#491 |
Drives: UK GT86
Has what been proven? I've reflashed mine and a few other cars a few times. Never suffered from a dead pedal and from the logs the only changes are changes in trims, which is what you'd expect. All other sensor readings show similar reading to when it's done more miles. Most of the calibration for idle readings can be done in seconds, but that's why you need a warmed car 1st so that there is no cat warm up proceedure.
.: Stealth 86 :.
#492 |
Drives: Subaru BRZ Limited
#493 |
Grip>Slip
#494 | |
Drives: RV-7
I'm methodical (well, slow) and this will make me hurry when installing the TRD CAI before the engine cools. Would you suggest a reset after installing a new less restrictive exhaust, too? |
#495 | |
Drives: 2013 FR-S, 2016 Miata Club
#496 | |
Drives: UK GT86
Resetting could be advised as its a quick way to clear trim adjustments, although the ECU is always adapting so a reset isn't necessary.
.: Stealth 86 :.
#497 |
Drives: UK GT86
A tuner told my mate about it when they flashed his car. We then tried it on his AT and I've since done it on my MT a few times. Let's put it this way, I only know of the dead pedal as its spoken of on here, I've never experienced it. My guess is that you have to calibrate the pedal's full range. I've done a log on a car that didn't do this and the pedal position never showed 100% until it had been pushed to the floor a couple of times, which would explain a bogging feel.
.: Stealth 86 :.
#498 |
Does anyone have the TRD intake and an oil cooler such as the Perrin? Any fitment issues with both installed?
#499 |
I don't have an oil cooler yet, but it will not fit as far as I can tell. Look at my pic of how close the oil filter is to the intake box. Not much room. I'm thinking on using banjo fittings instead of the elbows that Perrin has.
#500 |
Drives: '14 Monogram FR-S(RIP)
I know the Cusco oil cooler will fit with it. Isn't wallet-friendly though.
#501 |
Drives: 13' Scion FRS MT
Just got the TRD CAI / Exhaust combo installed.
Car sounds noticeably better, albeit a little louder. However the cabin volume with the windows up seems to be about the same. Definitely hearing the boxer engine now.
07' Z4M Coupe | KW Clubsports | AFE Intake | Stromung Mufflers | UUC Shortshifter | Advan RS
15' 228i MSport 13' FR-S | TRD CAI | TRD Catback | UEL Header | OFT Stg 1 | Rota Grid-V | RCE Suspension | Hankook | |
| The Following User Says Thank You to Re~Mix For This Useful Post: | tripjammer (06-18-2013) |
#502 |
Drives: Ultramarine FR-S 6MT
I definitely don't have that issue, my pedal is just about telepathic. If the car didn't respond I would swear I hadn't actually moved my foot at all.
#503 |
Drives: WRB BRZ limited 6MT
Been running this intake for a grip. No issues and it respond well to ecutek tunning. About to run this car with E85 and this intake. Will let y'all know how much power this combo makes.
| The Following User Says Thank You to tripjammer For This Useful Post: | Thorpedo (06-18-2013) |
#504 | |
| cold air intake vs short ram intake ? | tnt | Engine, Exhaust, Transmission | 5 | 02-02-2014 12:43 AM |
| So cold air intake or air intake? | bcmakesiteasy | Engine, Exhaust, Transmission | 12 | 02-01-2014 08:06 PM |
| HKS intake setup VS Injen intake,,,what are your thoughts? | JDMrolla | Engine, Exhaust, Transmission | 4 | 10-11-2012 01:31 PM |
