#2507 |
I Love custom Turbo kits
Drives: Limited BRZ
I had to google it, well played Paul.. (as usual!!)
#2508 |
Drives: 2012 Toyota 86
haha i think going to cuba is more illegal than braking traffic laws.
#2509 |
Drives: AVO BRZ
Just passed 375whp on e70.
#2510 |
Boosted
Drives: Not a supra....yet
#2511 |
Drives: AVO BRZ
That was just over 14 psi. Altitude 0, atmospheric pressure 14.7psi, ambient air temp 65f, fuel caltex e85, which is reading approx 72% here in winter time.
The car has stock air box, with snorkel delete and an avo panel filter. A slightly widened version of the avo dump pipe, then full 2.5" perrin exhaust with cat, but no resonator. Also a perrin crank pulley and lightweight flywheel. Here's some rough numbers from the flex tuning, converted to dynojet bhp using a 165bhp baseline. stock 98 ron 165 bhp (108 kw) 4.5 psi avo base map 212 bhp 6 psi 98 ron 250 bhp 9 psi 98 ron 275 bhp 9 psi e44 325 bhp 12 psi e44 345 bhp 13.5 psi e70 365 bhp (241 kw) After that a vac line under the intake manifold blew off, so they've fixed it and gone to lunch. :happy0180:
#2512 |
Pegasus White
Drives: 86
I want to see 300rkw!!!
Driving: Pegasus White Manual GTS 86.
#2513 |
Boosted
i think the current kit is reaching its limits ( Turbo, and IC wise)
#2514 | |
Anyway, very good numbers and really cool to see some testing with the corn juice!
#2515 | |
Boosted
#2516 |
Nincumpoops...
Sent from my Galaxy Nexus using Tapatalk 2 |
#2517 |
If I can make 285whp on a mustang dyno, which is over 300whp on a dynojet.. I would expect at least 350whp on e85
John |
#2518 |
Drives: AVO BRZ
Sorry it's at the wheels, multiplied by 14% going from the baselines (144 vs 165 whp).
I'll post sheets when I have them. With this intake/exhaust/turbo spec things will be getting restrictive, and Morpowa are going to do some back pressure testing on it. I think 260 rwkw would be asking a lot without at least going to a big pod filter. So in American terms I'd put the limit of the avo stage 2 hardware, with stock airbox and 2.5" exhaust at approx 400 whp. But I did hear something about a new wheel and housing...
#2519 | |
What clutch do you have ? |
#2520 | |
Drives: BRZ WRB
which 98ron limits could you estimate based on your experience - psi\bhp-wise? It should be knock-warning, right? meaning you can't go any further without a risk |
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 09:59 PM |
| FT-86 SpeedFactory - Firestorm Red - Build Thread | FT-86 SpeedFactory | Member's Car Journals | 38 | 02-26-2015 02:42 PM |
| JoeBoxer FR-S build thread | JoeBoxer | Member's Car Journals | 112 | 04-08-2013 01:19 AM |
| Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? | fred_boosted | Engine, Exhaust, Transmission | 215 | 12-12-2011 07:23 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
