Old 05-12-2013, 06:14 AM   #29
Calum
That Guy
Drives: 2013 asphalt FRS MT
Why not go with a surge tank setup with an external pump? Just for the extra flow?
Calum is offline
Old 05-12-2013, 09:06 AM   #30
Visconti
Drives: 05 STi
Because that doesn't fix the fuel flow issue inside the tank!
A surge tank setups take up room, smells and is pretty loud.
Basically anyone just popping on a surge tank really hasn't taken a look at the real issue with the fuel system.
John
Visconti is offline
The Following User Says Thank You to Visconti For This Useful Post:
Calum (05-12-2013)
Old 05-12-2013, 09:41 AM   #31
Don@Accelerated
Don@Accelerated's Avatar
Originally Posted by Tansey86 View Post
ah whoops I misread, thought it meant he could maintain 550rwhp on 255's. Nevermind lol
You can backpedal well enough in 2nd and maintain forward movement. Once you get the hang of it its easy. 3rd usually sticks as long as you get the momentum right.
Don@Accelerated is offline
Old 05-12-2013, 09:55 AM   #32
Don@Accelerated
The first thing we had was a surge tank. Unfortunately that doesn't work well.
The factory tank has a crossover pulsation siphon system. The larger flow pump throws that system off. That is primarily one of the reasons people are seeing a starvation problem in corners.
The surgetank relies on the primary system to fulfill its requirements. If the primary system doesn't keep up, your surge system falls off.
Example
2 Pumps in a surge tank for High HP Systems. Requires a 2 Pump lift system to provide an adequate amount of fuel flow over a duration of time. You either need to have a large surge tank, or have enough flow to keep up with the demands of your consumption.
Ok so now we've got 4 pumps in the system. All of them are relatively expensive. We've got an additional enclosure full of gas to kill you in an accident and just another place to leak. Ok Great!
So now lets say you have a 1/2 tank of gas and your considerably below the hump in the primary tank. The pulsation pump will not keep the primary side of tank at an adequate level with the two pumps to keep up the flow to fill the surge tank.
So what do you end up with here. We end up w/ a system that costs considerably to much. Can't run very low, possibly a fire hazard and has flow issues under cornering.
The Following 3 Users Say Thank You to Don@Accelerated For This Useful Post:
Calum (05-12-2013), GC GTS Aero Kit (05-12-2013), stevo_12v (08-27-2013)
Old 05-12-2013, 10:10 AM   #33
NomoreNA
NomoreNA's Avatar
Drives: Raven FRS
if this can hold 3 044s I would buy it today.
NomoreNA is offline
Old 05-12-2013, 10:13 AM   #34
Visconti
Drives: 05 STi
Why do you need 3 044s?
Visconti is offline
Old 05-12-2013, 10:23 AM   #35
Calum
That Guy
Example
This, I understand. Thank you for taking the time.
Calum is offline
Old 05-12-2013, 11:06 AM   #36
NomoreNA
NomoreNA's Avatar
Drives: Raven FRS
LS3 + twin 67s + ignite e98
NomoreNA is offline
Old 05-12-2013, 12:16 PM   #37
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
i use to have an 044 on my past project, way too loud, i would never do it again
Silverdub is offline
Old 05-12-2013, 12:39 PM   #38
rusty959
Drives: DGM BRZ limited
How are these pumps hooked up? I'm assuming one is going from the drivers side to either the other two pumps or to the front as well?
rusty959 is offline
Old 05-12-2013, 01:42 PM   #39
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
*sigh* gonna hold-off going FI...
JackSmiley is offline
Old 05-12-2013, 05:12 PM   #40
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
We were able to maintain 500-550whp on 93 octane.
Put up a new thread already.
Just kidding...
...but,
hurry up.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline
The Following User Says Thank You to Floggin Tires For This Useful Post:
No Limit Motorsport (05-20-2013)
Old 05-12-2013, 05:48 PM   #41
Don@Accelerated
There are 3 pumps not 2. 2 Supply fuel demand and the other is "Magic"
Old 05-12-2013, 06:06 PM   #42
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
any idea when will the build be revealed or at least more information ?
SmsAlSuwaidi is offline
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 10:00 AM
FRS Fuel System Component Walkthrough DeatschWerks Engine, Exhaust, Transmission 8 09-21-2012 12:09 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 05:03 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
Deatschwerks BRZ Fuel System Review xwd Engine, Exhaust, Transmission 0 08-11-2012 03:47 PM
