Old 05-22-2013, 02:30 PM   #15
jshadeck
jshadeck's Avatar
Originally Posted by jeebus View Post
Let's not forget that you are also running a taller than stock diameter tire too..by .8"
Just for the sake of being exact, since i have this setup (although depends tire brand) a 235 on a 9.5 has a stretch to it. Based on "calculators" my speedo should be off by almost 3mph at 90mph but 2 different gps reads and driving behind a brand new stock car at 90 tell me im off less than .5mph
jshadeck is offline   Reply With Quote
Old 05-22-2013, 03:29 PM   #16
speed6sam
Drives: SWP BRZ Limited 6 Spd
I run 18x9.5+38 square with 265-35-18 all around and never rub on anything. I did roll my front and rear fenders for a little more clearance and I am dropped 2.5 inches all around with camber right at 2.5 degrees in the front. I can go full lock without any issue or rubbing under any kind of driving.
speed6sam is offline   Reply With Quote
Old 05-22-2013, 04:24 PM   #17
jeebus
Yes, but the stock speedo is already off from the get-go by around 3mph. You just fixed the error.
jeebus is offline   Reply With Quote
Old 06-27-2013, 01:39 PM   #18
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
idk how any of you guys are rubbing. i was just at the track. and i run a more aggressive setup then most. ZERO rubbing. even when i threw the keys to a pro-grand am driver he pushed my car to it absolute limits and STILL no rubbing.
you either dont have the right camber, have shitty rates/coilovers or you're rebound/compression is off.
here is picture proof. all info on my car is in my build thread of my meaty tire thread...
as far as how do you know when you wont rub, well visually look and see if the wheel will clear. i rolled all 4 corners just to be safe but AT MINIMUM you must trim the rear bumper tabs and roll the front flare by the side markers.
Jive Turkey is offline   Reply With Quote
The Following User Says Thank You to Jive Turkey For This Useful Post:
denkigrve (07-09-2013)
Old 10-11-2013, 05:05 PM   #19
mfbmike
Drives: 2013 FRS, 2008 R32
This. He's running a 40 sidewall tire instead of a 35. As pointed out in this thread, there are people running 18x9.5 +38 wheels with up to 265/35's with no issues (with the required camber).
Plan on a similar setup myself, once my wheels get here.
mfbmike is offline   Reply With Quote
Old 10-11-2013, 05:11 PM   #20
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Need more ppl with 18x9.5 Forgestar F14's with a +38 offset to post some photos.
@empower-auto... where are your photos?
Old 10-12-2013, 12:22 AM   #21
empower-auto
Kouki-Monster
empower-auto's Avatar
My wheels are getting refinished at the moment and it's just about winter here. I'll see if I have any pics kicking around
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
The Following User Says Thank You to empower-auto For This Useful Post:
DarrenDriven (10-12-2013)
Old 10-12-2013, 06:34 PM   #22
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
@OP i run the same wheels but with 235/40-18 up front and 265/35-18 in the rear both +38 and im on stock height... your front setup is way too big as my fronts are just flush at 235s and my rears poke just a bit but to my liking... i have about 2-2 1/2 finger gap in the front and rear but you should have looked into the fitment if you were going to drop it that much... im on zero camber as well. if your going to track your car you need to go with 17s or 18s but maybe 8inches in width... how about you raise the car up until it doesnt rub since you have coilovers
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
The Following User Says Thank You to ScionFR-S For This Useful Post:
fx35s (01-24-2014)
Old 10-17-2013, 03:04 AM   #23
peebking
Drives: BRZ limited
just put it on with stock height 18x8.5 +38 front 18x9.5 +38 rear with 225/40/18 and 245/35/18 rear, plan to lower later
peebking is offline   Reply With Quote
The Following User Says Thank You to peebking For This Useful Post:
junior_reyez (02-11-2014)
Old 10-17-2013, 04:12 AM   #24
SortaFlushed
SortaFlushed's Avatar
Drives: Raven Black
How are they on the rears?
SortaFlushed is offline   Reply With Quote
Old 01-24-2014, 09:15 AM   #25
ScionFR-S
ScionFR-S's Avatar
I have same setup as above +38 offset but with 265/35s and the rid isn't too bad to be honest. Def a little harsh with the low profile but nothing that can't be gotten used to. The poke a little bit but it looks great IMO with it
Old 02-09-2014, 04:05 PM   #26
ScionFR-S
ScionFR-S's Avatar
I have the same setup but with a 235/40 and 265/35 ... Dropped on pro kit springs 1" i think its gunna look hella flush and perfect gapping
Old 02-09-2014, 04:21 PM   #27
charged86
charged86's Avatar
Very nice sir!
Old 12-20-2014, 02:43 PM   #28
Mikeez
Engineering Student
Drives: Scion FR-S 2015
I'm going 18x9.5 square with the F14 wheels. I am going 255/35r18 all around.
I will have the coilover RS*R Sports-i
I plan to drop the car 0.5-0.8" down. I don't plan on camber, if I have to camber... I will go -1.5 degree!
1.Any fitment issues you believe?
2.Which offset should I get? I don't want the wheels to go too out of the fender? I am using the FRS tore calculator to verify meanwhile
No one has the same set up as me here, but maybe from experience you guys can help
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Wheel Directory: Advan GT 18x9.5 +40 FT-86 SpeedFactory Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 12-05-2017 08:26 PM
Wheel Directory: Work VS-XX 18x9.0 +34/18x9.5 +39 mav1178 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-13-2014 05:09 AM
Wheel Directory: Forgestar CF5V 19x8.5 +?? / 19x9.5 +?? Mr. Joshua Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 08-22-2014 12:17 AM
Wheel Directory: Forgestar F14F 17x9.5 +38 lp87 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 07-02-2014 03:41 PM
Wheel Directory: BBS RS 18x8.5 +35 / 18x9.5 +35 JRoldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 03-07-2014 09:10 AM
