Old 05-21-2013, 07:10 PM   #99
swift996
swift996's Avatar
So I jacked my car up and felt around. My noise is only coming from the front driver's side. The top mount seems to have a little play in it relative to the others. Not sure if that's it. I also noticed the sway bar is close to the lower control arm, with some smaller or adjustable links I could rotate the bar a little to avoid that. I don't know if it makes contact but again the sound is specific to the front driver's side.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 05-21-2013, 08:21 PM   #100
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Wish i still had those Whiteline front links i had so i could send them out. I think there is a top hat issue, similar to the problem with the Com-C mounts last summer.
Old 05-22-2013, 08:59 AM   #101
swift996
swift996's Avatar
Is anyone running aftermarket end-links with the R2s?
Old 05-22-2013, 10:42 AM   #102
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'm not. I have some noise from the rears, but I'm not sure if it's really from the rears as I currently have a lot of junk in the trunk that could be bouncing around.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-22-2013, 10:54 AM   #103
ayau
Drives: Some rust bucket
I get a little clunking too, but it's nothing too bothersome. The crickets annoy me more than anything, lol.
I'm kind of worried that the off-the-shelf valving won't be able to handle the 500-600 spring rates. We'll see once I get them on a track/autox event.
Old 05-22-2013, 12:20 PM   #104
Hanakuso
Iirc, Jackson said it should be able to handle that.
Just to be 100%, the springs we have are 2.5" I.D.?
Hanakuso is offline   Reply With Quote
Old 05-22-2013, 12:29 PM   #105
ayau
That's correct. 6'' at the front, 7'' at the rear.
The Following User Says Thank You to ayau For This Useful Post:
Hanakuso (05-22-2013)
Old 05-22-2013, 12:49 PM   #106
Hanakuso
Cool, thanks! One of the authorize vendors is having a sale for $49 each but i'll probably wait till Eibach finds out the issues, and wait from some people tracking.
Old 05-22-2013, 02:16 PM   #107
swift996
swift996's Avatar
I'm about 95% convinced it's the top hat/mount. The others make a little noise (to be expected) but this is a loud clunk like the spring is smacking metal and then rattling free when the load comes off.
Old 05-22-2013, 02:20 PM   #108
RYU
RYU's Avatar
Drives: really slow...
If you have additional time to spend on this you can try removing the helper spring and setting spring pre-load to zero or even add a tiny bit of preload. You'll loose your droop travel but at least you can isolate the noise.
This will eliminate the helper spring being the culprit to your noise like I suspect it might be.
RYU is offline   Reply With Quote
Old 05-22-2013, 02:21 PM   #109
ayau
I wonder if the springs need to be longer so there's more compression and less slop?
Old 05-22-2013, 06:53 PM   #110
swift996
swift996's Avatar
As I mentioned it's all coming from the driver's side front. There's a good one at the end there:
[ame="http://www.youtube.com/watch?v=GpdddqXIFNg"]Eibach R2 Clunk Noise - BRZ - YouTube[/ame]
Old 05-22-2013, 07:36 PM   #111
jumbaco
jumbaco's Avatar
Drives: FD
those are some nice coilovers.
jumbaco is offline   Reply With Quote
Old 05-23-2013, 05:11 AM   #112
tokiokun717
Drives: 2013 FR-S Whiteout
Hi, I'm going to jump into this thread even though I have the R1s because I've been experiencing similar issues.
I noticed some people complaining about the excessively harsh ride, but did you guys try play around with the preload/height adjustment? I had that issue on mine too but I found out that you actually have to preload the springs quite a bit to get them to sit in a good spot and that actually gets rid of the harshness.
tokiokun717 is offline   Reply With Quote
The Following User Says Thank You to tokiokun717 For This Useful Post:
JoeBoxer (05-24-2013)
Fortune Auto 500 Coilover Review stoneman155 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 01-16-2020 05:22 AM
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
***Time to freak out, Eibach coilover pricing available**** JoeBoxer Brakes, Suspension, Chassis 154 05-16-2013 05:30 PM
Eibach Multi-Pro-R1 VS KW v3 thebear21 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 04-10-2013 01:32 PM
Eibach Coilover Options - SEMA 2012 Coverage FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 01-25-2013 07:19 AM
