#337 |
First 86 Driver Baby!
Drives: FR-S, Flex
Yeah, I saw a few of those in the dash. It would be interesting to find out what all they're for.
#338 | |
Drives: ZN6, DC2
#339 |
Old School Status
Drives: .
After reading a bit of the posts, it started to jump around and I need help from you guys to shed light some light for me, which OEM stalk can/do I use for the front fogs? I won’t be using the rear fogs. Also the harness needed to run them. Part#, model, etc. All your help will be much appreciated.
Eric
#340 | |
Drives: 2018 Golf R
As far as harness, none is needed. The stalk plugs right into the stock harness and the car is already wired for fogs up to the turn signal wiring. There are two unused wires in each connector behind the bumper where the turn signals plug in. Tap right into those and you have power to your fogs. Sent from my Nexus 4
Parting out HERE
| The Following User Says Thank You to civicdrivr For This Useful Post: | PANDA86 (05-16-2013) |
#341 | |
Old School Status
Drives: .
Thanks for your help. Eric
#342 |
Drives: FR-S, Flex
Does anybody know where I'd be able to get some female pins that fit in the ECU plug? I plan to build a harness for the auto sensor.
#343 |
Drives: Scion FR-S Asphalt AT & XB
Does anyone have the torque spec for the steering wheel nut????
#344 |
Drives: TSX
| The Following 2 Users Say Thank You to norm24 For This Useful Post: | civicdrivr (05-17-2013), PANDA86 (05-17-2013) |
#345 |
Old School Status
Drives: .
#346 |
Drives: 2013 Argento
Can anyone tell me where I can find the turn signal connectors and pins to make a harness?
#347 |
| The Following 2 Users Say Thank You to Willsonk For This Useful Post: | civicdrivr (05-20-2013), emutcfut (05-27-2013) |
#348 |
I just want to say thank you to everyone who put their research and worked together to get a DYI for fog lights. Mine came out great !!!! Thank you again!!!!!!
| The Following User Says Thank You to Willsonk For This Useful Post: | Sco2355 (05-17-2013) |
#349 |
Drives: 2013 scion fr-s ultramarine
any update on getting the auto headlight functioning with just ordering the light sensor. i am planing to get all the stuff to do a fog light upgrade and i am deciding which stalk to order. i would love to have auto light function if possible without a big headache. my wife's matrix has auto lights and its really nice not worrying about turning them on and off when getting out of the car.
#350 |
Drives: FR-S, Flex
It'll probably be a week before I can give you an answer. I'm waiting on re sensor and pins to come in, them I'll let you know how it goes. FYI, the sensor is the same one that's on the Legacy and Forrester.
| The Following User Says Thank You to kmbkk For This Useful Post: | civicdrivr (05-26-2013) |
| Who here has LEDs in their fogs/DRLs in their GT? | RZ86 | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 03-30-2013 10:54 PM |
| Fogs wiring; Will this work? | Khánh | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 02-16-2013 12:44 PM |
| BRZ HID Bulb + HID Fogs | delusional | DIY (Do-It-Yourself) Guides | 4 | 02-05-2013 05:09 AM |
| new Camry fogs fit the frs?? | hislargeness | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 09-26-2012 03:20 AM |
| for everyone thinking of using rear fogs | xpicer | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 07-04-2012 12:53 AM |
