Old 05-12-2013, 08:35 PM   #43
GC GTS Aero Kit
Australian and Proud !!!!
GC GTS Aero Kit's Avatar
Drives: 2012 Toyota 86 GTS Aero Kit
Don are these 3 pumps special or just standard Walbro 255's or DW290s? Do I need to modify the fuel system extensively or is it a kit I will be able to buy and put together at home? I have 1 of the pumps John sent me out for the 500cc injectors but I might need to change this if this is the safe way to go
BONKRS for life
GC GTS Aero Kit is offline
Old 05-12-2013, 08:42 PM   #44
Visconti
Drives: 05 STi
Yes the my 290 or DW's smaller 270 pump can be used.
Install... Don will have to chime in on that
John
Visconti is offline
Old 05-12-2013, 08:46 PM   #45
rusty959
Drives: DGM BRZ limited
Originally Posted by Don@Accelerated View Post
There are 3 pumps not 2. 2 Supply fuel demand and the other is "Magic"
I said one possibly going to the other two not that there were only two. I'm wondering if there are only two going to the engine because of the explanation of why you aren't running a surge tank. What you just said seems to confirm this.
That leaves one left to fix the issue of fuel not getting from the drivers half to the passengers half. There is no need for a pump to do things with the return nor would that help the situation of not enough fuel on the passengers side, so I feel it is safe to assume that the leftover pump is just moving fuel from the drivers side to the passengers side somehow in whatever "Magic" way you chose.
rusty959 is offline
Old 05-12-2013, 09:39 PM   #46
Don@Accelerated
Don@Accelerated's Avatar
1 Pump is your OE. 2 other pumps are the smaller 290s or 260s. You can keep one pump that you have and just buy one. Simply Remove $100 off the kit. I believe John and I talked about doing a core exchange for the basket to make it easy on people. Since your across the world, it'd be best to just buy a core and just do all the work for you. That way you can convert back to your oe piece should you chose to.
Don
Don@Accelerated is offline
Old 05-12-2013, 09:42 PM   #47
GC GTS Aero Kit
John
Yeah interesting to see if the plastic pump housing needs to be modified much to make the pumps fit
BONKRS for life
Old 05-12-2013, 09:42 PM   #48
Don@Accelerated
In a sense. The 3rd pump is making sure the fuel supply on the drivers side has enough flow when the demand requires so that the system can refill the passenger side at the same time and keep the cycle going.
Old 05-12-2013, 09:43 PM   #49
GC GTS Aero Kit
Don
Sounds good its what I did with my Evo 9 I sent my core they modified it with 2 walbro's in it and put it back in
BONKRS for life
Old 05-12-2013, 09:44 PM   #50
Don@Accelerated
Yes the OE plastic housing is modified. You will be drilling 3 holes through it to place the anodized black bulkheads through. Along with a ground stud for the pumps. Its nothing you can't do with a drill bit set and a drill.
Past that, its just normal hand tools. and a little bit of wiring for some relays.
Old 05-12-2013, 10:12 PM   #51
GC GTS Aero Kit
sounds doable I did everything else in the build should be able to manage this too
BONKRS for life
Old 05-12-2013, 11:58 PM   #52
vgi
Drives: frs
just curious, how come no one else developing FI kits with more than 250whp have come across this problem? AVO stage2, P&L, Dynosty, Ptuning, Full Blown, Evasive with HKS, JDL, others? Would people from some of those like to chime in?
vgi is offline
Old 05-13-2013, 12:03 AM   #53
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
this issue has been addressed by stock motor track race drivers, by having starvation as they exit turns. Gem a former member who has been banned also reported this issue on his vortech kit.
SmsAlSuwaidi is offline
Old 05-13-2013, 12:03 AM   #54
Visconti
Drives: 05 STi
We've come across this problem before and just made compensations with the Injector Open time for lack of fuel volume.
When Don was building the new turbo kit he decided to do some fuel flow testing.. that's when he discovered the fuel volume issue.
The fuel flow problem from one side to another continues to be a problem for aggressive road racing guys
John
Visconti is offline
The Following User Says Thank You to Visconti For This Useful Post:
GC GTS Aero Kit (05-13-2013)
Old 05-13-2013, 04:53 AM   #55
GC GTS Aero Kit
John
Im sure John is the first to say Don is testing the shit out of the limits of the stock car more than anyone else. Better to have a fuel abundance than any issue of lack of pressure / volume in my book
BONKRS for life
Old 05-13-2013, 09:08 AM   #56
Don@Accelerated
I'm sure atleast one of them has run into this. I seem to recall FBM using some kind of surgetank setup last year for something.
I think its pretty safe to say i'm the only one daily driving around at 600hp unless someone wants to prove me otherwise!
The Following User Says Thank You to Don@Accelerated For This Useful Post:
charged86 (05-13-2013)
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 10:00 AM
FRS Fuel System Component Walkthrough DeatschWerks Engine, Exhaust, Transmission 8 09-21-2012 12:09 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 05:03 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
Deatschwerks BRZ Fuel System Review xwd Engine, Exhaust, Transmission 0 08-11-2012 03:47 PM
