Old 05-16-2013, 07:51 AM   #407
vtmike
vtmike's Avatar
Drives: Scion FR-S
Originally Posted by xjohnx View Post
How'd she feel on the way to work?!
Idle and throttle response seem smoother. There was some hesitation to the throttle some times when giving it gas from idle before (possibly do to me removing the main resonator), the intake has seemed to cure that. It seems to pull harder everywhere but that could be me wanting to see results for the money spent.
So far I'm liking it.
vtmike is offline   Reply With Quote
Old 05-16-2013, 10:57 AM   #408
JETRED
JETRED's Avatar
Drives: Unicorn
Originally Posted by lavisxice View Post
my butt dyno feels like it it has a lot better low end 1-3k rpm pull
Seems to be the consensus with everyone running this, definitely going to get this after I get a tune!
JETRED is offline   Reply With Quote
The Following User Says Thank You to JETRED For This Useful Post:
lavisxice (05-16-2013)
Old 05-16-2013, 11:14 AM   #409
xjohnx
Grip>Slip
xjohnx's Avatar
It will likely improve after the ECU has some miles on it to relearn. Also we might want to clean your MAF still if you haven't already done that. Mine looked clean to the naked eye, but after spraying the MAF cleaner on the electric contacts you could see it was removing some contamination/oil
Old 05-16-2013, 11:46 AM   #410
Chase86
Drives: Ultramarine FRS
I just had mine installed by the dealer along with a TRD exhaust. Hard to tell any difference because I'd only had it for a couple days/200 miles before that. One thing I do notice is that its really, really loud. Sometimes its so loud I don't really like it. Do any of you notice the same thing??
Chase86 is offline   Reply With Quote
The Following User Says Thank You to Chase86 For This Useful Post:
tripjammer (05-16-2013)
Old 05-16-2013, 12:31 PM   #411
vtmike
vtmike's Avatar
Drives: Scion FR-S
Sprayed off the maf sensor before installing. So far so good. Hopefully the dyno shows some results.
Old 05-16-2013, 04:56 PM   #412
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
Yours is probably loud because of the TRD exhaust! The TRD intake does not add that much noise. It's quieter than the stock box with the silly sound generation tube.
Your TRD exhaust should quiet down after its broken in...
tripjammer is offline   Reply With Quote
Old 05-16-2013, 05:06 PM   #413
torqdork
torqdork's Avatar
Drives: RV-7
What did the dealer charge to install them? I know it's easy enough to DIY, but the warranty advantage would definitely help resale value.
torqdork is offline   Reply With Quote
Old 05-16-2013, 05:16 PM   #414
Chase86
How long is do you think the breakin takes?
Old 05-16-2013, 05:17 PM   #415
Chase86
I had those 2 things and a spoiler installed and all together it was just over $2K.
Old 05-16-2013, 05:44 PM   #416
vtmike
vtmike's Avatar
Drives: Scion FR-S
The ecu must be settling in because the car was definitely pulling harder than it ever has on the way home.
Sent from my Nexus 7 using Tapatalk HD
The Following User Says Thank You to vtmike For This Useful Post:
tripjammer (05-17-2013)
Old 05-16-2013, 07:04 PM   #417
rxpx2012
Drives: FR-S Manual
I only have the TRD intake and my dealer charged $40 plus tax to install it.
rxpx2012 is offline   Reply With Quote
The Following 2 Users Say Thank You to rxpx2012 For This Useful Post:
HotLeopardMama (05-16-2013), tripjammer (05-17-2013)
Old 05-16-2013, 07:20 PM   #418
torqdork
torqdork's Avatar
Drives: RV-7
Did they break out the labor only part of the charge on the repair order?
Old 05-16-2013, 08:12 PM   #419
cslntuee
Drives: Subaru BRZ Limited
Originally Posted by cslntuee View Post
How much for order an Emissions Compliance Label form local Toyota/ Scion dealer?
Thanks.
Any people have idea or experience?
Thanks.
cslntuee is offline   Reply With Quote
Old 05-16-2013, 08:59 PM   #420
NickFRS
Drives: 2013 Asphalt FRS
Yall just paid $350+ for a TRD emblem. My 2 cents... I hope it looks cool under there.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 12:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 08:06 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 01:31 PM
