Old 11-30-2011, 04:53 PM   #141
Brody8877
Lurker
Drives: 93 Mazda RX-7
Originally Posted by Noble713 View Post
Hmmm, pics of the production cars from Autoblog don't seem to have anything like Brembos.
http://www.autoblog.com/photos/2012-...photo-4643873/
http://www.autoblog.com/photos/2012-...photo-4644196/
They look like the same POS 2-piston front/1-piston rears that were stock on my Evo IV.
Yea, thats what I thought the 4pot didnt make it for the production cut.
Those sliders stop the car just fine. I will bet you as much money as you want that they will provide enough braking force to lock the tires/engage ABS. You get a bit better modulation and pad wear with fixed 4 pots and such, but you'll stop the car just the same assuming everything else is the same.
How much benefit do you think they'll actually give you for the price on a street car where 90% of these cars will stay?
I will have no qualms running those brakes hard on the track. Spec series will likely REQUIRE stock brakes. If they are the same brake parts that stop pig WRXs all day long then they are already more than enough for this lighter, lower powered car.
100% concur with your statement.
93 Mazda RX-7
15 328 w/Msport
18 M3 - Pending
Brody8877 is offline   Reply With Quote
Old 11-30-2011, 06:01 PM   #142
madfast
Drives: 2010 Evo X MR-T
The 4 pots are probably the TRD BBK. in the brochure there is mention of 18" wheels that are compatible with the monoblocks. we now have pics of 18" wheels from the FT II concept, on michelin pilot super sports no less! TONS of space for the 4 pots...
madfast is offline   Reply With Quote
Old 12-08-2011, 12:22 AM   #143
sweetteg
Drives: 98 tegrs, 90 240sx
Originally Posted by LionZoo View Post
If automakers would make more profit by embossing Hello Kitty onto their brake rotors, they'd do it. It's easier for them to charge you $500 for your Hello Kitty rotors that costs an extra $10 to make, rather than spend money trying to educate you by doing an ad campaign about how Hello Kitty rotors don't actually help performance. This thought process applies to everything from the most basic Hyundais all the way to the highest end exotics. In fact, I'd say it applies more to expensive cars since the customers are demanding, but are willing to pay and generally won't take no for an answer
i had to join the site and post this in response. great knowledge/info here, learned alot! and nice sig/car collection dave!
sweetteg is offline   Reply With Quote
Old 12-08-2011, 12:30 AM   #144
JDLM
JDLM's Avatar
Drives: 2009 BMW 335i
I am going to agree w/ what others are "thinking" about digging into the Subaru/WRX/STi parts bin and see what comes out
AWE90/ZSP/ZPP/2XA/NAV/HID/DPE////M/EAS/Disma
JDLM is offline   Reply With Quote
Old 12-08-2011, 01:23 AM   #145
ahausheer
Re-member
Drives: Toyota camry
Hello Kitty knows best. Plain is the way to go. I heard that when Hello Kitty is done racing and takes her helmet off her hair is always purrfect.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 12-08-2011, 03:48 AM   #146
Midnight Run
Action Thriller
Midnight Run's Avatar
Drives: E46M3
Lucky me.. I happen to have a spare set of STi Brembo calipers and 5x100 hubs off 04 STi that can try out when I get the car.
Midnight Run is offline   Reply With Quote
Old 12-08-2011, 10:34 AM   #147
Racecomp Engineering
Old 12-08-2011, 10:43 AM   #148
JDLM
JDLM's Avatar
This is the kind of attitude to have
Old 12-08-2011, 10:58 AM   #149
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
LOL awesome!!! I love that brake setup! And thanks!
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-08-2011, 10:59 AM   #150
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
You wouldn't use the hubs.. but the calipers would likely bolt on, but may need an adapter. What size rotors did the 04 STi have?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-08-2011, 11:04 AM   #151
JDLM
JDLM's Avatar
I am thinking adapter as well
It's just like the IS300 guys fitting Supra/LS brakes on with just simple parts:
Old 12-08-2011, 11:11 AM   #152
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Ok so it looks like a 12.7"x1.2" rotor for the 04 STi, height of 2.08" so a little less than an inch hat height past the rotor face.
2011 WRX (assuming exact same brake setup for BRZ) shows a 11.55"x0.945" with a height of 2.23".
So, that's pretty close to were you may just need 04 STi rotors and calipers. I'm sure people at NASIOC have already done this though so they would know.
At worse you may need to either user spacers on the caliper, or behind the rotor, or trim the caliper or spindle.. it'll all depend on where the caliper sits when bolted to a WRX/BRZ spindle.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-08-2011, 11:15 AM   #153
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Also if you replace the fronts you may want to run the 12.4" rears as well, either with the stock caliper on an adapter or the STI caliper (but I'd guess that would still need an adapter) depending on the resultant brake bias from the additional leverage up front.
The fronts may need an adapter too unless the spindle was the same between the STi and WRX. I don't know subarus enough to know.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-08-2011, 11:25 AM   #154
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Some info from a WRX Forum:
All 04-07 STI front Brembos will bolt right up to the front of any 02-07 WRX. Just purchase 04 STI rotors so the lug pattern will match.
The rears are more complicated.
02-05 WRX will require the adapter bracket, readily available from Kartboy to use brembos on the rear.
06-07 WRX requires nothing, the calipers will bolt right up.
regardless, all WRXs need WRX adapter rotors to ensure the emergency brake works properly. DBA is currently the only manufacturer that makes them. The part number is DBA 2657.
There are other options like "extended" brake shoes, or simply using stock 04 STI rear rotors.... neither would be the correct or "smart" way to do it though. That certainly doesn't mean it hasn't been done though.
All 4 dust shields will need to be removed/drilled out on all 02-07 WRXs to accomodate brembos.
The 06-07 WRX Brake lines will work on Brembos - I'm not sure if earlier year WRXs are interchangeable though - do your research.
So based on that, assuming BRZ spindles are the same as 06-07 WRX it should bolt up for the front.. the reats are worse because the parking brake is a drum instead of using the caliper since they are fixed calipers.
Just replacing the front could screw up the bias and could actually result in unfavorable results. Fine if you are just looking for cooler looking brakes on the street though.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Inside Line's Predictions (Subie Version) GT Engine, Exhaust, Transmission 13 05-23-2014 09:32 AM
PTuning Spec RS *pics inside* Dragonitti Other Vehicles & General Automotive Discussions 121 11-19-2011 11:52 PM
Heritage....inside? Maxim Scion FR-S / Toyota 86 GT86 General Forum 10 01-03-2011 08:17 PM
FT86 concept with a guy inside 4agze Scion FR-S / Toyota 86 GT86 General Forum 2 11-12-2010 03:16 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
