Old 05-14-2013, 09:12 AM   #15
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
Originally Posted by AZP Installs View Post
We have had very good results with both Amsoil and Motul Gear 300. By the way, selling for 15% off retail as a reseller of Amsoil products voids your dealership....
-Mike Paisan
AZP's First Private Track Event, June 19 at NJMP Thunderbolt $315 including Classroom and Mentor!
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
I will like to buy some but I dont know if shipping will be expencive to Puerto Rico because I believe you cant use USPS that is the cheapest way for me to get parts.
kombatlion is offline   Reply With Quote
Old 05-14-2013, 09:40 AM   #16
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I'm running Millers Motorsport CRX 75w90 NT in the trans and diff
• Synchronized transmissions and transaxles
• For dedicated track cars with limited slip transaxles, all types (see FAQ)
• Not suited for street driven cars with clutch type limited slip differentials
DESCRIPTION:
Competition full synthetic transmission oil. A blend of full synthetic base oils incorporating new "Nano Technology" additive chemistry to significantly reduce internal frictional and power losses.
APPLICATION:
Use as received for the lubrication of competition transmissions and differentials which require API GL4 or GL5 performance. Suitable for use in synchromesh and sequential transmissions. Recommended for modern transmissions where full synthetic oil is specified, especially for high performance road and track day applications. For use in all dedicated track cars with synchronized transaxles, including clutch type limited slip differentials.
USER BENEFITS:
• Exceptional cold flow properties for easier gear changes.
• Fast lubrication flow to component extremes on start up.
• Very good oxidation resistance and superior thermal stability.
• Low friction/low drag formula to help reduce operating temperatures.
• High film strength for maximum component protection.
• Significantly reduces friction, temperature, wear and minimizes power loss.
PERFORMANCE PROFILE:
API GL4, API GL5, API MT-1, MIL-PRF-2105E
ZF TE-ML-02B, ZF TE-ML-05B, ZF TE-ML-07A, ZF TE-ML-12B
ZF TE-ML-16F, ZF TE-ML-17B, ZF TE-ML-19C, ZF TE-ML-21B
TYPICAL CHARACTERISTICS:
SAE Viscosity Grade 75w90
Specific Gravity@15°C 0.875
Kinematic Viscosity@100°C 17.3cSt
Brookfield Viscosity@-40°C 88,000mPas
Viscosity Index 152
Great stuff if you track your car.
Old 05-14-2013, 12:02 PM   #17
bluesubie
Drives: 2004 Subaru Forester 2.5XT
Originally Posted by kombatlion View Post
Thanks I was confused I see that others have said that the put Motul Gear 300 on both so I was confused!!!
Some gear oils meet GF5 and GF4 and Motul Gear 300 is one of them.
GL-4; Specified for hypoid gear service under severe service but without shock loading. This classification is essentially obsolete but is still specified by some manual transmission/transaxle manufacturers. Implies an EP/AW additive package that contains 30% to 50% less S-P additives than the GL-5 service classification. Some Marine Gear Lubes fall into this classification, especially the full Synthetic Marine Gear lubes and specialty blenders MT lubes that use high levels of esters.
GL-5; Specified for hypoid gear service but with shock loads and severe service operation. Usually meets Mil-L-2105D and in most cases, is the multipurpose automotive gear oil. Most 75W90 to 75W140 grades meet the GL-5 classification. This grade has a high level of Extreme-Pressure additives that could be mildly corrosive to nonferrous parts, such as brass, bronze and aluminum parts. Most of the modern GL-5 lubes contain metal deactivators that prevents attacks by the extreme-pressure additives. In addition to EP additives, these lubes contain rust inhibitors, defoamants, friction modifiers, thickeners, and Viscosity Index Improvers.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=729255#Post7292 55
-Dennis
bluesubie is offline   Reply With Quote
The Following User Says Thank You to bluesubie For This Useful Post:
kombatlion (05-14-2013)
Old 05-14-2013, 07:20 PM   #18
so26
Drives: Raven FR-S 6MT
Originally Posted by D1cker View Post
I'm running Motul Gear 300 in the trans and diff, very happy with it and the bottles come with a built in fill nipple which makes it that much nicer to do. Seriously I'd pay extra for these bottles if I had to.
I agree, so I transplanted the nipple from the Motul bottle (which I put in the diff.) to the Pentosin bottle to fill the trans. Worked nicely with no need for a transfer pump.
so26 is offline   Reply With Quote
Old 05-14-2013, 09:01 PM   #19
roddy
roddy's Avatar
Drives: '13 Ultramarine
I've been using Pentosin MTF2 for about 8500 miles. I noticed an immediate improvement in shift quality. Good stuff.
Old 05-14-2013, 11:25 PM   #20
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
once my last free oil change is done from dealership ill be switching all fluids with Motul.... Goodspeed will be doing all of my maintenance once my last oil change
SMOKETREES is offline   Reply With Quote
Old 05-15-2013, 09:27 AM   #21
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
Motul Gear 300 all day. Our transmission shifts real nice now.
No Limit Motorsport is offline   Reply With Quote
Old 05-17-2013, 03:34 AM   #22
Trojan_SC
Trojan_SC's Avatar
Drives: '14 Monogram FR-S(RIP)
So let me get this straight because I keep reading conflicting stuff. Can I use Motul Gear 300 in the Tranny, and differential?
Trojan_SC is offline   Reply With Quote
The Following User Says Thank You to Trojan_SC For This Useful Post:
shu5892001 (07-26-2015)
Old 05-17-2013, 10:42 AM   #23
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Yes.
Sellout is offline   Reply With Quote
Old 05-17-2013, 10:50 AM   #24
regal
Drives: Scion FR-S/Toyota Yaris
Thanks for this thread, I found a deal on ebay for 6 quarts for $70 shipped. Its very convenient doing two cars and being able to use the same oil for diff and manual gear box.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 05-17-2013, 11:21 AM   #25
so26
FYI Motul 300 is a little on the thick side compared with some of the other popular choices.
Old 05-17-2013, 12:47 PM   #26
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
I'm doing MT-85 tranny fluid change tomorrow along with the Perrin shift rod bushing. Hope it would make a big difference in shift feel.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 05-17-2013, 03:25 PM   #27
so26
jack stands or lift?
Old 05-17-2013, 07:33 PM   #28
ft86Fan
ft86Fan's Avatar
Jack stands. Don't have a lift. Is that a concern?
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
FS: 1st 86 DGM/Asphalt Scion FR-S (Manual Trans) Neurytic Cars for Sale/Trade 3 05-22-2013 11:54 PM
Trans/Diff Fluid. DanoFA20 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-11-2013 03:11 PM
TRADE: my Silver GT Manual (October Delivery) for Pegasus White GT Manual -AUSTRALIA ysagisan Cars for Sale/Trade 0 09-19-2012 11:24 AM
Got a line on two unclaimed BRZs (manual trans) Tainen BRZ First-Gen (2012+) — General Topics 0 07-05-2012 10:40 PM
