Old 04-17-2013, 12:16 AM   #99
whtchocla7e
Drives: 2013 FR-S Hot Lava
Is this similar to what you guys are experiencing?
[ame="http://www.youtube.com/watch?v=1-M3fM-G6k4"]FR-S startup stumble - YouTube[/ame]
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 04-17-2013, 06:59 AM   #100
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
its 68F in CT?
Huehuecoyotl is offline   Reply With Quote
Old 04-17-2013, 01:40 PM   #101
firl21
Drives: Scion FRS in hot lava
Originally Posted by Dtronic View Post
Happened to me once last week. A little over 1000 miles.
I have an auto and it was in the afternoon going home from work. It was around 70F temp wise.
Cranked about 5 seconds and no start. A wtf moment and sat there for 10 seconds or so and tried it again and started after 3 seconds cranking.
Usally starts as soon as I turn the key. Hasn't happened again.
Bit strange. problem in the making. Happend to me aswell with 300miles on it. If it happens again im taking it in to the dealer to have the terminals and battery checked
firl21 is offline   Reply With Quote
Old 04-18-2013, 07:45 AM   #102
WRXGuy1
WRXGuy1's Avatar
Drives: 2013 WRB BRZ Premium 6MT
Not for me. With mine every once and a while I will turn the key and it will just keep trying to start up, almost like when the battery is almost dead and doesn't have enough power to start it. I turn the ignition off, back on again and it fires right up.
2013 BRZ Premium WRB MT - Picked up 5/31/12
WRXGuy1 is offline   Reply With Quote
Old 04-20-2013, 05:17 PM   #103
FR Sports
FR Sports's Avatar
Drives: Ultramarine FRS 6MT
I just experienced this start up issue at about 1450km. Cranked the engine for 4-5 seconds but didn't start. Re-cranked for 2-3 seconds after and it started. I don't think it's a battery related issue as the engine turned over strongly. I suspect it has something to do with the fuel and/or ignition system. Either the fuel is not being delivered to the cylinders and/or there is no spark from the spark plugs. Gut feeling tells me it has something to do with the new direct injection system. Maybe the high pressure fuel pump needs priming before turning over the engine although I am not sure if the direct injection is used upon start up.
FR Sports is offline   Reply With Quote
The Following User Says Thank You to FR Sports For This Useful Post:
Lonewolf (05-25-2013)
Old 04-21-2013, 05:05 AM   #104
KritiK
Drives: Toyota gt86
it happens yo me first time today with 4800km, I have a gt86 and pressed the button, the starter motor start, and normally in 2 seconds engine come on, but this time it has like 6 seconds to try, like there is no fuel on injectors, I don't know how to explain better.
KritiK is offline   Reply With Quote
Old 05-25-2013, 12:18 AM   #105
oTaGGeDo
oTaGGeDo's Avatar
Drives: Currently driving a 2013 turbo Tc
No tsb on this yet my new frs has done I twice today 1500 miles on it
oTaGGeDo is offline   Reply With Quote
Old 05-25-2013, 05:43 AM   #106
Lonewolf
Lonewolf's Avatar
Drives: Moped
Do you turn the key to the "ACC" position on the ignition and wait a few seconds to let the fuel system prime?
Old 05-25-2013, 07:35 AM   #107
oTaGGeDo
oTaGGeDo's Avatar
I always wait for my gauge to go all the way up to my set rev limit then all the way back down to 0 before turning the key yes
The Following User Says Thank You to oTaGGeDo For This Useful Post:
Old 08-06-2013, 05:48 PM   #108
cevin45x
cevin45x's Avatar
Drives: '13 BRZ Limited
This has happened to me 5 times since I bought it back in Aug 30th. And I have a feeling if I drove it more I would have experienced a couple more times. (maybe once a month) It has done this in hot, warm, and cold weather. I never brought it into the dealership cuz I know they won't be able to reproduce it. I have the push start button system.
'13 BRZ Limited - CBS MT
STX Build - OFT Stage 2 EL 93oct (etune)/TRD intake/HKS EL catless/Motiv OP/Invidia FP catted/Perrin CBE resonated/All complete Whiteline bushings/MTEC trans & clutch springs/Kartboy SS & mount/Perrin 19mm f & 16mm r/Perrin crank & assessory pulleys
cevin45x is offline   Reply With Quote
Old 08-06-2013, 07:50 PM   #109
Ozzman
Drives: old
How much fuel is left in the tank when this happens? Does it always occur at roughly the same fuel level, or does it not matter at all?
Ozzman is offline   Reply With Quote
Old 08-06-2013, 11:48 PM   #110
cevin45x
cevin45x's Avatar
It seems like it doesn't matter. It happened half tank and full, can't remember when the last time I let the tank go way down.
Old 01-02-2014, 07:51 PM   #111
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
My car is having similar problems .... Put the key in and turn it for the gauges and BOOM goes dead. I have to reset both terminals and hopefully it will spark up and turn on.... I had the battery checked and alternator and it's fine. He said he thinks it's the alarm system since Toyota put mine in and also auto start and disconnected the security box. I had this removed in hopes of it being fixed and nothing. I'm going to put the viper system in instead of a new battery since it's fine. Please quote me if anyone has any comments or advice
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 01-08-2014, 06:03 PM   #112
FV
FV's Avatar
Drives: 2007 Honda S2000, 2013 BRZ LMT
has anyone changed their battery to see if that would solve the problem?
FV is offline   Reply With Quote
After Market Problem Signals Fuse Popped- Car Wont Go into Gear ScionFR-S Issues | Warranty | Recalls / TSB 14 11-20-2012 02:34 PM
Car Won't Start schtebie Issues | Warranty | Recalls / TSB 25 10-15-2012 04:06 PM
trunk wont unlatch bakerr6 Issues | Warranty | Recalls / TSB 9 09-24-2012 01:32 AM
GTS come with push start? adam AUSTRALIA 13 06-04-2012 03:28 AM
Car won't start, no spark? #87 Other Vehicles & General Automotive Discussions 5 12-19-2011 12:29 PM
