Old 04-29-2013, 05:56 PM   #15
JimLill
Drives: 2013 Subaru BRZ-L
SRP
I bought the SRP gas pedal only.... what is the trick to remove the factory metal cover?
JimLill is offline   Reply With Quote
Old 04-29-2013, 06:20 PM   #16
CrazyWookiee
Drives: Whiteout FR-S
I fitted the Cusco Accelerator Pedal too. It helps quite a bit, here's an install & review video I did:
[ame="http://www.youtube.com/watch?v=q4cfX1aocTo"]Cusco Sports Accelerator Pedal FR-S/BRZ/86 Install & Review - YouTube[/ame]
"I'm the real Peter Lau" - Peter Lau
CrazyWookiee is offline   Reply With Quote
Old 04-29-2013, 09:14 PM   #17
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
It is held on by metal tabs on the back side. Just use a flat head screwdriver and bend them out. Metal part falls right off.
kask2_6.0 is offline   Reply With Quote
Old 04-30-2013, 01:15 AM   #18
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I'm 6'3" with a size 12 shoe size... No complaints on the stock pedals for me
[ame="http://www.youtube.com/watch?v=rtZQXs-YFds"]Heel and toe - YouTube[/ame]
HRTROB is offline   Reply With Quote
Old 05-01-2013, 04:27 PM   #19
JimLill
The task is as above but goes even easier if you pull out the whole pedal assembly and do it on the bench.
As for heel/toe, the video above shows the old classic heel/toe, actually using the heel. A lot of guys abandoned that and use the side of the foot technique.
http://www.r-series.org/footwork.pdf
Old 05-06-2013, 10:42 PM   #20
weedtank
weedtank's Avatar
Drives: Ultramarine
Did you have to remove the stock metal cover and also did you remove the pedal assembly to install it?
weedtank is offline   Reply With Quote
Old 05-07-2013, 01:01 AM   #21
CrazyWookiee
Nope. It just wraps around the stock pedal. Easy install and fits snug.
Old 05-07-2013, 01:45 AM   #22
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Not sure how your brake/gas pedal are adjusted but when I put on the SRP accelerator pedal if I pressed hard on the brake the gas pedal was at the same surface level - rock the outer edge your foot a little (we're talking a few mm's) and it blips the throttle easily. With maximum braking you could easily inadvertently be hitting the gas...being the brake pedal would be pushed further in. If anything the brake pedal needs to be adjusted out from the firewall a little bit.
I did not like the stock pedal spacing of the FR-S at all, too awkward! My '98 Tacoma is much better setup for heel/toe from the factory... pedals are perfectly spaced with firewall not right off the accelerator pedal like on the FRS. SRP pedal fully fixes the issue by allowing the side of the foot rocking method nearly effortlessly. And after nearly 1 year of use they are as rock solid as when first put on.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 05-10-2013, 05:39 PM   #23
Frs x3
Likes it in the rear
Frs x3's Avatar
Drives: RS 1.0
Hello, I was wondering if anyone could give me some insight on an issue that I'm having. After owning this car for about a month now I'm noticing that my kneecap area is starting to hurt. It has become very uncomfortable for me to even drive this thing to the local grocery store. I'm no heel and toe expert and don't do any track driving so when moving my foot to brake I'm actually bending my knee back to accommodate the uneven level from gas to brake. I've found no level of seat adjusting helps, anyone have any feedback that could be helpful?
Frs x3 is offline   Reply With Quote
Old 05-10-2013, 07:11 PM   #24
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Originally Posted by Slartibartfast View Post
Interesting that you want it closer to you and I want it a little further away. I have SRP pedals too and I find the height perfect for heel-toe around town (I actually just do it out of habit, not because I need to).
But, on the track, with harder braking, the gas pedal is sitting too high to heel-toe perfectly. And it's on the track that I really want it smooth.
I don't know of any way to raise it without a spacer under the SRP plate. (Gas pedal for you, brake pedal for me). But, if you find a way to adjust it, please let me know.
Thanks
Right now my gas pedal is too low with SRP pedals and CL RC6 pads on the street, but on the track it may be a different story. You sound like you have a lot of track experience, so you probably have already done these, but here are things to check off that may help (good for newbies):
1. Get stainless steel brake lines
2. Change to high-temp DOT4 brake fluid and bleed the system within a week before the track day.
3. Get a master cylinder brace
4. Get racing brake pads that are very firm
If you have done all of these and the gas pedal is still too high, you are not alone. This is extremely common with production cars on the track. The technique is to blip the throttle when coming off the brake, not as it is applied:
• Brake hard for the corner with the left foot on the clutch pedal.
• Ease off the brake, and when your foot is high enough, blip the throttle and slip the transmission into the appropriate gear.
• Finish rolling off the brake and onto the gas as you turn into (or go through) the corner and let out the clutch.
If you time it right, very little throttle blip will be may needed as the speed of the transmission will be correct for you chosen gear. On my previous car I was able to do this very smoothly. I feel that having the gas pedal a bit too high is actually preferable as I can compensate easier with proper technique.
I will be on the track in early June, so the experimentation will start then with this new car.
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
The Following 2 Users Say Thank You to Black Tire For This Useful Post:
Elliotw (07-23-2019), Slartibartfast (05-10-2013)
Old 05-11-2013, 08:10 AM   #25
JimLill
Pedal Height
I have had several cars in the past where the pedal height was an issue. I solved every one by going with something like SRP pedals where spacing could be accomplished by putting a spacer between the added pedal cover and the OEM pedal top. The rubber nubs on FRS/BRZ pedals may add a challenge. For racing, the gas must be no higher than the brake under threshold braking, no exceptions!
Old 05-11-2013, 08:11 AM   #26
JimLill
What is your height and inseam? Understanding your leg geometry would help in providing an answer
Old 05-11-2013, 08:36 AM   #27
Frostyman
Drives: 2013 Raven FRS
All of these ideas and suggestions are great. I'm gonna add mine: I drive barefoot. Heel toe is so easy, even a person with monkey toes can do it! I hit the brake with the big toe, and the gas with the other toes. No need for height adjustments. lol
Frostyman is offline   Reply With Quote
Old 05-25-2013, 06:58 PM   #28
Frs x3
Frs x3's Avatar
Drives: RS 1.0
Originally Posted by TyperRspec789 View Post
Alright.. I'm willing to share my secret.. I too have the SRP heel-toe pedal and I love it!
Here's how you RAISE the gas pedal- I've been meaning to put this in the DIY section for months, but been a little lazy about it..
1. Remove the gas pedal assembly by removing the 2 nuts
2. You'll notice there is some slack on the 2 threads that the bolts were on
3. This slack allows you to put spacers to raise the gas pedal ~1cm
4. Reinstall gas pedal assembly
Done.. 1cm makes A TON of difference for heel toe.. It actually made it too easy because I'd find myself blipping the throttle with regular braking. If you guys need help with visualizing this mod- I'll post a DIY.
I just wanted to say thanks for sharing this bit of information. For a month now I've had a knot in my right leg from the stress of switching between pedals. I finally added a spacer and a galvanized washer adding almost an inch in height. This has made driving easier and I can finally drive comfortably.
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 03:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
Rear camber adjustment options? zooki Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 09-12-2012 10:46 AM
Clutch Pedal Engagement Adjustment denverizzles Scion FR-S / Toyota 86 GT86 General Forum 1 07-25-2012 05:01 PM
