Drives: FRS
Safe amount of boost on stock engine?
Anyone know what might be a safe amount to boost on a stock engine before having to build the internals?
Just weighing the option and prices for now. |
#2 |
Drives: 2013 White FRS
I dont think anyone knows. if you boost at the levels the tunes come in i would say thats safe.
SBD turbo. Delicious tuning flex fuel. Kate oil cooling kit. Spencer crash beam. Perrin 3" Exhaust. Motiv pipes. Wilwood Front Big Brakes. Greddy Cold Air Intake. Stance Coilover kit. Spyder v2 tails. Sparcos driver seat. Race Creations duck bill cf trunk. 91/e85 tuned by Eric @ elite performance. All other installs by Neal @ the racers line.
Coming soon: track time |
#3 |
Boosted
Drives: Not a supra....yet
All depends on your tune , kit and the way you intend to drive it
My estimates from hours of lurking around here 10~ on 91 14~ on 93 thanks to king tut 16sh on 9X + WMI 20+ on e85 Obviously this is the amount of boost, you have to consider fuel issues , drivetrain and cooling My 1 cent
| The Following User Says Thank You to SmsAlSuwaidi For This Useful Post: | Sportsguy83 (05-21-2013) |
#4 | |
Drives: FRS
#5 | |
Boosted
I'm going boosted On 91 and e85 soon hopefully, i'll stay low for a month or two until I throw some low cr rods and pistons.
#6 |
Drives: AVO BRZ
I heard via the ecutek and haltech networks of a few cars throwing rods around 300 whp!
![]() Apparently it's just a load limit on the rod when it sees bursts of extreme accel. There's a lot of big number charts on here but how many of them saw extended, high load use outside of a dyno room?
| The Following 2 Users Say Thank You to nix For This Useful Post: | FA20Club.com (05-21-2013), Sonolin (05-21-2013) |
#7 | |
Drives: slow
If I'm not mistaken a fair number of them have seen a decent amount track and Drag use at 250+ whp |
#8 |
Drives: Scion FRS
Water/Meth injection seems like a good option if you have limited access to E85 or want to wait on building the motor. Ptuning is pulling 400whp on 93 and meth injection on the stock block. More than enough to get you in all sorts of trouble
#9 | |
Drives: 450 awhp twin turbo vr4
Meth Injections = Rusty part + 70% more for catastrophic failure (Not practical for every armatures ) E85 = Very few fuel stations, and the Fuel consumption is 2-3x times more of the traditional 93. Your full tank of gas may just serve you 1/3 of the original mileage range The best possible is to build a car running on 93, with conservative tune. The good news is that with 93, and running around 10 PSI will have you in the range of 300-350 RWHP already. This already makes this car into a beast |
#10 | |
Boosted
Aren't you pushing 3xx whp on a stock block @nix ?
#11 | |
Drives: AVO BRZ
#12 |
Drives: FRS
im on 93 and 5.3 psi at 286hp and with exhaust close to 300 if not 300 so its very safe because i beat it up. next week or two ill be on 10 psi pump and e85 so hopefully ill be around the 400++ so ill beat that up and tell you if its safe also but it should be lol
#13 | |
NASA SpecE30 Racer
It seems most people on this site are not really that interested in the timing that cars are running as compared to the boost that they are running. The cars making good horsepower numbers on lower boost levels are going to be running considerably more timing. You throw in some E85 or meth and again you are going to be running considerably more timing. To get the total picture of how a kit is running you would need to see dyno plots with horespower, torque, afr, boost, and ignition timing. TL;DR: There is no correct answer to your question.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#14 |
Drives: FRS
who ever has the better tuner lol pretty much ^^
| How much spacer is safe on stock rear studs? | wparsons | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 12-27-2014 01:49 AM |
| Amount of Brake Fluid.... | THEmailman | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 04-13-2013 11:46 PM |
| 2JZ engine swap on low boost - low 11's run | HighLife | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 10 | 03-07-2013 05:55 PM |
| FS Stock Engine/Trans/Drivetrain | ecda | Engine, Exhaust, Bolt-Ons | 1 | 02-13-2013 05:04 PM |
| What socket size and what torque amount for stock alloy wheels? | Takeshi | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 11-01-2012 10:25 PM |
