go_a_way1
Old 05-17-2013, 06:05 PM   #1401
Rabble
Drives: Asphalt FR-S
Originally Posted by Slick View Post
For sure, it's only a half-inch wider than the stock wheel. No problems with fitting the OEM tire.
http://www.tirerack.com/wheels/Wheel...ll&sort=Weight
Rabble is offline   Reply With Quote
Old 05-17-2013, 06:08 PM   #1402
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by Rabble View Post
What's the question?
Slick is offline   Reply With Quote
Old 05-17-2013, 06:17 PM   #1403
Rabble
Sorry,
Will these fit on the car? the offset is like +35 compared to +48 stock
Old 05-17-2013, 06:21 PM   #1404
jshadeck
jshadeck's Avatar
Sorry,
That link is 17x7 +48 rims..
jshadeck is offline   Reply With Quote
Old 05-17-2013, 06:28 PM   #1405
Rabble
Oh, where it says 17x7 you have to pick the other one from the drop down. Tire rack is weird like that.
Old 05-17-2013, 06:30 PM   #1406
jshadeck
jshadeck's Avatar
That shows me a 17x7 +38
Old 05-17-2013, 06:32 PM   #1407
Rabble
Those are the ones.
Old 05-17-2013, 06:38 PM   #1408
jshadeck
jshadeck's Avatar
Those are the ones.
Just making sure, u confused me asking about stock tires on a 7.5" and mentioning a 35 offset.
17x7 +38 will be the oem rim size but will move .4" outwards due to the offset
Old 05-17-2013, 06:39 PM   #1409
Rabble
Cool, Thanks!
Old 05-17-2013, 06:43 PM   #1410
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Sorry,
The wheels you linked are 17x7 in either +38 or +45. They would both fit just fine.
They list 18x7.5 in the same offsets, but that would still fit with no issues. Just can't use the stock tires in that case.
Edit...I lag, looks like someone beat me to it.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 05-19-2013, 07:29 AM   #1411
abling2
Drives: toyota gt86 firestorm red
Im planning to buy wheels and tires specs are 18x9.5 +38offset with 255/35/18 tires. what lowering springs would be safe for me to run on without having to roll fenders and zero rubbing issues? thanks
abling2 is offline   Reply With Quote
Old 05-19-2013, 12:06 PM   #1412
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
:-) there are 33 pages of great replies here. Read up and choose your own. That's part of the fun!
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 05-19-2013, 01:14 PM   #1413
FRSTRM
Baby LFA
FRSTRM's Avatar
Drives: Baby LFA
Apologize if these sizes have been touched upon before - wheels really aren't my specialty. I'm considering the Platinum Widow 18"
Brand_____ Platinum
Model _____Widow
Item Weight______30 pounds
Product Dimensions_____18 x 18 x 8 inches
Exterior_____Matte Black with Gloss Black Inserts
Manufacturer Part Number_____212-8818B
Construction_____1-piece
Rim Diameter_____18 inches
Rim Width_____8 inches
Bolt Pattern (Number of Holes)_____10
Bolt Pattern (Pitch Circle Diameter)_____100 millimeters, 4.5 inches
Offset_____42 millimeters
Backspace_____6.15 inches
Hub Bore_____73 millimeters
How would these fit on stock? I may lower in the future, but not by much.
EDIT: I would also likely get 225/40 tires - would this work as well?
(This isn't my car - I own a Firestorm, but this is how it looks on an FRS [images show 17" wheels])
FRSTRM is offline   Reply With Quote
Old 05-19-2013, 03:01 PM   #1414
jshadeck
jshadeck's Avatar
Brand_____Platinum
Model_____Widow
Attachment 37825
Attachment 37826
Attachment 37827
30 pounds? 😬
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
