go_a_way1
Old 05-16-2013, 02:51 PM   #1387
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by Aydhayeth View Post
And what ET would be recommended in the rear with 9.5? Don't want it sticking out.
That's a lot of rubber, I like a little stretch for the looks. But keep wheelgap the same or less as stock.
+40 offset.
See here:
http://www.ft86club.com/forums/showthread.php?t=36710
Great timing...
Slick is offline   Reply With Quote
Old 05-16-2013, 02:59 PM   #1388
Aydhayeth
Drives: Corolla, GT86
Cheers mate.. I will make a topic once I get the car
Aydhayeth is offline   Reply With Quote
Old 05-16-2013, 11:57 PM   #1389
abling2
Drives: toyota gt86 firestorm red
Im planning to buy work emotions cr kai 18x9.5 +38 offset w/ 255/35/18 tires on them. what lowering springs would be the best for me without having to roll my fenders or not having a rubbing issues on any fenders, and not have to adjust my camber please let me know. and by the way how are the tpms sensor gonna work now if I buy/install these sets of wheels? do i have to get customize sensor? or what? and will lowering the car would void any type of warranty thanks
Avelino
abling2 is offline   Reply With Quote
Old 05-17-2013, 03:25 AM   #1390
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Avelino
Regarding the TPMS, you can just have the shop yank 'em off your stock wheels and put them on the new ones. I wasn't even charged extra for it.
If you get new sensors, you not only have to pay for them but you also have to pay the dealer to register them to your car. I wouldn't. Either get them swapped or deal with the yellow light.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 05-17-2013, 11:59 AM   #1391
Aydhayeth
Another question
Using the calculator on the site ( I'm assuming it's accurate )
I'd need to have 225's on the front for some stretch and 235's on the rear.
Yay/nay? Or am I missing something?
For those who don't know what wheels I'm looking at:
Front 18x.8.5J ET40
Rear 19x9.5J ET40
Old 05-17-2013, 12:11 PM   #1392
Slick
Slick's Avatar
Another question
Front 18x.8.5J ET40
Rear 19x9.5J ET40
I'd recommend 225/40 for fronts and 245/35 for rears for proper sizing if you want "some stretch", also can fit 255's.
Ideal tire widths (i.e. no stretch) would be 245/35 for the 8.5" fronts and 265 or 275 for the 9.5" rear wheels.
Old 05-17-2013, 12:43 PM   #1393
2point0
2point0's Avatar
^My STi's stock setup was slightly stretched at 245 (/40 I think) on a 18x8.5" wheel. I had to be careful setting them down as the tire wouldn't protect the rim.
The tire design will make a big difference here, though.
The Following User Says Thank You to 2point0 For This Useful Post:
Aydhayeth (05-17-2013)
Old 05-17-2013, 12:53 PM   #1394
Aydhayeth
Got any pictures by any chance?
Old 05-17-2013, 01:37 PM   #1395
2point0
2point0's Avatar
This is the best I have. Doesn't show really well, though.
But like I said, it's a really slight bit of stretch. The same size Federals would probably be square or even bulge a tad.
Sometimes I think I should have kept these.
Old 05-17-2013, 01:47 PM   #1396
Slick
Slick's Avatar
Yes, different makes are different widths.
i.e. a Conti 245 may be narrower/wider than a Bridgestone 245, but within each brand (or model) they are comparable to each other.
Same goes for treadwear ratings, they mean nothing unless compared within the brand.
My Contis are listed as a 340 treadwear, but they are comparable to other brands in the 200's. As a sharp contrast, the stock Michelin Primacy are rated at 240 treadwear. No way are they stickier than the Contis!
Here are some pics of my Conti Extreme Contact DW in a 245/35R18 on a 9" wheel.
vs stock wheel & stock sized Michelin winter:
from inside the wheelwell:
outside view:
Old 05-17-2013, 04:29 PM   #1397
Rabble
Drives: Asphalt FR-S
I've got to buy some new rims today, as in right now. Will 17x7.5s fit the stock tires?
Rabble is offline   Reply With Quote
Old 05-17-2013, 04:30 PM   #1398
mistressmotorsports
This may have been answered, but I am having a hard time finding it. How does the wheel fit chart on the other thread address camber? Specifically, I am wondering if I have a one inch drop, how much camber is required to get a 245 tire on a 18x9 +45 flush in front? Same question but for an 18x9.5 +45 in back. I like the wheel sizes, but I do not want to run tons of camber (or basically more than what a decent handling street car should have.) Thanks.
mistressmotorsports is offline   Reply With Quote
Old 05-17-2013, 04:56 PM   #1399
Slick
Slick's Avatar
For sure, it's only a half-inch wider than the stock wheel. No problems with fitting the OEM tire.
Old 05-17-2013, 05:04 PM   #1400
Slick
Slick's Avatar
Read up through this thread and you will see that 18x9 +45 will not fit well on the front, unless you choose to stay with stock camber and suspension and it is still very close (read: too close) to the strut perch.
And since you state that you will be dropping by 1", you will likely be running at least -1 camber or more if camber bolts are used. So they won't fit for sure.
Adding negative camber will pull the top of the wheel closer to the strut.
I am running 18x9 +35 and only have 7mm clearance between the strut and rim.
Ideal offsets for those wheels sizes would be:
18x9 +35
18x9.5 +40
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
