Old 03-07-2013, 09:54 PM   #29
mad_sb
Drives: 2013 Asphalt FR-S
The can of the helmhotz is welded to the body of the of the high flow cat on mine so that should further reduce stress on the connection to the main pipe.
The Following User Says Thank You to mad_sb For This Useful Post:
Sportsguy83 (03-07-2013)
Old 03-08-2013, 01:18 AM   #30
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
Here's a picture of mine, high quality stuff IMHO
Cade01 is offline   Reply With Quote
The Following User Says Thank You to Cade01 For This Useful Post:
Alabang 86 (03-08-2013)
Old 03-08-2013, 02:26 PM   #31
sw20kosh
Drives: 2013 Black FR-S
So does the catted pipe + helmholtz work better than the stock pipe in regards to:
a. drone and
b. loudness
There is a bit of 3-4k rpm drone I want to clear up with my cat back and am thinking this resonated nameless pipe might do the trick?
Old 03-08-2013, 03:41 PM   #32
FR-S Matt
a. drone and
b. loudness
The helmholtz might tone down the drone a bit, but loudness, not really if your catback is already loud. The downpipe makes it a bit louder with the cat.
Old 03-08-2013, 04:54 PM   #33
Fenrir
Drives: Mazdaspeed 3
Just to weigh in, I bought one of the first axelback/overpipe kits (same as Tainen, just no helmholtz or header (yet!)) last year, and mine barely drones at all at cruise. That's the original design, high flow cat in the overpipe, and no helmholtz.
Then again, I'm used to straight-pipe peripheral port rotaries, so nothing seems loud anymore...
Fenrir is offline   Reply With Quote
The Following User Says Thank You to Fenrir For This Useful Post:
Sportsguy83 (03-08-2013)
Old 05-08-2013, 01:54 PM   #34
bcmakesiteasy
Drives: 2013 FRS Ultramarine
noob question, but does anyone know if this will fit my auto trans frs with my berk dual exit muffler delete?
bcmakesiteasy is offline   Reply With Quote
Old 05-08-2013, 02:23 PM   #35
Tainen
Drives: First SWP BRZ-L
I believe their latest design is auto friendly now. Call them up to be double sure.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
The Following User Says Thank You to Tainen For This Useful Post:
bcmakesiteasy (05-08-2013)
Old 05-17-2013, 02:52 AM   #36
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Originally Posted by Xdragonxb0i View Post
for those of you who do have it, do you guys think its worth it? I want the performance gains but near stock level sounds. So i will get a high flow cat, is the resonator needed?
I ran the nameless axle back for about a month while waiting on my front pipe. I got a newer offset axle back and it was supposed to be pretty quiet. I thought it was too loud. After installing the front pipe with the helmholtz chamber...I was very surprised how quiet it made the entire system. It's back to being nearly stock levels at cruise and sounds even meaner at wot. I got one of the newest revisions with the helmholtz located at the back of the pipe.
Nameless has a great rep for a reason. This front pipe is amazing. It's completely win-win. More power, high flow cat, less drone, more aggression, no rasp and impeccable craftsmanship. Now if they would only release their header....
industrial is offline   Reply With Quote
Old 05-18-2013, 01:10 AM   #37
CodyFRS
CodyFRS's Avatar
Drives: Asphalt FRS
Living in PA, so I have emissions. Driving an Automatic FR-S.
Price isn't really a matter. Which of this would be the best choice of the 4?
Basically what is the Meaning of SS/TI?
http://ft86speedfactory.com/search/r...x=-1136&y=-163
CodyFRS is offline   Reply With Quote
Old 06-24-2013, 05:43 PM   #38
wawro569
Drives: 2013 Scion FR-S MT
Looking to pull the trigger on this overpipe/frontpipe combo with helmholtz today. I've done as much research as I could on this and so far it looks absolutely amazing, was wondering if I could get some opinions/reviews from current owners of this part just out of curiosity.
wawro569 is offline   Reply With Quote
Old 09-23-2013, 12:58 AM   #39
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Yes it's worth it!
Helmholtz Resonator on Automatic Transmission equipped FRS
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 09-23-2013, 01:51 PM   #40
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Saw this bumped so I thought I might chime in with some updated info. I have added a JDL UEL header and the car is crazy loud now. Strangely enough, it doesn't drone at all. Thank you Nameless.
The Following 2 Users Say Thank You to industrial For This Useful Post:
tonystewart (09-23-2013), YouShallKnow (03-16-2015)
Old 11-29-2013, 01:15 AM   #41
hyper4mance
hyper4mance's Avatar
Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
I'm assuming this is the the helm reso? I have the JDL uel as well and I'm considering the one piece over and front pipe with HFC with a tame cat back like 2.5" resonated perrin. I guess my question is it recommended to have the helm reso with a setup like that? Currently the uel header with stock headerback is ok in terms of loudness, maybe just a hair more would be perfect without drone.
hyper4mance is offline   Reply With Quote
Old 11-29-2013, 10:54 AM   #42
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
The Helmholtz resonator is designed specifically for drone not volume....
The nameless one is designed for their header but as industrial mentioned it worked for the JDL as well.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Will Helmholtz resonator decrease power? shu5892001 Engine, Exhaust, Transmission 31 01-07-2015 09:37 AM
Agency Power Front/Over pipe (Combo pipe) - Cheap! seven Engine, Exhaust, Bolt-Ons 12 03-09-2013 01:40 AM
Will a resonated front pipe make alot less noise than test pipe? Mike86 Engine, Exhaust, Transmission 8 01-26-2013 07:24 PM
Ordering Nameless Exhaust - Helmholtz Resonator?? Umbie Engine, Exhaust, Transmission 16 12-03-2012 01:48 PM
