Old 05-21-2013, 06:12 PM   #1
empower-auto
Kouki-Monster
empower-auto's Avatar
Red face Wheel Directory: Forgestar F14 18x9.5 +38
I'm a little frustrated .. maybe with myself. I pulled the trigger on 18x9.5 Forgestar F14's with a +38 offset.
I am running a 235/40/18 tire all around. For suspension I have HSD HR coil-overs and my height up front is pretty "flush" no gap. 1-finger gap from sidewall to fender lip. I have -1.3 camber up front.
Now .. on the street it's perfect. However on a track it's useless. The rubbing is brutal under any serious cornering. I really don't understand how anyone can say this sizing "fits" with no issues. I've seen some people reporting track use with the same sizing .. or even a 255/35 which makes no sense to me.
I went out to an auto-x course and the front was absolutely horrible.
Silly me for not doing some better measuring but .. what gives?
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 05-21-2013, 06:16 PM   #2
yoshiharadesign
Where exactly is it rubbing?
yoshiharadesign is offline   Reply With Quote
Old 05-21-2013, 06:24 PM   #3
empower-auto
Kouki-Monster
There's a black mark on the inner fender (non painted part, just inside the fender lip) about 3 inches long.
Rich Anderson
EMPOWER AUTO
Old 05-21-2013, 06:32 PM   #4
empower-auto
Kouki-Monster
took the paint right off of the fender lip on the drivers side
Rich Anderson
EMPOWER AUTO
Old 05-21-2013, 06:40 PM   #5
jshadeck
jshadeck's Avatar
Who told u it would fit no issue when dropped on coilovers? I have this setup at stock suspension, and i know i cant drop my car w out excessive camber, which i personally wont do. Maybe they meant it was ok at stock or maybe a small drop?
jshadeck is offline   Reply With Quote
The Following User Says Thank You to jshadeck For This Useful Post:
Wolfking (06-26-2013)
Old 05-21-2013, 06:41 PM   #6
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
what is your spring rates on your coils?
Sounds like you are too low.
18x9.5 really isn't an ideal wheel size for the fronts for competition on a stock car.
The Following User Says Thank You to norsamerican For This Useful Post:
Old 05-21-2013, 06:58 PM   #7
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
You'll need to double that camber setting. My car has coilovers 17x9s +35 w/ 245s w/ -2.5 & no issues.
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 05-21-2013, 07:08 PM   #8
empower-auto
Kouki-Monster
Lesson learned. I am going to go up 0.5 inches and get my camber dialed in once my bolts show up.
Rich Anderson
EMPOWER AUTO
Old 05-21-2013, 07:17 PM   #9
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Buy a second set of wheels for the track. 17s ftw!
18x9.5 up front is all for show but no go on stock body!
86_ZN6 is offline   Reply With Quote
Old 05-22-2013, 01:24 AM   #10
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
I run the same set up wheel set up with 245/35 rubber with -2.0 degrees front camber. Car gets tracked and B road blasted regularly.
I've had no rubbing on track and only with a really BIG g out (its happened twice in 6 months) do I get rubbing in the rear.
MOAR camber on the front
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
Old 05-22-2013, 06:52 AM   #11
FR-S Matt
With coilovers on 18X9.5, I think a 1 inch drop or so is sufficient. I don't see a heavy drop benefiting unless you really mess with the camber adjustment. The stock spring is already a fingernail away on a +38 18X9.5 with a 245/35 tire. If I can get a little more spring clearance, there'd be no problem with hard cornering or rubbing.
Old 05-22-2013, 10:52 AM   #12
Jlturner
Jlturner's Avatar
Drives: Scion fr-s
I seen you on the track Sunday in Edmonton, I was going to come over and introduce myself but by the time I got down there you had left. I was also planning to run 18x9.5 wheels all around with 235/40 rubber. I won't be tracking my car often but I don't want any rubbing issues either. I'm wondering now if I should change my plans for wheels. I am lowered on Eibach Sportlines so I'm probably not quite as low as you so maybe I will get away without rubbing.
Jlturner is offline   Reply With Quote
Old 05-22-2013, 11:09 AM   #13
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
More front camber is the answer here. I will be getting my setup fine tuned over the next week, and I will definitely report back what I have to do to ensure I get no rubbing on my 18x9.5 +40 265/35/18 setup.
mfbmike (10-11-2013)
Old 05-22-2013, 11:43 AM   #14
jeebus
Let's not forget that you are also running a taller than stock diameter tire too..by .8"
jeebus is offline   Reply With Quote
Wheel Directory: Advan GT 18x9.5 +40 FT-86 SpeedFactory Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 12-05-2017 07:26 PM
Wheel Directory: Work VS-XX 18x9.0 +34/18x9.5 +39 mav1178 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-13-2014 04:09 AM
Wheel Directory: Forgestar CF5V 19x8.5 +?? / 19x9.5 +?? Mr. Joshua Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 08-21-2014 11:17 PM
Wheel Directory: Forgestar F14F 17x9.5 +38 lp87 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 07-02-2014 02:41 PM
Wheel Directory: BBS RS 18x8.5 +35 / 18x9.5 +35 JRoldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 03-07-2014 08:10 AM
