Old 05-06-2013, 10:45 AM   #267
HunterGreene
Hail Magnet
HunterGreene's Avatar
Originally Posted by Chinadian View Post
As a noob,
Can we get a video of the adjustment? I cant visualize the way to do it properly =(
Thanks!!
Actually, I had issues with it at first, until I got under there. Its a tight fit, getting a video camera/phone in there to record is going to be even harder.
My advice--printout the instructions, and semi-memorize them. Then do your best limbo dance and get under there with a flashlight. You should hopefully know which one is your clutch pedal, so press on it. Trace the motion of the pedal, and you will find the rod that goes through the firewall to the clutch cylinder. The part you want to adjust is where that rod screws into the U-shaped frame.
It really is that simple, just sounds more difficult than it is. Good luck!
The Following 2 Users Say Thank You to HunterGreene For This Useful Post:
Chinadian (05-06-2013), jcw99 (01-24-2015)
Old 05-06-2013, 11:38 AM   #268
Chinadian
Chinadian's Avatar
Drives: FRS Whiteout
Just adjusted the cluth lower but.wen.i adjust the cruise.control the.bolt when.i turn.it.it actually turns the entire sensor.thing as well and i didnt see the whote protruding.part get less protruding. Thoughts?
Chinadian is offline   Reply With Quote
Old 05-06-2013, 11:57 AM   #269
HunterGreene
Hail Magnet
There are two nuts on either side of the bracket that holds that pressure sensor. Loosen the one that is closer to the firewall, which should make it easier to move the one on the other side. Adjust until the sensor is even, then re-tighten.
Old 05-06-2013, 06:49 PM   #270
JonnyRocket
"New hotness"
JonnyRocket's Avatar
Drives: WRB Limited MT BRZ
As a noob,
Thanks!!
I made a video a few months ago, it's back on page 6 or so. But here it is again.
[ame="http://www.youtube.com/watch?v=ScZFQ0j5beY"]http://www.youtube.com/watch?v=ScZFQ0j5beY[/ame]
@Koji_Online, will you add this to the OP so people don't continue to ask about a video? Or @DarrenDriven, will you add it to post #2? Thanks!
...SOLD my WRB BRZ...
Replaced with a 2013 Mazdaspeed3!
JonnyRocket is offline   Reply With Quote
The Following 4 Users Say Thank You to JonnyRocket For This Useful Post:
Chinadian (05-06-2013), HunterGreene (05-07-2013), jcw99 (01-24-2015), Wes (07-10-2013)
Old 05-06-2013, 11:00 PM   #271
Chinadian
Chinadian's Avatar
After setting the clutch level my previous concern about my rough shifting has been removed. It makes the shift soooo much smoother after adjusting the clutch.
I have not gotten the second part to adjust the sensor yet, but the clutch feels really loose, like if I just tap the clutch it moves around alot. I wondering if thats normal? and will that stiffen up after I complete part 2 of adjusting the sensor?
Old 05-07-2013, 08:38 AM   #272
HunterGreene
Hail Magnet
Did you tighten down the rod? I don't think there should be much loose movement of the pedal, if any.
Old 05-07-2013, 08:39 AM   #273
HunterGreene
Hail Magnet
Kudos to you, sir, you are much more patient and bendy than I.
The Following User Says Thank You to HunterGreene For This Useful Post:
JonnyRocket (05-07-2013)
Old 05-09-2013, 04:38 PM   #274
Koji_Online
N7 Spectre
Koji_Online's Avatar
Drives: 2017 Toyota 86 (Ablaze - 6MT)
Smile
Thanks for uploading a vid! I have updated my OP
GT 6/ Sport PSN: Koji_Online
Koji_Online is offline   Reply With Quote
The Following User Says Thank You to Koji_Online For This Useful Post:
JonnyRocket (05-09-2013)
Old 05-10-2013, 12:20 PM   #275
oofie
Great write up!
I have a simple question though, do we want the sensor to protrude a bit? Mine is protruding a bit, maybe 1-2mm.
oofie is offline   Reply With Quote
Old 05-10-2013, 02:32 PM   #276
Koji_Online
N7 Spectre
Smile
Originally Posted by oofie View Post
Great write up!
Yes, a small protrusion of the white 'button' when adjusting the cruise switch ensures that it will still work & that the switch is not applying pressure on your clutch pedal.
Though it seems most people who adjust clutch pedal height to about even with the brake, do not need to adjust the cruise switch.
oofie (05-10-2013)
Old 05-10-2013, 03:26 PM   #277
HunterGreene
Hail Magnet
I went the anal retentive route and have the cruise switch very lightly against the plate, so I can't see any of the white nib that sticks out.
Old 05-11-2013, 08:19 AM   #278
Chinadian
Chinadian's Avatar
GOt mine done, feels and works great THANKS!!!
Old 05-15-2013, 09:24 AM   #279
mid_life_crisis
Drives: FR-S 10 #103 AT
It may be that the factory adjustment pinned the arm against the mounting collar of the switch, so it didn't move around. Now that you lowered the pedal a bit, it presses the button in, but isn't pinned against the collar, so it is free to move a little, which it wasn't before.
mid_life_crisis is offline   Reply With Quote
Old 05-15-2013, 09:28 AM   #280
mid_life_crisis
Adjusting the position of the clutch pedal is a nice trick, but what would really impress me is if someone could figure out a way to make the clutch engage a little more gradually and less abruptly at the end of the pedal movement. When I drove one, it felt like most of the travel was just wasted movement, that all it needed was to be pressed an inch or two. That last second grab is a pain in the mcnuggets. It could (and should) be a lot smoother.
clutch adjustment, clutch helper spring
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 03:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 02:17 PM
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* wanger Scion FR-S / Toyota 86 GT86 General Forum 5 06-02-2012 01:41 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
