car yourself?
Old 05-29-2013, 10:02 AM   #10
Grip Ronin
The Mechanic
Grip Ronin's Avatar
yup always have on every car
IG-Joey_Soul
Old 05-29-2013, 12:48 PM   #11
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Do you have a picture of the nut? I'm having a very similar noise from my front driver side wheel. I made an appointment to bring it in for service but if it's an easy fix I'd rather do it myself.
JDKane527 is offline   Reply With Quote
Old 05-29-2013, 01:14 PM   #12
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Thanks for the heads up, will check mine.
Rayme is offline   Reply With Quote
Old 05-29-2013, 04:21 PM   #13
JDKane527
JDKane527's Avatar
Got 1/8 of a turn on both ball joint nuts, but there is still noise.
Old 07-08-2013, 11:56 AM   #14
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Sry I forgot about this thread for a while, could be a different problem making the noise, are your struts tight?
IG-Joey_Soul
exlpoded cv joint ben15r Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 09-01-2018 04:12 AM
KW V3 and pillow ball DriftEightSix Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 09-29-2015 06:44 AM
Extended ball joints.. tech4pdx Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 05-01-2013 09:53 AM
Scion Drops the ball... dcaff Scion FR-S / Toyota 86 GT86 General Forum 402 12-14-2011 12:40 PM
Watch this on your next ball game 4agze Off-Topic Lounge [WARNING: NO POLITICS] 4 10-03-2011 04:55 PM
