Old 05-14-2013, 06:56 PM   #1
so26
Drives: Raven FR-S 6MT
Brake line degradation
I was under my FR-S today and notice that a portion of the rear brake line has degradation and a couple of the fittings have cracks in them. Has anyone else noticed this? I guess this means a trip to the dealer
BTW the car has 16kmi on it.
so26 is offline   Reply With Quote
Old 05-14-2013, 07:04 PM   #2
Sargy
Long Distance Driver
Sargy's Avatar
hmmm...
Sargy is offline   Reply With Quote
Old 05-14-2013, 07:08 PM   #3
jshadeck
jshadeck's Avatar
Looks like something got on them and ate away the outside? Not sure
jshadeck is offline   Reply With Quote
Old 05-14-2013, 07:09 PM   #4
OrbitalEllipses
Drives: Attitude
Is that an e-brake cable? That doesn't look like a hydraulic brake line; I replaced all four this past weekend.
Old 05-14-2013, 07:12 PM   #5
so26
Not sure, they do seem to be hydraulic lines though ... maybe someone else knows
Old 05-14-2013, 07:15 PM   #6
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Doesn't look pretty. Is this where the under panels would come handy?
Carlitoz3 is offline   Reply With Quote
Old 05-14-2013, 07:55 PM   #7
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Picture one is not brake lines. Those are fuel lines. The fittings pictured are quick-disconnects which aren't used in brake lines for safety reasons. Additionally, except for the lengths between the body and knuckles, brake lines are metal.
The diameters of the lines in the second pictures are too large for brake lines as well.
There's a good amount of undercoating under the car. I think the overspray cracked on the flexible lines and let water get underneath. See if you can remove some of the overspray around the damaged areas with a fingernail or something that won't damage the fuel lines to see if the damage your're seeing is really in the lines.
The Following User Says Thank You to Draco-REX For This Useful Post:
Marrk (05-15-2013)
Old 05-14-2013, 08:29 PM   #8
so26
Originally Posted by Draco-REX View Post
Picture one is not brake lines. Those are fuel lines. ...
Hmmm ... I thought there was only one fuel line coming from the pump?
Old 05-14-2013, 08:47 PM   #9
Draco-REX
Corner Junkie
Draco-REX's Avatar
There's some system to move fuel from one side of the saddle to the other. And I would say there was a return line, but I think I've read that this is a return-less system. (Not sure how the FPR bleeds off excess pump pressure...) There is also the Evaporative Emissions system which will have its own lines.
Those connectors are only used for fuel and coolant, and there's no coolant at the back end of this car.
FR-S/ SBRZ (2013 Al) -PTUNING Braided Stainless Steel Teflon Brake Line Kit!! Freddy@PTUNING Brakes, Suspension, Chassis 33 12-07-2013 02:01 PM
Stainless steel brake line upgrade? 6-Shift Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 06-13-2013 04:43 PM
~D3PE Stainless Braided Brake Line System~ Evan@D3PE Brakes, Suspension, Chassis 6 06-12-2013 03:40 PM
SS Racing Brake Line K1 Motor Works Brakes, Suspension, Chassis 5 06-29-2012 02:36 AM
