Old 12-08-2011, 07:50 PM   #71
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I have never seen a N/A 4 cylinder where the auto/dsg is faster than the manual. Only turbo 4 cylinders, 6/8/10/12 cylinders.
SUB-FT86 is offline   Reply With Quote
Old 12-08-2011, 08:25 PM   #72
ydooby
ydooby's Avatar
Drives: Toyota MR2 Supercharged
Originally Posted by SUB-FT86 View Post
How much does 13 gallons weigh? 200+ lbs? I doubt it.
You have to take into account the weight of his fat arse.
ydooby is offline   Reply With Quote
Old 12-08-2011, 10:44 PM   #73
Eldorian
Drives: 04 RX8
When I saw that I chose not to respond to it.
Seriously. The Renesis is a high strung, low displacement, naturally aspirated engine. What the hell do you think they're putting in the Toybaru?
Eldorian is offline   Reply With Quote
Old 12-08-2011, 10:52 PM   #74
ahausheer
Re-member
Drives: Toyota camry
When numbers are publishes I will refer to Consumer Reports. My reason for this is their 0-60 times are from idle, no shenanigans. I like this because I too will not be using shenanigans when I drive it hard.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 12-08-2011, 11:06 PM   #75
ryude
Drives: Volkswagen GTI
Dry weight means no tranny fluid, no motor oil, no fuel, no coolant, and more. It can easily add up to 100+ lbs.
ryude is offline   Reply With Quote
Old 12-08-2011, 11:15 PM   #76
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Lest we forget that this car will have a greater drivetrain loss due to the front engine rwd configuration. Longitudinal transaxles, fwd or longitudinal mid engined cars are both more effiecent. Expect it to be closer to 7 then 6. Fine with me, I'm not buying this car for stoplight duels.
mines13 is offline   Reply With Quote
Old 12-08-2011, 11:42 PM   #77
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
new reviews coming in are guessing "shade over 6" so we seem to be in the ballpark
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 12-08-2011, 11:53 PM   #78
serialk11r
Drives: '06 AM V8V Coupe
Hard to say, usually auto is given widely spaced gears and high final drive because manual is supposed to be "sporty" (how stupid is that), but seeing how they wanted the automatic to have a whiff of sportiness I think it's possible they kept the ratios similar, in which case the faster shifting auto would do better.
Uh not exactly, the Renesis pumps more air than a 2.0L engine per crankshaft revolution. More precisely, 2 crankshaft revolutions will pump the full displacement of the motor into the intake and out the exhaust, while a rotary pumps its full displacement out in 1 crankshaft revolution because it pumps 1.3L worth of air in and then 1.3L of exhaust out together.
That aside, it has >230hp which is quite a bit more than the FR-S.
Old 12-09-2011, 07:54 AM   #79
SUB-FT86
86 Member
:happy0180:
I totally forgot about that. Thanks.
My RSX has a sporty geared automatic and it is .5-.7 seconds slower than the base manual at 7.7 seconds.
Old 12-09-2011, 08:01 AM   #80
serialk11r
Maybe they call it sporty, perhaps you feel like it's sporty, but the ratios are quite a bit lower and far apart http://www.new-cars.com/2004/acura/acura-rsx-specs.html
Auto definitely shifts faster, they're usually plagued by crap ratios.
Actually looking at that chart I totally understand why you complain about your car now, the manual transmission has 17% higher gearing in 1st, combined with torque converter slippage, ouch.
Old 12-09-2011, 09:35 AM   #81
Matador
hashiryu
Drives: Mk4 Supra
Said the Stig's fat American cousin.....
Exactly. Witness the weights Ferrari claims for their cars and then witness the weight they test at.
Welcome to FT86club.com
The 'FT' stands for 'forgot topic'.
Matador is offline   Reply With Quote
Old 12-09-2011, 09:46 AM   #82
WhippleDip
Drives: 2001 BMW 330Ci
I try and think of the 86 as basically a RWD USDM Integra Type R based solely on the specs.
They both weigh about 2600-2700lbs and have very similar Horsepower and Torque. Based on this information, and factoring in drivetrain power losses on the 86 and Torque Steer on the ITR, they both should be very close, so around 6.5 seconds. I would love to see a drag race between them both, would be interesting to see how close in performance they really are.
WhippleDip is offline   Reply With Quote
Old 12-09-2011, 09:53 AM   #83
Soravia
Drives: Miata Club
It will probably be around RX-8. Less weight, less top power, marginally less torque, but sooner torque delivery. I doubt any difference from RX-8 will make any significant number.
After 60MPH, RX-8 should pull away.
3x 240SX, RX-8 Sport, Sentra Spec V, A4 1.8T Quattro, Miata NB2, Miata NC 2.5
Soravia is offline   Reply With Quote
Old 12-09-2011, 09:54 AM   #84
Soravia
Drives: Miata Club
Nurburgring Video of Subaru BRZ Coupe / Subaru FR-S / Toyota FT-86 Shows off Handling Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 113 11-21-2020 02:02 PM
Handling: Camber Attainable with Struts. Your Experiences? skeeler Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-09-2011 05:07 PM
Forget the NA vs Turbo debate!!!! Midship Runabout Engine, Exhaust, Transmission 69 04-05-2011 06:24 PM
AE86 handling video... Blokatos FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 9 02-07-2010 05:20 AM
