Old 12-05-2011, 08:29 PM   #15
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by DuMa View Post
fairly certain its 17x7. 215 is not that stretched on the width of the wheel
stock tc had 17x7 wheels with 215/45. same specs and thats how the stock tires looked on my stock tc.
Yeah generally manufacturers stick with the "suggested" or "measured" wheel spec for a tire, and in general for a 215/45/17 that's 7.0. In recent specs posts I've seen the 17x7.5 though and anything from 7-8 is considered acceptable for a 215 (without either stretching or.. pinching? not sure what the opposite would be called).
Either way I'm replacing the OEM wheels simply because 1) I don't like them and 2) they weight 20lbs based on the tech manual.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-05-2011, 08:29 PM   #16
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Originally Posted by syldrin View Post
i thought that was the offset on the greddy FRS' rims
Those were +45
http://speedhunters.com/archive/2011...-greddy-b.aspx
The RAYS Progressiv forged wheels measured 19x8.5 +45 at the front and 19x9.5 +45 at the rear. The front brakes were fitted with four-piston GReddy calipers.
Old 12-05-2011, 08:33 PM   #17
coyote
coyote's Avatar
Drives: Slowly
Tyre selection dictates rim width, not the other way around.
coyote is offline   Reply With Quote
Old 12-05-2011, 08:41 PM   #18
LSxJunkie
LSxJunkie's Avatar
Drives: Car
The details suspension pics in some thread (they've all run together in my head now) showed that there was.. and the fenders are prerolled according to the guys at the Scion reveal and some magazines, so that's awesome
Also, coilovers in theory should take up less space, so even wider wheels will be possible then.
For most people though, anything beyong a 8.5" wheel is going to be either for looks (deep dish) or autocross/track so they can fit really wide tires on the car... or for drifters to stretch 205s over a 10" wheel or whatever the heck they do.
But, like, stretching tires totally gives me better steering response and stuff. I need it for control in corners and stuff. Plus I can run lower offsets and that means wider track man!
LSxJunkie is offline   Reply With Quote
Old 12-06-2011, 10:06 AM   #19
Harinjo
Harinjo's Avatar
i think they are 7" wide (i drive currently 215/45 R17 @ 17x7 on my daily and it looks same)
more important for me is - which offset the oem wheels are?!
Harinjo is offline   Reply With Quote
Old 12-09-2011, 03:57 PM   #20
colatkitty
colatkitty's Avatar
Drives: S2000, Z4M
OEM Wheel width?
I've tried looking for the specs of the OEM wheels, but can't seem to find the definitive answer. Are the stock 17" wheels 7 or 7.5" wide? How about the offset, 45?
Definitely nobody will know the weight, but they don't look particularly heavy. I'm guessing around 18lbs.
I'm really hoping that I can run at least a 9" wide wheel for the car, but there just don't seem to be much choices out there for a 5x100 bolt pattern...
colatkitty is offline   Reply With Quote
Old 12-09-2011, 03:59 PM   #21
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
7"
20lbs.
Offset has not been stated that I can remember.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-09-2011, 04:00 PM   #22
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Also see this thread: http://www.ft86club.com/forums/showthread.php?t=2682
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-09-2011, 08:35 PM   #23
RRnold
2 wheel member
RRnold's Avatar
I'm not sure if you were doing it on purpose but you linked this same thread!
Old 12-09-2011, 08:54 PM   #24
fatoni
why?
Old 12-09-2011, 09:15 PM   #25
RRnold
2 wheel member
RRnold's Avatar
It is mentioned 17x7
http://www.insideline.com/subaru/brz...rst-drive.html
Wheel size17-by-7 inches front and rear
Edward Loh's BRZ twitter
WORLDS FIRST BRZ REVIEW: Edward Loh, our good buddy who happens to also be the new Editor-in-Chief of @Motor Trend Magazine. He also became one of the first to drive the Subaru BRZ a few hours ago in Japan. He just did the world's first BRZ review... Tweeted. Follow him at Twitter.com/edloh. Now. Some highlights:
BRZ stands for Boxer Rear drive Zenith
BRZ Limited adds: Leather/alcantara trimmed seats, fog lamps, rear deck spoiler, 17-inch rims, vented discs (16-in front/15-in rear).
Oh yeah, and NAVIGATION comes standard on BRZ, along with 8-spkr audio sys, soft touch dash, and alu pedal pads!
BRZ std features (Premium): LSD, tilt/telo leather wrapped steering wheel, shift knob, e-brake lever, 6spd manual, cruise ctrl.
BRZ 2nrs: Wheel offset is +48mm; width is 6.5 in for 16 inch wheels, 7 in for 17s. Max wheel diam is 18, maybe 19, w/ 215 fr and 225 rr.
BRZ lat g target is 1g. Btw, Subie considers competitive set Mini Cooper S, HyundaiGenesis Coupe, MX-5, GTI, Civic Si, and Scion FR-S.
Top speed limited by 7450rpm fuelcut. In 6th gear, that is about 220kmh or about 136mph. Seems low but #checkmymath
BRZ Cd is 0.27 thanks to diffusers, double bubble roof channel, and rear deck lid spoiler (which smoothes airflow, doesn't add dforce.
BRZ to be available in 7 colors: black, pearl white, dark blue, silver, dark gray, and WRX blue (of course).
More BRZ/FR-S/GT86 trivia: Subaru sez 86x86 mm bore/struck is merely coincidence and not Toyotaorder.
BRZ FA20 engine must take premium b/c of trick D4S port and direct fuel injection. Comp ratio is 12.5:1, yet Subie claims 30mpg hwy!
Light weight pays off big. Brilliant MX-5-like handling but w/ practical 2+2 package. 200hp/150tq, from 2L boxer pushing only 2700lbs
Subaru BRZ should go on sale in May 2012, starting around $24k for Premium and about $27k for Limited. Subie expects sales of 3-4K/yr
Breaking News: According to Subaru a key difference between BRZ n Toyota GT86/Scion FR-S are firmer front n softer rear spring rates 4 BRZ.
Old 12-10-2011, 12:23 AM   #26
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Red face
Someone created a new thread. I posted that then asked Hachi to combine the threads he combined them but didn't delete my post.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-10-2011, 12:47 AM   #27
3scapist
Argues nekkid
3scapist's Avatar
Drives: 08 E92 M3
Am I the only one who's disappointed these cars didn't come with staggered wheels?
3scapist is offline   Reply With Quote
Old 12-10-2011, 12:48 AM   #28
JDLM
JDLM's Avatar
Drives: 2009 BMW 335i
Nope (I can name a couple of cars w/ more HP that have the same size wheels but staggered tires) and that is fine
AWE90/ZSP/ZPP/2XA/NAV/HID/DPE////M/EAS/Disma
JDLM is offline   Reply With Quote
The wheel bolt pattern is... quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 193 02-29-2012 07:04 PM
That steering wheel poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 26 12-04-2011 01:16 AM
Anybody not liking the steering wheel? Levi BRZ First-Gen (2012+) — General Topics 40 12-03-2011 11:43 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 01:28 PM
Wheel fitment sfwg BRZ First-Gen (2012+) — General Topics 6 10-28-2011 07:33 PM
