AVOturboworld
Old 05-14-2013, 01:19 PM   #2493
Sonolin
I'm getting very curious about this kit!
After some more research this really seems like the kit to buy for a track car & dd. I have a few questions:
1) What PSI is your dyno on page 1?
2) Why is the dyno on page 1 ~15 whp lower than, for example, the drift office tuned car at ~5.8 PSI (that resulted in ~245whp)? That car was done on 91 octane as said in that thread, so I'm a little confused. Is 15whp from simply fine tuning, or more PSI, or..?
3) Do you guys offer a "track ready" kit? Will this kit come with adequate cooling to run this car at a track for hard 45 minute sessions?
4) How hard/how much time would it take to "reverse" this turbo kit? (Just the turbo & header, and plugging up any vacuum lines, etc.) Just curious on how hard the overall process for this would be, it doesn't look to hard as everything seems concise and easy to reach correct? The only major item looks to be simply the turbo + header right?
5) Do you offer any e85 tunes and/or dynos? Has this car been tested with e85? I'd probably go Visconti at that point but just curious what you guys offer
Thank you very much! Your definitely the top competitor in my mind at the moment for forced induction, when the funds allow...
Sonolin is offline   Reply With Quote
Old 05-14-2013, 06:15 PM   #2494
AVOturboworld
That is our old 5psi actuator. It was running about 5.5 at peak, and backing off to 4psi at the top end. The chart doesn't reflect the current kit specs (better 6psi actuator, better exhaust manifold), but it's accurate in terms of our kit on the same car, baseline stock vs. baseline turbo kit. I'm seeing about getting that chart updated in the next week or two with current hardware.
A bit more power from tuning, and the boost probably went up slightly due to the tuning. Our power chart is based upon an off-the-shelf tune on a stock car (except for the turbo kit itself), that possibly will be running 91 octane. It's not a chart based on max possible if you do X+Y+F+turbokit, it's based on what you get if you bolt it in, change the oil, and flash the base map to the car.
We do have some hardware specific to the track, though to be honest, it's just a couple of extra's for insurance. The first thing to decide is the power that you will be running at the track, that will determine how much you'll need to work on the cooling. If you are just running base 5~6psi vs. 10~15psi, for instance.
While we have run the kit on the track for extended periods without issues on our car in Japan, I will note that it was near to/at the limits of the standard cooling at that point. But then, from testing data we retrieved from some n/a cars at the same event, even in n/a form it's close to those limits. If you are going to do extended track time, an oil cooler is definitely recommended. A more efficient radiator will help as well.
But the key word there is efficient. A larger radiator may take a bit longer to get too hot - but once it is too hot, it can also stay too hot longer than a smaller radiator.
If you are not touching the front mount intercooler, it's a fairly quick job. You need to unbolt the turbo kit from the car (remove undertray, unbolt exhaust manifold from engine, unbolt turbo discharge from header back exhaust), put the water lines back to stock (ie, don't throw away the stock water line), and remove the oil lines.
We don't, not out of the factory. There's too many different issues to sort with that you cannot do "off the shelf". We prefer to leave that up to the local shop/tuning.
The Following 2 Users Say Thank You to AVOturboworld For This Useful Post:
Sonolin (05-14-2013), Sportsguy83 (05-15-2013)
Old 05-14-2013, 06:43 PM   #2495
Sonolin
Originally Posted by AVOturboworld
We actually answered all your questions for once, something that's rarely, if ever, seen online.
Thank you very much for the detailed and helpful response! Nice change of pace from "other" companies.
I'm getting really excited now, lol. Sounds perfect. And I definitely see the track testing you guys have done, I've been casually following your posts for a while and its very impressive to hear how well its doing. I know others have tested the Vortech supercharger kit and have noted a lot of cooling problems from that (stock) so I'm very glad AVO is holding up well.
My power levels I'm looking at are ~300whp with e85. So somewhere under 10psi (with e85) I hope. Of course, that will need fueling upgrades, clutch, and cooling but I'll be doing a oil cooler and upgraded radiator at that point. Would that be sufficient at that power level? Have you tested any cars with your kit at the track with similar boost/power levels?
I wish more people were doing testing with this kit and e85 I don't think I've seen one dyno yet
By a "fairly quick job" can you give me a rough hour quote on that? I know I'm demanding but this is a very important factor for me in my choice of turbo kit . There's plenty of reasons and I need this to be reversible to stock whenever I need to/want to. Under 4 hours would be ideal.
Thank you very much! Great customer support
Old 05-14-2013, 09:44 PM   #2496
AVOturboworld
Fensport in the UK is doing about 300bhp on 9psi with race gas - e85 will actually be a bit easier to put timing into, so it's definitely doable.
Somebody experienced with the kit can probably do it under 4, it's just a matter of knowing where everything goes. When you are doing it the very first time, it takes longer.
The Following User Says Thank You to AVOturboworld For This Useful Post:
Sonolin (05-15-2013)
Old 05-14-2013, 09:53 PM   #2497
Patrix
Patrix's Avatar
Drives: 2013 Scion FR-S Asphalt
I love it! It's look so clean!
Patrix is offline   Reply With Quote
Old 05-15-2013, 01:27 AM   #2498
Sonolin
300bhp on 9psi with race gas?
Strange. I thought I've seen close to 300whp with ~10-11psi on pump?
Old 05-15-2013, 09:00 AM   #2499
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Two new videos added, third one is old but I had not posted it in this thread: Thanks to @raul for being cameraman, he got to drive it as reward
[ame="http://www.youtube.com/watch?v=RTNGjQMSHdU"]Subaru BRZ with AVO Kit more pulls. - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=pj3guGviIsQ"]Subaru BRZ AVO Kit 1-4 Gear Pull - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=W7uqfy6ZAJI"]Subaru BRZ with AVO Kit drive by video - YouTube[/ame]
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
civicdrivr (05-16-2013), Draco_PR23 (05-15-2013), Sonolin (05-15-2013)
Old 05-15-2013, 09:05 AM   #2500
#87
I usually post drunk
#87's Avatar
its funny you hit 113 in that video, that has been the top speed ive reached on so many occasions I wonder what it is about that number ^_^
#87 is offline   Reply With Quote
The Following User Says Thank You to #87 For This Useful Post:
Old 05-15-2013, 12:01 PM   #2501
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Can you list the "plenty of reasons"?
Old 05-15-2013, 12:05 PM   #2502
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
@Sportsguy83 all runs were filmed in Mexico i assume ?
Old 05-15-2013, 12:08 PM   #2503
Sonolin
Reselling, and California, being 2 reasons
Old 05-15-2013, 12:08 PM   #2504
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Cuba acually. Shorter boat ride.
Old 05-15-2013, 12:09 PM   #2505
Sportsguy83
Drives: Limited BRZ
Edit: Cuba actually sounds better, almost real and its closer as @King Tut points out.
Northwest Cuba it is!
Old 05-15-2013, 12:12 PM   #2506
AVOturboworld
All my drives are filmed in the remote tundra of Canuckistan.
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
