Old 05-17-2013, 10:19 PM   #1
Cal3000
Drives: Panda FR-S
Is engine knock normal for the FA20?
I logged some data while driving home. I have a tune. Apparently knock correction is occurring 5-8 time every 5 minutes while cruising. Is that normal? Doesn't seem good. I'm on 91 octane.
Cal3000 is offline   Reply With Quote
Old 05-17-2013, 10:44 PM   #2
Allch Chcar
Drives: N/A
According to the manual, some is normal on 91 octane. Serious knocking would be audible (with the windows down).
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 05-17-2013, 11:01 PM   #3
Cal3000
Drives: Panda FR-S
Audible would be knock corrections under -3 degrees if I remember.
Old 05-17-2013, 11:07 PM   #4
AVOturboworld
That's 91 octane for you.
Old 05-18-2013, 12:21 AM   #5
Cal3000
Drives: Panda FR-S
I'll probably put the stock map back on tomorrow and see how that looks. As long as there is no engine damage, I'm ok with a little knock
Old 05-18-2013, 12:18 PM   #6
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
why can't we have decent gas in this country???
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 05-18-2013, 04:55 PM   #7
Mobius357
Drives: '15 WRX '13 Legacy '07 Colorado
My car seems to run well on the 93 we have here. Use to have 94 too, but I haven't seen that for a while.
Mobius357 is offline   Reply With Quote
Old 05-18-2013, 06:57 PM   #8
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
Politicians.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 05-18-2013, 07:02 PM   #9
Visconti
Drives: 05 STi
Depends when it happens.. WOT old be a problem , but normal driving isn't such a big deal...these ecus have a advanced knock control system and normally can deal with this stuff pretty well
john
Visconti is offline   Reply With Quote
Old 05-18-2013, 08:08 PM   #10
Cal3000
Drives: Panda FR-S
john
Thanks for letting me know this.
I slapped back on the stock map and still knocking. ECU resets itself after flashing right? All these graphs are from Shell 91 octane.
Old 05-19-2013, 11:32 AM   #11
arghx7
Drives: car
You'd be surprised how many new engines run like this. It's not just an FA20 thing. It's to maximize gas mileage and sense the octane level.
Old 05-19-2013, 12:12 PM   #12
A5D5TRYR
A5D5TRYR's Avatar
Drives: FR-S 6MT Ultramarine (BeeDrill)
Yeah, I think it's the same reason the new direct injection high compression V6's in the new pony cars can run regular. Same with the Genesis 2.0T and I think the new Focus ST can run regular as well even though it's turboed.
2013 Scion FR-S - Ultramarine 6MT
A5D5TRYR is offline   Reply With Quote
Old 05-19-2013, 02:56 PM   #13
Allch Chcar
Drives: N/A
Premium unleaded is a tiny fraction of Gasoline use because it's significantly more expensive. Things have changed in the last 10 years, can you guess why?
http://www.eia.gov/todayinenergy/detail.cfm?id=11131
-Allch Chcar
Old 05-20-2013, 07:33 AM   #14
Dynotronics1
If it the calibration is set perfectly for your car and your fuel, then no they should be no KR. A 1.0 pull every once in a while on a 1 AM is fine, and will not cause any issues, but what your displaying looks like it needs a bit more work. I'm sure your tuner will finish it up, assuming you are sending logs
Dynotronics1 is offline   Reply With Quote
Engine Knock sound issue nos145 Issues | Warranty | Recalls / TSB 65 10-20-2019 04:57 PM
FA20 Engine component photos Crawford FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 89 02-22-2016 02:31 AM
Normal Engine Coolant Temps? Dezoris Engine, Exhaust, Transmission 1 04-05-2013 03:17 PM
anyone experience engine knock on 91 octane? chenshuo BRZ First-Gen (2012+) — General Topics 15 01-13-2013 07:10 PM
