#15 |
Custom User Title
Drives: Asphalt FR-S MT
Update,
I didn't sleep because I was working on this spoiler. I took a nap around 9:15am and woke up around 1:30pm. I'm off to Home Depot (wire for door lights) and Radioshack (side marker LED bulbs and resistor.) @MyRx @Sonolin @ everyone else ![]() Under the shell is a lightly modified TT-01E. I would not recommend the RTR for two reasons. (1) The car is not desirable in its RTR state. You need to start from scratch to install the essential parts. (2) I honestly do not know what kind of transmitter you get. You end up spending less with your own setup than you would if you bought the RTR and switched stuff. Essential upgrades: - bearings (stock comes with these plastic bushings...what )- aluminum drivshaft I also have adjustable upper arms, but they aren't necessary. I do want some decent shocks though. Load out: - stock brushed motor (plenty for drifting) - stock ESC - Spektrum SR200 Receiver with a Dx2e transmitter - Turnigy 3600mah 2S 30-40C discharge. - HPI T-Drift Tires Want: - 4300kv-5000kv 4 pole Brushless 3650 Inrunner - appropriate brushless ESC - Real oil dampened shocks - lower offset (which I think is actually higher offset in the RC world) wheels that match what I'll be putting on the real thing. This will be my show build. It will only be driven if the ground is near free of debri (sand, rocks, parking stops, curbs...etc). I had to cut my old body to get the spoiler off, but I'll patch that up to the best of my abilities. The original plan was to use that one as a beater. The problem is that Tamiya is so generous, they provide the bodies with the mounting holes already cut/drilled out. Oh well though. I'll be velcroing it.
#16 |
Custom User Title
Just for gits and shiggles.
Sent from my mind using telepathy.
| The Following User Says Thank You to boredom.is.me For This Useful Post: | MyRx (05-20-2013) |
#17 |
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
So you want yours to look like mine?
#19 | |
Good luck with your build. Can't wait for the result. Thanks for sharing.
#20 |
Sarcastic Bastard
Please post a picture of the chassis without the body. Also, motors are not rated like that anymore. They are rated by Stator turns of wire. The motor in the car picture was a 13.5. The lower the number the faster the motor. The car in my picture has more motor than you could ever use without gearing down a ton.
#21 | ||
Custom User Title
I've been building and flying RC planes, boats, hovercraft, and more for years. I'm in no way new to this.
#22 |
Custom User Title
Here is a few of my more recent stuff.
My 5" class fiberglass race boat. It's new and I haven't had much time to get it going. Mine is the orange Slick Not me, but my glider. I like to fly this one about 6" off the ground. My 32" beater Slick turned into a night flyer. My now night flyer and its twin. I built both. I micro EDF to mass awareness and made nano class jets possible. The smallest jet in the world (6" I believe) has my ducted fans. He is now working on a 4.5" version of his A10. My precision flyer that lasted one day. What a fun day that was. 12" version of my ultralight aerobatic design. My mCPX next to my 450 (Both sold) MY Zipper. 6.7" wingspan ogival delta design made purely for speed. I still haven't maidened it. Sent from my mind using telepathy.
#23 |
Sarcastic Bastard
Good Luck. Maybe we can race them when I go to Florida next year for the World Championships.
#24 |
Drives: 2020 BRZ tS #54
#25 | ||
Custom User Title
I've never worked with rc clutches before. I swapped a Castle 5700kv into a friend's Traxxas Slash. The clutch doesn't hold though. It did this on the stock motor too. Any ideas?
#26 |
Custom User Title
Here are the chassis pics. The receiver sits on top of the steering servo. I'm repairing the Slash in the background for a friend and put the receiver in it.
#27 | |
clean the slipper plates and check the pads.. if you hold the rear wheels and give it power the fron should push up slightly and adjust to how you drive.. i only race mine on indoor track no basher |
#28 |
Sarcastic Bastard
I'll be at Snowbirds in Orlando with 700 of my closest friends. Thank god for sponsors, I could never justify the cost if I had to pay myself.
Full shocks are easy for that chassis. HPI, Tamiya, Associated and a bunch of others make them. Motor gearing is a little more difficult with the limited adjust-ability of the kit. For a speedo, Novak and Tekin make mid priced ones but they are all brushless now. |
| The Following User Says Thank You to ntron1 For This Useful Post: | marky (05-20-2013) |
| FRS300 Rebuild Has Begun..Blown Motor to Built Monster | FA20Club.com | Forced Induction | 917 | 10-20-2013 06:26 AM |
| How often to rebuild coilovers or stock shocks? | stockysnail | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 12-24-2012 12:54 PM |
| Mini NSX | M-17 | Other Vehicles & General Automotive Discussions | 43 | 11-09-2012 10:10 AM |
| My Mini FR-S | Supermassive | Off-Topic Lounge [WARNING: NO POLITICS] | 13 | 08-23-2012 01:53 PM |
| What about that 1.5L Mini FT? | LexusFman | Scion FR-S / Toyota 86 GT86 General Forum | 39 | 04-10-2011 09:54 PM |
