Old 05-05-2013, 06:33 PM   #323
vtmike
vtmike's Avatar
Drives: Scion FR-S
Originally Posted by soros151 View Post
I have recorded lower values. But that tends to be the ECU configuration believe.
Sent from my HTC VLE_U using Tapatalk 2
Ok thanks. I ask because I recently got a dyno that was showing really rich conditions during the torque dip (below 10.) But when I tried to do some logs using torque it would constantly show this same value everywhere during full throttle.
Sent from my Nexus 7 using Tapatalk HD
vtmike is offline   Reply With Quote
Old 05-06-2013, 01:30 AM   #324
cfusionpm
Drives: Firestorm 6MT Scion FR-S
Originally Posted by Brody602 View Post
Can anyone make something like this? Just a couple ideas, one is just a little tray with a lip coming from underneath the HVAC controls, the other is two brackets on each side, maybe with a rubber line to prevent movement? Out of plastic or fiberglass? I'd probably wrap it in carbon fiber anyways, and I don't want a permanent solution, so I'd probably stick the side brackets with 3M tape, or the tray under the HVAC controls might be able to just be tucked under?
I would love something like that for my nexus!
......to Home Depot!
2013 Firestorm 6MT Scion FR-S
cfusionpm is offline   Reply With Quote
Old 05-07-2013, 07:42 AM   #325
Flasher
Smartass
Flasher's Avatar
Drives: Toyota GT86 & Impreza STi
Originally Posted by developer
It seems to be much more accurate than the default fuel percentage that is in Torque.
PID: 2129
Long name: Fuel Remain (or whatever you want)
Short name: Fuel Remain (or whatever you want)
Minimum Value: 0.0
Maximum Value: 100.0
scale: x1
Unit: Gal
Equation: ((A*13.2)/100)
OBD Header: 7c0
If you want the fuel remaining in Liters:
Unit: L
Equation: ((A*50)/100)
Hmm - this doesn't seem to work for me. I checked the level in torque and it was showing 11 L left. After filling up the fuel tank with ~39 L it was showing a level of 47.5 L. but it should be 50 litres. Already checked the equation and couldn't find any mistake. Any suggestions?
Flasher is offline   Reply With Quote
Old 05-12-2013, 11:56 PM   #326
Hawk
Drives: Red 86 GTS and GU Patrol
Same thing happend to me yesterday. Had 8L left in the tank and was able to fill exactly 42.1 L. Torque showed 47.5 L fuel level.
I suspect our tank has a sender that is operated with a float like most cars.
When the float reaches the top of the tank, the float stops but you will be able to fill more. All my previous cars ( analogue fuel gauge) acted like that.
I had to drive about 50 km to see the needle droping.
I will check in the next days after how many k's torque will show a drop in fuel level.
Hawk is offline   Reply With Quote
Old 05-13-2013, 03:56 AM   #327
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
I'm sure that is the case. It also explains why nearly all fuel gauges stay at full for quite a few miles before starting to fall.
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
Old 05-17-2013, 11:27 PM   #328
Yruyur
Yruyur's Avatar
Ok someone make this custom pid.
Miles remaining on tank.
As long as you can use variables returned from other pids already, it should work....I think
(Fuel remaining %) * (13.2 gallon tank) * (current mpg)
The Following User Says Thank You to Yruyur For This Useful Post:
cfusionpm (05-18-2013)
Old 05-18-2013, 08:00 AM   #329
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
It wouldn't trust it. I monitor the fuel remaining % regularly for autocross, and it's highly variable. Seems to change with how hard you drive the car. Though you could compensate for that with a less variable mpg number...
Old 05-18-2013, 10:29 AM   #330
Yruyur
Yruyur's Avatar
The slushing around of the fuel probably threw it off. I was thinking more for freeway or street use which would probably be more accurate. Would have liked it on my Prescott drive yesterday.
Old 05-24-2013, 02:33 PM   #331
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I still cant get the oil temp reading to work. Torque Pro, Nexus 4, AGPtek® Super Mini ELM327.
I'm following the guide on the first page, all my settings are the same. What should I try next? I entered in the PID and it still isn't registering.
post_break is offline   Reply With Quote
Old 05-24-2013, 02:42 PM   #332
Yruyur
Yruyur's Avatar
Take a screen shot of your settings.
Something I have seen others do is to select the supplied oil temp gauge when adding a display. Make sure you use the custom named one you built.
Old 05-24-2013, 02:55 PM   #333
post_break
post_break's Avatar
Never mind I got it working. Had to restart everything a bunch of times.
Old 05-24-2013, 07:16 PM   #334
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Can someone tell me how I tell Torque to stop logging g? In my logs it displays "G(x),G(y), G(z),G(calibrated)" even though I do not have any of those values listed in the "Select what to log" options.
Old 06-03-2013, 10:50 AM   #335
Kamran
Pepe Le Pew Wannabe
Kamran's Avatar
I was wondering if any one of you know of known issues with ELM327 Minis going bad after a while?
My android can still find the Bluetooth device (ELM327) and when I select it, it prompts me with to enter the code, which I input. My cell phone shows connecting/pairing with the device for a split second and then drops the pairing, without connecting! I've tried many times, on many different days, unplugging and plugging back, etc, and still the same.
So to locate the problem, I gave my phone and my ELM327 to a friend and asked him to see if he can connect using my ELM327, his phone and his car. But no luck there either!
What was even more strange is that he no longer can connect to his own ELM327 after I tried his elm in my car!
He tried any combination of my cell phone or his cell phone, his ELM327 or mine, and no luck at all.
The only thing I can think of is that these cheap ELM327 Minis go bad after a few use.
There is a newer version V2.1 on Ebay now (the blue ones were V1.5). Not sure if the V2.1 is any better...?
Your thoughts or feedback would be appreciated.
My middle age crisis started prematurely… at 16!
I'm also independently very, very..... dependent!
Kamran is offline   Reply With Quote
Old 06-03-2013, 10:52 PM   #336
Sensisnow
Drives: 05 TSX & 13 BRZ
What version of android are you running? The newest update to 4.2.2 has some bluetooth issues. Mine used to connect quickly every time, but since the update to 4.2.2 it can be hit or miss. Sometimes it will connect on the first try, but other times it will just continually search for my bluetooth adapter. It will usually connect to the radio just fine, but I've had issues with that from time to time as well.
Sensisnow is offline   Reply With Quote
The Following User Says Thank You to Sensisnow For This Useful Post:
Kamran (06-05-2013)
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
