Northwest AK, ID, OR, WA
Old 04-30-2013, 01:46 AM   #29
kioton32
kioton32's Avatar
Drives: 14' Monogram FRS, ulramarine, white
Originally Posted by ramiram1984 View Post
Not unless you go with a stronger tranny :P
In the stock form the Automatic tranny can handle 450 HP and 425 lb/ft of torque... The manual can only handle 220 hp and 200 lb/ft torque before the clutch starts slipping... That's what I was referring to. So at 220 hp you have to upgrade the clutch.
whether it be low and slow, fast and loud, or riding on rails, make it unique and make it your own.
kioton32 is offline   Reply With Quote
Old 04-30-2013, 02:21 AM   #30
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
The Perrin car is at 300whp on stock clutch, there are AVO cars running 250+whp and 220+wtq on stock clutch.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
Old 04-30-2013, 02:44 AM   #31
kioton32
kioton32's Avatar
I said it starts slipping at 220... Not that you have to upgrade it... But its highly recommended...
Old 05-18-2013, 05:07 PM   #32
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
@BRZPDX 10 bucks for dyno results!
Old 05-18-2013, 10:28 PM   #33
kioton32
kioton32's Avatar
Ok, so I got my baseline numbers and my numbers after the exhaust was installed... Baseline was 146.3 HP and 120.2 lb/ft torque... After doing my exhaust I'm sitting at 167.3 HP and 145.8 lb/ft of torque now I need to get a full tune for it and ill be good to go or my F/I kit... I like the numbers so far but still have some of the torque dip problems... They should go away when I get the full tune done.
Old 05-19-2013, 01:56 PM   #34
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
Was the dyno done on the same day? Its hard to believe a 21hp and 25 lb torque gain from a cat back exhaust on a n/a 2L engine. Is this with a base map tune or just bolt on exhaust without the tune?
Just for reference, I have a catless front pipe, 2.5in Invidia N1, Perrin CAI, LWCP, and a open source custom tune with BRZedit, and gained about 13hp / 15 lb torque.
If your numbers are 100% correct, then your bolt on parts will be the highest power upgrade I have ever witnessed on this forum, including headers w/o a tune. A bolt-on header gains about 5hp w/o a tune.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
The Following 3 Users Say Thank You to BRZPDX For This Useful Post:
Freeman (05-19-2013), NickFRS (05-19-2013), Zaneman (05-19-2013)
Old 05-19-2013, 08:57 PM   #35
kioton32
kioton32's Avatar
It wasn't on the same day but the ambient temp was only 2 degrees different... I dont have a tune from brzedit or fa20club or anything like that but I did do a little tuning of the air/fuel mix and some rpm changes... Nothing major... I was surprised by the numbers on the Dyno as well... I'm gunna tun it again when I get my header and overpipe as well... Gunna do another baseline and then with the header and overpipe...
Old 05-21-2013, 12:34 AM   #36
BRZPDX
Boosted Member
BRZPDX's Avatar
For sure, I need to see that result!
BRZedit Drive By Wire Info mad_sb Engine, Exhaust, Transmission 20 03-20-2021 01:19 PM
BRZEdit (ECUEdit) illmatic Software Tuning 246 06-02-2016 01:15 PM
BRZedit Cam Tuning Info mad_sb Engine, Exhaust, Transmission 11 01-25-2015 04:58 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 12:20 PM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
